Helen
Re: Differences between the Olympus Pen e-pl9 &. e-pl10?
iKokomo wrote:
I have used an Olympus Pen e-pl1 for years upgraded to an e-pl7 and now (after using it to death) I am looking at upgrading once again.
I love the small form factor/high-quality image that I have gotten out of my e-pl series. I also have a lot of good glass for it.
Therefore, I was wondering if there was any difference between the Olympus Pen e-pl9 vs. e-pl10?
I have researched multiple websites and they say the only difference is a couple of "in-camera editing options" are different. Since I use Adobe LR to edit, I do not care about those features.
Are there any other differences between the e-pl9 vs. e-pl10?
You have had great responses from Guy Parsons and Confusedabit but I'll add my thoughts too...
As they both mentioned, a valuable feature added to the E-PL10 in particular is that the silent shutter facility is available in the PASM modes - it was first introduced to the E-PL range with the E-PL9, but on this model was trapped within a subset of features at the AP "Advanced Photography" position of the mode dial called Silent Mode, which only operates in a full-auto (program-only, but with considerably reduced options and flexiblity compared with normal program mode). That option still exists on the E-PL10 too, but the full availability of silent shutter being available alongside the other shutter options of full mechanical and 0-sec Anti-Shock (i.e. EFCS) in the PASM modes is much more useful.
A further refinement of silent shutter mode in PASM on the E-PL10 is that there exist options to re-enable the use of flash with silent shutter, as well as focus beeps and the AF-assist light (all three can be re-enabled individually and it only needs to be done once unless you want to disable them again later). Whilst other lines of Olympus models introduced silent shutter earlier, these re-enablings only became options fairly recently on models higher up the range, with the Pen-F being the first, followed by the E-M1 II, E-M1 III, E-M1X, E-M5 III and, after the E-PL10, the E-M10 IIIs (not the III) and E-M10 IV. Presumably the forthcoming E-P7 will have these features too.
Compared with your previous E-PL1 and E-PL7, the E-PL9 and 10 reinstate the built-in flash from the E-PL1, but unfortunately both lost compatibility with the add-on EVF units, the VF-2, 3 and 4 (because they no longer have an Accessory Port - so any other Accessory Port-compatible add-ons such as the Macro Arm Light cannot be used either). I mention this in case you have and use any of them.
Whilst the E-PL9 and 10 are physically identical to one another aside from a couple of different options in their body colour choices (and they are broadly similar in design to your E-PL7), they have all-polycarbonate exteriors yet surprisingly, are slightly heavier.
They have the expected advancements in movie mode (not that I am a big user of video modes, so not well-informed there) but both models have far fewer customisation options than previous E-PL models and fewer customisable physical controls (the menus are brutally shortened) so be aware of this. They also have absolutely no custom memories or MySet features whatsoever - again, something to be aware of if you are fond of these on your E-PL7.
