A Hawk at Publix
AlwynS Veteran Member • Posts: 3,945
Re: A Hawk at Publix
Bassy wrote:
well written alwyn very well explained
Thanks kindly Bassy. One thing that I find that is incredibly important is that we all have to come up with settings and a "workflow" that works for us. I am extremely comfortable with the process I described but that does not mean it would be the right thing for somebody else.
just for the record i do not have smile/face detection turned on in my camera
i do have zebra custom 1 turned on lower limit 109 plus
Makes sense. I realise that my "manual" workflow of managing exposure through movement of the metering point plus adjusting EC if required is open to errors as it relies on me judging the Live view exposure. But I have been doing it for so long now that it is totally second nature. Which of course does not mean I do not mess up on occasion....
Cheers
Alwyn
 AlwynS's gear list:AlwynS's gear list
Nikon Coolpix P610 Sony RX10 IV
Rodger1943
Rodger1943 Forum Pro • Posts: 16,469
Initially, I thought it was a great shot, but on closer examination I could see that the focus on the head was "soft". I too have encountered this many times, even on small birds, where the body is in focus and the head not so much. The easiest way round it I have found it not to use F4, but try F5.6. That gives you a greater depth of field and allows the head to be more like the body, this is especially true, when the bird has its back to you, as the back is closer than the head. The greater depth of field you get with F5.6 is enough to show the whole bird in focus. There are times when you really want to use F4, as it lets in a lot more light, you can then try manual focus on the head and then you can move the camera around for re-framing and still keep the focus on the head.
Panasonic FZ1000 FZ200 Sony RX10 iv
 Rodger1943's gear list:Rodger1943's gear list
Panasonic Lumix DMC-FZ200 Panasonic FZ1000 Sony RX10 IV +2 more
Sorry Rodger but, while it might be a matter of degree, I must disagree. It is generally accepted that the head/eye is the prime objective to be in focus. Increasing the DoF is a palliative measure. The fix is to focus on the head. In this case there is absolutely no reason why one could not comfortably have focused on the head/eye using Flexible Spot in the right position. If then you want the rest of the body in focus one could consider reducing the aperture for greater DoF.
Cheers
Alwyn
sherman_levine
sherman_levine Forum Pro • Posts: 13,245
How about using the lock on subject focus, locking on the eyes by moving the camera?
 sherman_levine's gear list:sherman_levine's gear list
Panasonic FZ1000 Sony RX10 IV Nikon Coolpix P950
Accepted that there is more than one way of doing it. I just described one way that gives me great control over focus and exposure plus it allows the camera to use AFC to re-focus between burst shots. Plus I do not have to repeatedly do it for follow on bursts: I just place the focus/metering spot where I want it and press the button. Enough benefits for me to have happily done it this way tens of thousands of times with results that I am totally happy with.
Seeing that birding is my primary genre anything that makes life simpler, allows me to shoot repeatedly quickly and gives me results that I am satisfied with makes me happy.
Cheers
Alwyn
OP Elliern Senior Member • Posts: 1,707
I was thinking the same thing, Sherm.  Have been reading all the comments here, and White’s ebook and even some birding blogs on using the camera.  But sometimes that’s information overload and I just get more confused. I made so many changes before that I  just did a reset and started over.
Ellie
Enjoy the Moments!
“What day is it?” asked Pooh.
“It’s today,” squeaked Piglet.
“My favorite day,” said Pooh.
A.A. Milne
 Elliern's gear list:Elliern's gear list
Canon PowerShot SX50 HS Nikon Coolpix P610 Nikon D5100 Sony a6000 Nikon D5500
As I said at the beginning: to each his own. I have absolutely no reason to change from my method because it simply works for me. I am 100% happy with both the process (because for me it is fast, intuitive and flexible) and the results. But obviously you should use whatever works for you.
FWIW I have just checked: I have about 87,000 shots on my RX10 IV, probably >60% birds. As mentioned before: bird photography is basically what I do.
Cheers
Alwyn
Rodger1943
Fair enough Alwyn, you're right about the head being the primary focus, I was just offering an alternative that seems to work for me.
sherman_levine
Alwyn,
Wasn't suggesting that you change.  Indeed for the RX10, lock on subject is a particularly bad choice, because the lock appears to persist only for a single shot.
For the FZ1000, and I suspect the other Panasonics. the lock persists until canceled, so one can reposition, and change zoom while the tracked subject remains in focus.
Sherm
jodaco Regular Member • Posts: 103
Alwyn,
Sherm
The lock persists as long as auto focus is engaged. This is one of the benefits of back button focus. If focus is disassociated with shutter release then ending a burst of exposures (or a single shot) does not give up the object lock.
That being said I think this subject is still a bad candidate for locking the subject. The subject locking algorithms are sensitive to contrast and color and are usually not good at distinguishing a head from a body (unless it is a human or dog/cat face and those features are enabled). In this case if you had tired to lock the entire hawk would have been considered the subject and then the closest point of that subject would have been the focus point. This still would have likely been the belly.
 jodaco's gear list:jodaco's gear list
Sony RX10 IV
