DIY Ni MH battery pack
Started Jun 9, 2021 | Discussions
TCoulter New Member • Posts: 23
So I made a DIY auxiliary battery from an RC Car battery. Its 9.6v. My old warhorse Sunpak 555 does battle with the sun pretty well. Just needed more oomph. Long story short, shot a full day wedding indoors and out on the first charge. Only used 30% of the juice. I machined Delrin mounts so it snaps to my flash in seconds.
Macro guy
Macro guy Veteran Member • Posts: 6,067
Re: DIY Ni MH battery pack
This is pretty cool.
How many amp hours is the battery?  What did you use to connect the battery to the flash?
 Macro guy's gear list:Macro guy's gear list
Canon EOS 5D Mark II Canon EF 50mm F1.8 II Canon EF 70-200mm F4L IS USM +4 more
Macro guy
That's pretty cool. I had done something similar with my Sunpak 544, but I used a 12v lead acid battery and I had to get a voltage regulator to knock the voltage down to 9v, so the package is much bigger and heavier. I like the fact that you were able to stick the battery pack to the flash handle.
OP TCoulter New Member • Posts: 23
For less than $70 total investment, it has far exceeded my expectations. The charger takes very little time charge to full capacity.
Macro guy
That's great. I'll investigate this option.
