Case for Sony 200-600
peter826 Contributing Member • Posts: 729
Can anyone suggest a case for the Sony 200-600 that's a little more padded than the bag that comes with it when purchased? I'll be carrying the lens on flights as a personal item. I considered just wrapping it in some bubble wrap and using the bag that comes with, but the bag lacks a strap, ideally I'd carry it over my shoulder. The lens won't fit in my normal carryon with all my other camera stuff.
 peter826's gear list:peter826's gear list
Sigma DP2 Merrill Sony RX1 Sony RX100 VI Sony a7R Sony a6000 +8 more
LenRivers Senior Member • Posts: 3,407
Re: Case for Sony 200-600
The think tank holster 150 I think will work. I personally use the think Tank glass limo backpack to Carry a bit more to make it a functional bag  I can also carry a Monopod!
You could also look at pelican hard cases
personally for travel getting to and from I like either a backpack or a bag with wheels
regardless of what you decide and even if you buy 2-3 options best is to put your gear in and carry it around for a bit. What you see on paper and others opinions may or may not work for you
dfrat
dfrat Regular Member • Posts: 371
Ltgk20 Regular Member • Posts: 264
dfrat wrote:
This is the case I've been using. It's a decent bag for the money. The 200-600 fits very well in. https://www.bhphotovideo.com/c/product/903044-REG/Ape_Case_ACPROLC18_Professional_Large_Lens.html
I'm also using this case and it works well enough.
 Ltgk20's gear list:Ltgk20's gear list
Sony a1 Sony 135mm F2.8 (T4.5) STF Sony FE 55mm F1.8 Sony FE 100-400mm F4.5-5.6 Sony FE 12-24mm F4 +4 more
OP peter826 Contributing Member • Posts: 729
This looks great, thanks!  Unfortunately it appears to be sold out most everywhere I've checked.
Old Pirate Senior Member • Posts: 1,513
I too have the Think Tank 150 and I like it because you can carry the lens hooked to your camera even if you have a teleconverter on it.  You simply reach in, pull it out, and start shooting.
 Old Pirate's gear list:Old Pirate's gear list
Sony a7R IV Sony a1 Sony FE 90mm F2.8 macro Sony 1.4x Teleconverter (2016) Sony FE 70-300mm F4.5-5.6 G OSS +7 more
aSevenArr
aSevenArr Senior Member • Posts: 2,983
I'd simply bubble wrap it and put it in my carry-on personally. The 100-400 GM fits inside my padded insert (with a couple of other lenses) but that 200-600 is far longer.
I do think the 100-400 is far more versatile a lens and has the nicer bokeh.
 aSevenArr's gear list:aSevenArr's gear list
Sony RX100 IV Sony a9 Sony E 10-18mm F4 OSS Sony FE 35mm F2.8 Sony FE 70-200 F4 +13 more
I had been using a Sigma 150-600 with an MC-11 as my long telephoto.  I also carry the Sony 70-300.  My use case for the 200-600 is pretty small, I like shooting rising/setting moon photos.
joger
joger Veteran Member • Posts: 7,115
Try the LowePro LP36307 - works fine for me.
A bit tight but fits including tripod foot and lens hood .
_____________________________________
A7R IV - one camera to rule them all
ISO 9000 definition of quality: 'Degree to which a set of inherent characteristic fulfills requirements'
I am the classic “Windows by Day, Mac by Night user'
“The horizon of many people is a circle with zero radius which they call their point of view.” Albert Einstein
"In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move." Douglas Adams
 joger's gear list:joger's gear list
Sony a7R IV Sony FE 135mm F1.8 GM Sony FE 35mm F1.4 GM Sony FE 50mm F1.2 GM Sony FE 14mm F1.8 GM +13 more
Thank you.  That one was in stock, so I ordered it.  I'm traveling with it next week, I'm sure it will be fine.
