EOS M6 Mark II HDMI output to PC monitor (via PC)
Started 4 months ago | Questions
Larry Cunningham
Larry Cunningham Senior Member • Posts: 1,096
I'd like to send the view I see on the LCD screen or EVF of my EOS M6 Mark II to my PC, and thence to my monitor via the camera's HDMI output. I don't want to mess with the video connectors on the back of the monitor (they're limited and difficult to reach). What I'd like to do, if possible, is use an HDMI-to-USB converter like the one below:
BlueAVS Video Capture Card HDMI to USB
to connect the HDMI output of the camera to the PC, then send the "live" image to the monitor.
Will this connector work for this, and will I need any particular application to send the image to the monitor?
The goal behind all this is to  get a big-screen view of what my camera sees to help me focus when I do macro photography. At least at this point, I don't contemplate needing to record video on the PC, I just want to pass the image on to the monitor.
If this approach won't work, is there another, preferably straightforward and not-too-expensive, way to do the same thing?
Larry
 Larry Cunningham's gear list:Larry Cunningham's gear list
Canon EOS M5 Canon EOS M3 Canon EOS M6 II Canon EF 50mm F1.8 II Canon EF-S 17-85mm f/4-5.6 IS USM +18 more
Canon EOS M6
nnowak Veteran Member • Posts: 7,770
Re: EOS M6 Mark II HDMI output to PC monitor (via PC)
Larry
Two thoughts...
I am pretty sure your M6 II supports the Canon EOS Utility software which will allow tethered shooting with a basic USB cable. Alternatively, if you don't want to use the EOS Utility software, I would recommend connecting a spare HDMI cable to your display and bypassing the PC. Adding the USB dongle might introduce some lag to the video feed that would make manual focusing cumbersome.
Here is a link to the EOS Utility for the M6 II
https://www.usa.canon.com/internet/portal/us/home/support/details/cameras/eos-dslr-and-mirrorless-cameras/mirrorless/eos-m6-mark-ii?subtab=downloads-software
Larry Cunningham
OP Larry Cunningham Senior Member • Posts: 1,096
nnowak wrote:
Two thoughts...
Thanks! I'll admit to a rather strong, and longstanding, bias against software developed by any hardware manufacturer. It tends to be, well, clunky and buggy and annoying. I had downloaded Canon EOS Utility years ago (and have since upgraded to the latest and greatest), but once again felt it wasn't worth fiddling with.
After reading your suggestion, I fired it up and attached my M6 Mk II using a USB cable (I also got it to work using a wireless connection, but figured the hardwired connection would be more reliable). It works pretty much as advertised, so I'll try using what came with the Canon package before investing any more time or money.
The one detail that disappointed me was that, with the camera set to manual focus, the live view on my monitor doesn't include the Focus Peaking I see through the EVF. The combination of big screen and focus peaking would have made focusing on macro subjects much easier.
Larry
