Canon Rebel T7/Sigma 150-600 - Lens detaches itself
Started Jun 15, 2021 | Discussions
Rakeshg New Member • Posts: 10
Hello - I am using a Sigma 150-600 Contemporary lens that seems to "unscrew" itself from the camera body mount periodically. The lens fell twice and I sent it to Sigma to get checked out. They replaced the mount but it happened a couple of times since then (luckily the lens did not fall). I am typically shooting birds, so I do zoom in/out frequently.
Has anyone had this happen? Is there a problem with the camera body or am I just "carrying/using it wrong"? I typically have it slung across my body, lens facing down. I am using a Peak Design Slide strap with one anchor on the camera body (top left) and one on the lens mount.
Any tips or solutions would be appreciated. Thanks!
 Rakeshg's gear list:Rakeshg's gear list
Canon EOS Rebel T7 Canon EF 28-80mm f/3.5-5.6 II Canon EF 75-300mm f/4.0-5.6 III Sigma 150-600mm F5-6.3 | C
Digirame Forum Pro • Posts: 41,857
Re: Canon Rebel T7/Sigma 150-600 - Lens detaches itself
That seems quite bad.  I've never had that happen with my Canon T3i (600D) or Canon T7i (800D) cameras and the Tamron 150-600mm lens or with any lens for that matter.  Maybe you can rent another camera body like the Canon T7i (800D) and see if the problem persists.  The lens should lock in place.  My guess is that it's your camera body that's causing the problem, but that's a total complete guess.
mdmarqphoto Senior Member • Posts: 1,460
I have that lens and have never had any issues like that.  Could you be accidentally pushing the lens release?  Maybe while carrying it facing down the button is being pressed by a belt/belt loop, or a strap somewhere?
 mdmarqphoto's gear list:mdmarqphoto's gear list
Canon PowerShot S5 IS Casio Exilim EX-ZR800 Canon EOS M Canon EOS 90D Canon EF 85mm F1.8 USM +7 more
OP Rakeshg New Member • Posts: 10
I don't think so... originally I thought that may be it, but I've been watching for that and am pretty sure that is not it.
Do you think the zoom movement could be doing it? The lens zoom ring has some resistance and I'm now wondering if the zoom in/out is somehow rotating the lens out of the camera mount.
The lock is in the camera, so any turning of the lens should not release it unless there is a problem in the camera.  Maybe the locking pin/mechanism in the camera is worn.  Have you tried mounting another lens and see if you can get it to turn without pushing the release button?
If I remember correctly, the Tamron and Canon 150-600 zoom in/out in opposite directions?  I'm concerned that my zoom movement may be causing it detach from the camera mount.
On my camera, I don't hear an audible "click" when attaching any lens (even the kit ones). I guess renting a different camera is a good option, so will try that.
I tried with the standard kit lens and it seems solid. Even with the Sigma lens, normally I cannot get it to move without the lens release. It's just really odd that it's happened so frequently and I can't figure out the pattern.
Iron Mike
MOD Iron Mike Contributing Member • Posts: 540
When I first purchased my 5DmkIV, the little pin that locks the lens onto the mount was broken and stayed permanently depressed down. That allowed any lens to turn and pop off (regardless of whether the button on the side of the mount was pressed or not). I promptly returned the camera to the store for an exchange.
The first thing to do is check that the pin is sticking up out of the mount when no lens is mounted, and when you put the lens on the camera it should make a little "ping" sound when the pin pops into its hole on the lens. If the pin is up with no lens mounted, and you don't hear the pin engage once you twist the lens on, then it's possible that the pin doesn't properly register with the hole on the lens.
locking pin
Mike
Yes, to zoom in and out, the Tamron 150-600mm lens rotates in an opposite direction to other Canon lenses that I have (from what I remember without checking). I still suspect it's the camera. The lens should click in place. You should be able to hear it. See what Iron Mike has to say about it.
The pin seems to look normal. I don't hear a "click" sound though, it's more of a "thunk" (when the lens and camera markings align. If I use my hands to move the lens, there is just a little bit of play, but it doesn't unscrew.
I guess I will just have to keep a watch on it and see if I can figure out what could be happening. Thanks again for your help
Toronto Photography
Toronto Photography Senior Member • Posts: 1,064
It should lock with a click. MY guess is your click lock on your camera is damaged, and the weight of the lens plus zooming cause it to unlock.  I doubt it is the lens other than the size/weight.
 Toronto Photography's gear list:Toronto Photography's gear list
Canon EF 70-300mm f/4-5.6 IS USM Canon EF-S 55-250mm f/4-5.6 IS II Canon EF 24-105mm F3.5-5.6 IS STM
Toronto Photography
See above but it sounds like it worn and again the weight/motion combo causes it to be an issue.  Buy a used rebel XT for 60 bucks and see if its an issue, the mounts are the same. Or rent one, or lend me your lens and I try it out to see if its a lens issue. (or a friend)
I think it was (is?) an issue with how I had the strap connected. I noticed that the release button was facing in and could be jostled by my hip. I changed the orientation of the strap and also connected it to the lens mount and now the camera faces outward. So far, I have not had it happen again, so keeping my fingers crossed.🤞
User4286416121 Senior Member • Posts: 1,225
My first thought is similar.
Connecting the strap to both the lens and the camera gives a twist.  Just wait for the button to get nudged and voila..
tkbslc Forum Pro • Posts: 17,523
can you twist the lens off yourself without pushing down on the button?
You aren't inadvertently resting your hand on the release when supporting the lens?
I changed the way I had my strap connected (now the camera faces away from my body) and so far, it has not happened. I think I may have been jostling the release with my hip but can't be certain.
Ah, I missed your last reply.   Good you found a potential solution.
