Canon SX60 with Godox V860IIc flash (over/under exposed)
Started Jun 7, 2021 | Discussions
mgrosh New Member • Posts: 2
I just purchased a Godox V860IIc flash for my Canon SX60 and started testing it out. At first i noticed that every photo was underexposed. It does flash but not at full power. The flash is in ETTL mode and have have tried the camera on multiple modes and settings.
What really get me is that the Flash seems to either flash at very low power (underexposed) or full power (overexposed).
for example, see these two photos taken. in Av mode with all default settings on the camera.
anything FEC -2.00 or greater comes out underexposed.
anything FEC -2 1/3 or less comes out way over exposed.
Canon PowerShot SX60 HS
Jon_T
Jon_T Veteran Member • Posts: 6,393
Re: Canon SX60 with Godox V860IIc flash (over/under exposed)
for example, see these two photos taken. in Av mode with all default settings on the camera. ....
Not all "default settings"; both images taken with the "Spot" metering:
Give a try with the SX60 HS' "Evaluative Light Metering" to see if it helps.
I have the small Godox TT350 to use on my RX 10 IV and it works great with the Sony TTL metering.
Good Luck!
 Jon_T's gear list:Jon_T's gear list
Panasonic Lumix DMC-FZ200 Canon PowerShot G15 Canon PowerShot SX50 HS Canon PowerShot S110 Leica C +16 more
OP mgrosh New Member • Posts: 2
Good Luck!
Yes, tried with all three metering settings with the same results (was on spot because that was the last i tried after seeing a similar suggestion on another thread)
Obviously is it normal for such a large change in exposure with on a 1/3 change in FEC???
thanks,
Jon_T
Good Luck!
Would not think so with just "FEC". Though from the EXIF problem not due to using "FEC" and camera's "EC"; which can be cumulative with some cameras.
The EXIF's "Flash Fired" notes "Yes (Auto, red eye reduction mode, returned light detected)". Not sure what the "returned light detected" means.
Do you have same +/- exposure issue with red eye reduction mode OFF?
If you have not already done, try the "support" at the Godox Site HERE.
Via a Google "godox v860iic flash inconsistent exposure" search found the DPR "Inconsistent exposure with Godox V860II" topic HERE.
If you have/ or can borrow another flash unit to see if problem persists to find out if problem with the Godox V860IIc flash.
Sorry cannot be of more help.
The Godox TT350 I use with RX10 IV works great.
Jon
Sue Anne Rush
Sue Anne Rush Senior Member • Posts: 6,285
Excellent series and thank you for sharing.
Sue Anne Rush
 Sue Anne Rush's gear list:Sue Anne Rush's gear list
Canon PowerShot G9 Panasonic Lumix DC-FZ1000 II Canon PowerShot Zoom Canon EOS 7D Canon EOS Rebel T7 +4 more
parkhyunjeong New Member • Posts: 14
That's nice equipment! But, I think you could also explore more because it has really so much potential.
kli
kli Veteran Member • Posts: 4,589
Just me, but putting the camera in M and not using auto ISO takes a lot of guesswork out of the equation. If you do those two things, do you still get this behavior? What happens if you put the camera in P mode?
Happens with dSLRs when using Av/Tv with flash, where the autoexposure modes are pretty much set up that flash will be for daylight fill if you have everything set to be automated. Only P mode will treat the flash like a pop-up flash and use it for main illumination in low light.
That happens if not all the pins are touching all the hotshoe contacts. When TTL communication isn't happening, the flash will always fire at full power. Check that the speedlight is seated fully forward in the hotshoe, and that the locking pin is in place.
Aside from all of this, Godox speedlights work with the Canon dSLR/mirrorless hotshoe. When it comes to fixed-lens compacts, 3rd-party flashes may not behave so well, as Canon apparently uses a different communication protocol with the Powershots than they do the dSLRs.
I remember getting a Yongnuo YN-568EX for my 50D. Worked beautifully. Did everything my 580EX did. On my Powershot G9, however, the 580EX worked fine, but the YN-685EX wouldn't even fire. It could also be you've hit one of those communication variant holes where Godox's reverse-engineering doesn't work.
 kli's gear list:kli's gear list
Fujifilm X100T Canon EOS 5D Mark II Canon EOS 50D Panasonic Lumix DMC-GX7 Canon EF 135mm F2L USM +12 more
YehudaKatz Senior Member • Posts: 2,512
It appears to me that the flash isn't seated all the way inside.
No text.
 YehudaKatz's gear list:YehudaKatz's gear list
Canon EOS 6D Canon EOS M50 Canon EF 24-105mm f/4L IS USM Canon EF-M 22mm f/2 STM
