Dynax 7D - Image quality and size won't persist after switch off
Started Jun 8, 2021 | Discussions
c4lv1n New Member • Posts: 1
Hello all,
Bit of a camera noob here, inherited from my grandpa.
I'm having issues with the image quality and size resetting whenever i turn the camera off and back on again? I've tried resetting to default in case I changed a setting by mistake but I'm certain I was able to shoot RAW by default without having to manually change this every time I turn the camera on?
The date and time persist which makes me think its not the internal battery?
Any advice would be massively appreciated!
Thanks in advance!
Konica Minolta Maxxum 7D (Dynax 7D / Alpha-7 Digital)
dutch_km_user Regular Member • Posts: 172
Re: Dynax 7D - Image quality and size won't persist after switch off
Hi Calvin,
If you are using the 7D in 'green P' mode this is how it is supposed to work.
In all other modes the setting should remain after switching off and on.
Please let us know if this solves your problem.
Vincent
 dutch_km_user's gear list:dutch_km_user's gear list
Konica Minolta Maxxum 7D Sony Alpha DSLR-A900 Sony DT 18-70mm F3.5-5.6 Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony DT 16-80mm F3.5-4.5 ZA Carl Zeiss Vario-Sonnar T* +6 more
Joseph Balson
Joseph Balson Regular Member • Posts: 299
Definitely the P mode: it puts the camera in 6MP fine Jpeg whatever you do in the menu.
It's just some glass, some silicon and magnesium. It isn't a religion.
