Lens upgrades? 70-200 2.8 EF->RF?
Started Jun 8, 2021 | Discussions
steeldrake Junior Member • Posts: 43
I plan to upgrade my 7dmk2 to R6 (yes would like the cropping extra of R5 for wildlife, but considering price - including memory cards -, file size, low light etc it all makes R6 sound better).
Any thoughts on lens upgrades:
I currently own EF 100-400L II, EF 70-200 2.8L III, EF 24-70 2.8L, EF 100Macro II, EF-S 10-22. I use the 100-400 most often, so i plan to upgrade that to RF 100-500. The macro i use seldom, so i will keep it, 24-70 upgrade is so expensive, so i keep it. But i was wondering does it make sense to upgrade the 70-200? Any opinions? I do not use it that much so i could suffice with adapter but would upgrade provide even more quality/features/...
 steeldrake's gear list:steeldrake's gear list
Sony RX100 VI Canon EOS R6 Mark II Canon EF 100mm F2.8L Macro IS USM Canon RF 24-105mm F4L IS USM Canon RF 70-200mm F2.8L IS USM +3 more
Klaus dk
Klaus dk Veteran Member • Posts: 9,755
Re: Lens upgrades? 70-200 2.8 EF->RF?
Can't tell you what you should do, but I chose to go with pre-owned EF lenses (had mostly EF-S) for the low-usage focal lengths and RF for those I'd use most. So far that has been a good solution for me.
If you don't use the 70-200 that often, you'll probably not want to use the RF often either. Going from crop to FF and being a portrait shooter, the RF 70-200/2.8 was my dream lens, but it's the only top notch RF lens I've bought so far.
Good luck and good light.
 Klaus dk's gear list:Klaus dk's gear list
Sony RX100 II Canon EOS R Canon EOS R5 Canon EF 16-35mm F4L IS USM Canon RF 24-105mm F4L IS USM +7 more
tkbslc Forum Pro • Posts: 17,522
portable side-grade
The RF is smaller and lighter
The EF can take teleconverters.
Optically the RF is a hair sharper (really have to pixel peep charts to see it).  But the RF also has significantly more vignetting.
I wouldn't call it an upgrade.  More of a decision of if you want to pay a premium for a version of the same lens that is much more portable.
moon1029 Regular Member • Posts: 304
The EF has smoother zoom ring. The RF has IBIS correction for pitch/yaw movement.
The RF seems to have better focus, especially using eye detection.
 moon1029's gear list:moon1029's gear list
Canon EOS R5 Canon EOS R6 Canon 85mm F1.4L IS USM Canon RF 15-35mm F2.8L IS USM Canon RF 70-200 F4 L +6 more
iShootWideOpen
iShootWideOpen Regular Member • Posts: 428
I get my RF 70-200 F/2.8L IS this afternoon after selling my old EF 70-200 F/2.8L IS II
My main reason for the upgrade was portability. The already long EF version is made even longer with the adaptor. No thanks!
 iShootWideOpen's gear list:iShootWideOpen's gear list
Canon EOS R5 Canon EOS R6 Canon EF 50mm f/1.2L USM Canon EF 85mm F1.2L II USM Canon EF 135mm F2L USM +10 more
OP steeldrake Junior Member • Posts: 43
Thanks all. Good points everyone. Portability is a important for me too. Currently the big size means i often leave the lens home.
How bad is the vignetting? Using crop body on my white lenses today i do not have any problem with those lenaes naturally.
Any comments on swithing from EF 24-70L 2.8 to RF 24-105L 4.0 IS? (No money left for 24-70 😆)
The Light Stalker
The Light Stalker Contributing Member • Posts: 960
I've put my EF 70-200 f2.8 II up for sale so I can justify the RF version. Aside from the RF not accepting teleconverters, the portability will make an excellent replacement in my 3 lens walk-around bag. When I need more telephoto I have other lenses that are up to the task. The R5 makes the 100-400L II sing even with low light situations, amazing.
The Light Stalker
 The Light Stalker's gear list:The Light Stalker's gear list
Hasselblad X2D 100c Apple iPhone 12 Pro Max +1 more
The Light Stalker
I've put my 24-70 f2.8 II up for sale as I found it to be too long and unbalanced on the R5.  The RF 24-105L f4 is a pleasure to use, makes a great walk-around lens and the extra focal length is most welcome.
The Light Stalker
thunder storm Forum Pro • Posts: 10,139
If you didn't miss the wide end on the 7DII, you could also have a look at the Tamron 35-150mm f/2.8-4.0....
I love 50mm (equivalence)
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
Mike Arledge Senior Member • Posts: 2,465
If you don’t need the 2.8 speed, I have the RF 70-200 F4 on the R6 and it is just stunning to use.  I have no plans to need the speed for extra light and prefer primes when shooting faster than F4 to go even faster like F2 or F1.4.  I would strongly suggest it as a replacement consideration.
 Mike Arledge's gear list:Mike Arledge's gear list
Nikon Z5 Nikon Z fc Sony a7 IV Canon EF 24-70mm F2.8L II USM Sigma 28mm F1.4 DG HSM +5 more
Leigh A. Wax Senior Member • Posts: 1,621
For me, Adapter "swapping" was the main issue as to retaining my EF lens's.
If you stay with all EF, you can leave the Adapter on an "R" body; whereas if you mix EF & RF, unless you have two Bodies, or a separate Adapter for each EF lens your "toting", you\re not only dealing with lens changing, but fumbling with Adapter swapping as well.
Though my EF 100-400L-v2 functioned extremely well on my R5, with the Adapter plus a 1.4 TC it became "awkwardly " long zoomed out.
In the end, I sold most of my EF gear, retaining only the EF 16-35F4L, with the Adapter "permanently" attached.
Currently, It's an R5, RF 100-500L, RF 1.4 TC, RF 24-105F4L, & EF 16-35F4L; and in the future hope for a "back-up" body (R7 ???), & ??? lens/s.
Unfortunately, there are some down-sides to some of the RF Zoom's, like the RF 100-500's inability to zoom fully back, and others that are not compatible with TC's at all.
tdbmd Senior Member • Posts: 1,546
I have a 7DII and now the R6.  I think my EF lenses are even better on the R6 using an adapter.  I would try them on the new body first, before going to RF series, I think you will be impressed
 tdbmd's gear list:tdbmd's gear list
Canon EOS 7D Mark II Canon EOS Rebel T8i (EOS 850D) Canon EOS R6 Canon EF 85mm F1.8 USM Canon EF-S 17-55mm f/2.8 IS USM +11 more
That's an important point.
I have the RF 85mm f/2.0 as my only RF lens. It's not the most used lens, so it's not a very big deal. But when you have 2 frequently used EF lenses and one frequently used RF lens it can become annoying to do the adapter swapping.
Karl_Guttag Senior Member • Posts: 1,883
The Vignetting is not significant on the RF70-200f2.8L (check the many Youtube videos such as https://www.youtube.com/watch?v=dituzmm4VvU). Generally much less than the RF15-35 and RF24-70f2.8L.
Canon does depend heavily on vignetting and distortion correction with most of the RF lenses but not so much the RF70-200f2.8.  There is a slight barrel wide open and pincushion at the far end but both are mild compared to other lenses. Every RF lens is extremely sharp in the center even wide open and the RF70-200
Note, I went through two copies of the RF70-200f2.8L as the first one seem badly decentered at the wide end. The second one I got is amazingly sharp throughout the range but a little softer while still what I would consider good at the wide end to the corners. At 200mm it is as sharp as the R5 could detect all the way to the corners (I looked at corners at f2.8 that look better than the center of most lenses).
Of the three f2.8L zooms I have, the RF70-200f2.8L is clearly the best through the range without correction. In terms of sharpness and contrast in the corners after correction, the RF15-35 is second best and the RF24-70 (surprisingly) is the weakest of the three (particularly at about 35mm).
 Karl_Guttag's gear list:Karl_Guttag's gear list
Canon EOS R5 Canon RF 15-35mm F2.8L IS USM Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 24-240mm F4-6.3 +14 more
Another thing to consider in the RF VS EF decision process , is that Canon, like other's, is for now near "totally" dedicated to mirrorless; and as more folks abandon EF for RF, the future value of your EF gear, on the used market, will diminish accordingly.
Prices for new EF lenses are going up.  Bodies like the R and RP will become more and more affordable. And a used 6DmkI is only 400 euro these days.
There won't be supply only of used EF glass. There will be a demand too.
iShootWideOpen
For me these are the two RF lenses that offer the biggest advantage over their EF counterparts and the main reason (along with R5-R6 AF) why I switched from Canon DSLR's.
David Franklin Senior Member • Posts: 1,692
Re: Lens upgrades? 70-200 2.8 EF->RF? That w
Well, FWIW, here is what I did, and my rationale for it, even if it might not fit your particular needs.
I sold my EF 24-70 and bought the RF 24-70, for several reasons, all of which have been validated by use. It’s sharper overall, has much less lateral chromatic aberration (almost none on mine), has less variation of sharpness and contrast across all focal lengths, is quieter when focusing and quicker focusing, and feels even more “sturdy”, although it does not feel any lighter.
I kept my EF 100-400 II because it was such a great performer, I didn’t care that much about another 100 mm, did not use it that much and the cost of the the lighter weight RF was disproportionate to my needs.
On the 70-200, that was a close call, but the new RF version won me over and has worked out very well so far. If money is a serious issue for you and you love the idea of a non-extending lens barrel and very short focus throw, plus the ability to use Canon tele converters, I would urge you to keep your EF version. For me, the amazing compact size, when stored in my bag and just carrying it around, were wonderful benefits of the new RF, as was the considerable lowering of its weight. These advantages meant that I am more likely to carry the lens and that meant that I will get more use out of it. The new lens does seem to be just the smallest amount possible better optically, but, if so, it’s by a trivial amount. I love this new RF version and it fits my needs perfectly. It also may have other future benefits tied to the new mount, but, that remains to be seen.
Keep learning; share knowledge; think seriously about outcomes; seek wisdom.
 David Franklin's gear list:David Franklin's gear list
Canon EOS R5
ThoreauAZ Regular Member • Posts: 111
I'm halfway there!  That 28-70 was my main reason to jump into the RF world.  Now I'm working on making my EF 70-200 f/2.8L IS (not II or III, ollllld gen 1) disappear so I can grab the RF version.
KEH has been gobbling up my old equipment like pacman to bring me closer
 ThoreauAZ's gear list:ThoreauAZ's gear list
Canon EOS R5 Canon EF 70-200mm f/2.8L IS USM Canon RF 28-70mm F2L USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 50mm F1.8 STM +1 more
You have good points. The short focus throw is an easily overlooked but important feature to me. I like the 0.7m MFD too, which would allow me to take otherwise impossible shots.
