Capture One Express in Conjunction with Lightroom
Started Jun 12, 2021 | Discussions
pao1os New Member • Posts: 2
Hi,
I am a Fuji X photographer, using X-E1,2 and X-T20 bodies. Up until now I have used Lightroom to catalogue and edit my images. I have noticed that although it has gradually improved, LR does not deal with sharpening and noise particularly well with the X-Trans sensor images.
I have discovered that I have free access to Capture One Express so my thinking was that I would load up images which are worth keeping or selling into C1 for sharpening, noise and Fuji colour profiles (as these are apparently accurate to Fuji's specification) then finish my processing in LR and PS.
However I am having difficulty in exporting from C1 and importing into LR. I have discovered that C1 will not export RAF files to DNG so I was thinking of baking the changes into the image but am not sure which format to export to. The options appear to be TIFF or PNG (apart from JPG).
Any suggestions?
Fujifilm X-E1 Fujifilm X-E3 Fujifilm X-T20 Phase One Capture One Express 7
Ysarex
Ysarex Veteran Member • Posts: 3,354
Re: Capture One Express in Conjunction with Lightroom
pao1os wrote:
Hi,
Any suggestions?
Return 16 bit TIFF files to LR.
Erik Baumgartner Senior Member • Posts: 6,893
pao1os wrote:
Hi,
Any suggestions?
A whole lot easier to use the Iridient X-Transformer plug-in ($36) from within Lightroom. Two mouse clicks and you can produce well demosaiced DNG’s from a single or multiple selected RAFs which appear next to the original images with all your Lightroom development settings up to that point (including color profiles/film sims etc.) automatically applied (you will want to apply different sharpening/NR settings). X-Transformer demosaicing is on par with C1’s.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
BJ60EH Regular Member • Posts: 137
I quite often export from C1 to LR using 16 bit tiffs. Tiffs are lossless and I don't see any loss in quality.
Just make sure they're 16 bit, C1's default is 8 bit.
Here's an example
 BJ60EH's gear list:BJ60EH's gear list
Fujifilm X-T2 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm 50-230mm Fujifilm XF 10-24mm F4 R OIS
iancbradley Regular Member • Posts: 294
I export Jpegs (shock horror). I have resigned myself to using ONLY C1 for Raw processing and editing; and using LR ONLY for organising and sharing (well, I do make the occasional tweak in LR, but I try to avoid it)
it took some effort to learn the UI for C1, and it was a wrench to give up editing in LR, but worth it.
It works even more smoothly if you upgrade to the full version of C1 and use the Sessions workflow
SDPharm Regular Member • Posts: 298
> I export Jpegs....
Ian, if you use a Mac, you can also use Apple Photos to organize your keepers. In addition to the usual keywords, folders, etc, Photos is very good at searching images that are not indexed. For example, you can search for 'cars' or 'trees' or 'flowers' or certain people or pets. It works surprising well.
 SDPharm's gear list:SDPharm's gear list
Fujifilm X-T5 Zeiss Touit 50mm F2.8 Fujifilm XF 16mm F2.8 Fujifilm XF 16-80mm F4 Fujifilm XF 70-300 F4-5.6 R LM OIS WR
(unknown member) Senior Member • Posts: 2,057
Before it was possible to use Classic Negative on Lightroom Desktop I used the free C1 to batch apply the film sim, batch auto correct, then batch export as JPG. I tried Tiff but the file size was too big. Then import the JPGs and raf files from the camera into LR.
Now I edit fully in Lightroom despite their Classic Negative being worse, and I assume the other sims. Pressing the auto button in C1 generally was better than not e.g. recovering shadows, but that only left a JPG to edit in Lightroom.
I edit every photo's colors I use with Classic Negative so I should just make a preset as I like it a bit different to the others. But C1 Classic Neg is by far the best imo.
Maybe try my auto thing (apply auto button on import with the film sim) to see if that makes JPGs you are happy with? Or like others have said 16 bit Tiff files, if file size isn't an issue.
