MC-21 Sigma SA to L mount
Started Jun 6, 2021 | Questions
George1958 Senior Member • Posts: 1,475
Hi, I am considering buying a Sigma FP but I am torn between this and a Sigma Quattro H. I have an SD15 and the 18-35 F1.8 Art and the 50-100 F1.8 Art.
These I understand would be fine on the Quattro. However I go down the FP road and use the MC-21, will I get vignetting or experience cropping of the FP sensor given my lenses are APSC?
I can't really justify the expense of buying new L Mount lenses at this time.
My thanks in anticipation
George
 George1958's gear list:George1958's gear list
Sigma DP1s Sigma SD15 Olympus PEN E-P3 Sigma sd Quattro Olympus E-M1 II +6 more
Sigma sd Quattro H Sigma SD15
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
Re: MC-21 Sigma SA to L mount
These I understand would be fine on the Quattro. However [if] I go down the FP road and use the MC-21, will I get vignetting or experience cropping of the FP sensor given my lenses are APSC?
Yes.
Others may be along shortly to disagree ...
Pedantry is hard work, but someone has to do it ...
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
docmaas
docmaas Veteran Member • Posts: 7,061
I don't think so.  On the original fp Sigma did not allow a choice for apsc if it could read the lens info, which it can for all modern Sigma lenses.  If apsc is detected it will only allow the camera to shoot in apsc mode. Any vignetting seen will be approximately the same as you would see on the Quattro.
Mike
"Laoma shitu" "An old horse knows the road" Chinese Proverb                                        "Dao ke dao, fei chang dao. Ming ke ming, fei chang ming" Laozi
"At every crossroads on the path that leads to the future, tradition has placed 10,000 men to guard the past."
Maurice Maeterlinck
Ceistinne
Ceistinne Veteran Member • Posts: 3,256
George
George,
If you use APS-C lenses on a full frame camera you will definitely get vignetting. If the camera can detect APS-C it will auto switch to the APS-C crop size if the camera has that feature or you could change the setting to APS-C by way of a switch or in the menu, again if the camera has that feature. Most of them do. I do not know whether the fp or fp L has. Have a look at the User Manual on the Sigma website for information on that.
The lenses you reference above will be ok on the sd Quattro H, the 18-35mm may vignette slightly up to 19 or 20mm  but will be ok up to 35mm.
S
 Ceistinne's gear list:Ceistinne's gear list
Sigma SD1 Merrill Sigma dp2 Quattro Sigma SD9 Sigma SD10 Sigma SD14 +5 more
SigmaTog
SigmaTog Senior Member • Posts: 1,114
Sigma lenses with the designation DC will vignette on a full frame, the designation DG will cover full frame.
rick decker
MOD rick decker Forum Pro • Posts: 19,097
Yes you will...Depending upon your preferences, you can choose DC Crop on or Dc Drop Auto On or DC Crop Off. With the FP and DC Crop On, your image is reduced dramatically in size - just under 10 mp. Using the 10-24 ratio with a 60 mp you would be reduced to 25mp. If you are willing to do your own cropping, here is a table based upon the fp (24mp) and the 8-16:
8m.........12-13mp
10mm...14-15 mp
12mm...18-19 mp
14mm...24mp
16mm...24mp
Now don't assume that these ratios are the same for other lenses. My point is that using DC Crop on or on auto, you give up a lot. But you may not want to crop so many images. If you are a windows user, FASTSTONE has a cropping function that displays the new size on the bottom of the screen and has a whole bunch of presets as far as ratio goes. And it also has a horizon-straightening option and a whole bunch of other stuff.
You have my express consent to edit any of my images that I post on DPR. If you want to edit an image that does not belong to me that I have edited and posted, you need to contact the owner.
http://www.lightreflection.com
http://www.rickswavepics.com
D Cox Forum Pro • Posts: 32,979
There are two reasons to buy the fp : much higher ISO in colour, and being able to use manual-focus lenses from film SLRs.
If neither of those matter to you, then I think the sdQH is a better camera for still photography. However, it might be good to get an MC-21 soon while it's still available, so that you can buy an L mount camera in the future. SA cameras have no long term future.
I bought the fp to use alongside the sdQH, as I have a number of old lenses that I like. It's a fun camera, but realistically the sensors are not yet ready for use without a shutter. (Sony have a newer sensor in the AI that is much faster, and I expect to see fp models that can work properly with flash in a year or three.)
Don Cox
Sigma fp
Strangefinder
Strangefinder Senior Member • Posts: 1,352
The Quattro makes more sense, I think. Though if you’d like the ISO, Cine etc benefits of Bayer then perhaps check to see if the fp L is much more expensive than the fp in your market as it will realise those lenses at 26mp in APS-C mode (just like an X-Pro3 etc).
B&H (probably also Adorama and Sigma USA) do sell the MC-21 at a substantial discount at least once per year for a few weeks.
If you find that you can justify a new lens afterall, then the I-series 24/35/45/65 are good value and light, as are the Lumix S 50mmF1.8 and the Lumix S 20-60mmF3.5-5.6
“If you're not careful, the newspapers will have you hating the people who are being oppressed, and loving the people who are doing the oppressing.” Malcolm X
“Remember that all through history, there have been tyrants and murderers, and for a time, they seem invincible. But in the end, they always fall. Always.” Gandhi
Scottelly
Scottelly Forum Pro • Posts: 18,026
George
George, what are you hoping to accomplish? Do you want a smaller camera? Do you want to get more resolution in your images? Are you wanting a tilting viewfinder? (I'm guessing that's not high on your priorities list, since you're considering the SD Quattro H.) Do you want to be able to shoot at higher ISO settings, with better results? Do you just want an EVF? Are you looking to increase the speed at which you can shoot?
If you like the Foveon look, you are probably going to be happier with the SD Quattro H, though I don't think you'll be able to get one new now. If you want to be able to get good results shooting at ISO 6400, then I suggest the fp as your solution. I believe the SD Quattro H will give you very similar results to your SD15, though with more resolution. Even at ISO 3200 though, the image quality is pretty horrendous, unless you're shooting in monochrome or converting your images to monochrome. I think of all the Sigma cameras with Foveon sensors to be limited to practical ISO settings from 100-1600, and I almost never go above ISO 200, because I just don't like the noise in my images. I feel the same way about using high ISO settings with other cameras too, but not to the same degree. I have actually shot my Nikon at ISO 6400.
As far as vignetting is concerned, your APS-C lenses will indeed work pretty well on the SD Quattro H, but not so well on an fp. If you get the fp-L though, you'll have enough megapixels that you can crop a lot, and still have a 30 or 40 MP image. Also there is the possibility of using some of the different shooting formats. If you use 21:9 or square format, for example, you may find you'll get very little vignetting at most focal lengths with your lenses.
Scott Barton Kennelly
https://www.bigprintphotos.com/
 Scottelly's gear list:Scottelly's gear list
Sony SLT-A65 Nikon D810 Sigma sd Quattro H Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR Sony DT 18-55mm F3.5-5.6 SAM +27 more
xpatUSA
Scott, what would be "a lot" in this case?
Bearing in mind that even a 30MP image would result from a crop of only 0.707 times the linear dimensions, I'm not sure that cropping 30% off is actually "a lot"?
Admittedly, cropping from FF to APS-C would still get you about 27MP ...
rick decker
With some of these new AI up-sizing products such as Topaz and Photoshop SuperRes, you can blow things up a "lot" and then crop a "whole bunch" Here is one example:
fp 45mm 600x400
Same Image run through PS SuperRes to 12000x8000 and cropped d own to 6000x4000
Some day who knows...one lens shoots all!!
xpatUSA
rick decker wrote:
With some of these new AI up-sizing products such as Topaz and Photoshop SuperRes, you can blow things up "a lot" and then crop a "whole bunch"!
Good point ... computational photography rules, IMHO.
Some day who knows...one lens shoots all !!
That would be the Otus 55mm, I reckon ...
And like all rulers, it can make big mistakes.
Don
Sigma fp
amweber21 Regular Member • Posts: 227
fp 45mm 600x400
I have mixed feelings about what I get out of from these techniques. It often tries to sharpen things that should not be, like the fence behind the riders in your example.
 amweber21's gear list:amweber21's gear list
Sony a7R II Panasonic S1 Sigma fp L Panasonic S 24-105mm F4 Macro OIS Panasonic Lumix S 20-60mm F3.5-5.6 +14 more
xpatUSA
amweber21 wrote:
fp 45mm 600x400
Which is why many of these techniques come with adjustable parameters requiring additional intelligence from the User ...
In Camera raw, like he's used here, it's just a "you get what you get" check box. No parameters are far as I know. Topaz has some control, but it has even more artifacting in my limited experience with it.
Scottelly
Considering an APS-C sized crop would be less than half the image, I'd say that's a lot. I did say he'd ". . . still have a 30 or 40 MP image." I stand by that claim.
rick decker
I have done lots (whole bunch!!:-) of comparisons probably a dozen of so, most of which I have saved,  between Topaz and SR and generally favor SR as having better detail. They are not that far apart.
Good to know.. From what I have done, Adobe seems to be a little better, but maybe because it is less aggressive so it is more subtle. I had tried processing some raws through DXO PureRaw on my last wedding (using a trial), while the natural lighting looked okay (not a huge difference for the huge file size increase) the group and couple shots using flash came out absolutely horrendous! Nothing could have saved them, and again, no control on how it processes. I just editted those as normal. I have noticed it cleans up my M43 cameras in low light pretty well.. But I held off on buying it for now.
OP George1958 Senior Member • Posts: 1,475
Re: MC-21 Sigma SA to L mount thanks for your input and time
Dear all , thank you for your time in replying to my question and your thoughts .
I am primarily a stills shooter and lean toward fine art, mostly plants and some landscape . I do love the foveon look, colours and detail. I have grown used to using base ISO and also having to work with the slower approach.
after reflecting on the various comments I am going to be looking for a Quattro H to work with my current lenses. Appreciate SA mount is not a long term plan but I don’t need that many lenses either, perhaps an additional macro lens such as the 70mm. My relatively fast F1.8 zooms cover most over focal lengths I use and work well with portraits etc.
I remain very interested in the FP but rebuilding a system is expensive and I seriously wonder how much more my photography would benefit? . That is accepting I have never minded being at base ISO with my SD15, or it’s slow operational speed and other quirks .
I have noticed the Quattro H is still on the Sigma UK site as a live product but many retailers do not appear to have any stock. Given I am in the UK I wonder if it’s a brexit effect , lots of other non sigma gear seems to be out of stock?
regards
George
