BG Stand For Seemless
c h u n k
c h u n k Senior Member • Posts: 1,693
Looking for semi portable stand that can handle seemless paper. Will be for full length and headshots. Doesnt really need to be wider than for like groups of 3, maybe 4. Ideal would be if it could extend for groups but be able to be smaller. I may just get something that can handle individuals for now, depending on cost differences. Looking at Savage portastand, but that will be limiting for groups.
1) Needs to be somewhat portable
2) Needs to be sturdy and safe!!
3) cost effectiveness a plus
4) adjustable widths a plus
All the bg stands I see on BH etc doesnt really specify what it can safely be used for.
Some of my photos here: https://flic.kr/ps/2i6XL3
“You're off to Great Places! Today is your day! Your mountain is waiting, So... get on your way!” --Dr. Seuss
 c h u n k's gear list:c h u n k's gear list
Canon EOS 70D Canon 6D Mark II Canon EF 85mm F1.8 USM Canon EF 100mm f/2.8 Macro USM Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) +7 more
John Spaar
John Spaar Senior Member • Posts: 1,010
Re: BG Stand For Seemless
I used an SP systems portable stand. Using three sections to 10ft wide. Used with a white paper roll for years without a hitch. Breaks down in about 10 minutes into a nice carrying case. (just hang on to the Allen wrench)
A purist at heart to protect the art
 John Spaar's gear list:John Spaar's gear list
Canon EOS 50D Canon EOS 7D Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon 6D Mark II +11 more
Gato Amarillo Veteran Member • Posts: 8,063
This looks to be the same stand I use, though mine is near 20 years old so I cannot guaranty this is the same quality. It amounts to a pair of fairly solid light stands and a four-section crossbar --
https://www.bhphotovideo.com/c/product/1495040-REG/dot_line_rs_2016_rps_portable_backgound_stand.html
You can  use 2, 3 or all four of the crossbar sections depending on the width of your seamless.
There are other brands that are equally good, I'm sure. I would look for a set that has a normal light stand spigot on the stands for a little extra versatility.
One caution -- do not leave seamless on this type of stand when not in use. It will sag and create permanent ripples in the paper. Take it down and if possible store standing on end.
Gato
tcphoto1
tcphoto1 Senior Member • Posts: 1,256
I gave up on dedicated background systems years ago, I simply use two C Stands w/Hollywood arms and a couple set weights. I use C Stands much more than seamless support so I always have a few on set even if I'm on location.
 tcphoto1's gear list:tcphoto1's gear list
Canon EOS 5D Mark IV Canon EF 50mm f/1.2L USM Canon EF 70-200mm f/2.8L IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 16-35mm F4L IS USM +10 more
Rico Tudor Contributing Member • Posts: 940
I'm the same way in part: two MSE Beefy Baby light stands. I do use the Manfrotto telescoping crossbar that drops over the baby pins. Add a few pony clamps and this b/g rig is secure, effective, and portable enough.
Canon, Nikon, Contax RTS, Leica M, Sony, Profoto
c h u n k
OP c h u n k Senior Member • Posts: 1,693
Was actually looking at similar solution. Thinking of the Flashpoint cstand/grip arm. Was worried bc the grip arms are only 40"ish but I guess they dont have to come together. Def much heavier than the porta stand option though.
