Panasonic 30mm f2.8 Macro vs 42.5mm f1.7, Which one would you keep?
Started Jun 1, 2021 | Questions
bs1946
bs1946 Veteran Member • Posts: 7,780
When I returned to MFT last December, after a long absence, I went on an insane buying GAS fueled spree. In May, I finally got control and started selling off a lot of what I bought. Now I'm down to my GX9 plus the Olympus 12mm f2 and 17mm f1.8, along with Lumix 30mm f2.8 Macro, and the Lumix 42.5mm f1.7. But, I want to get down to a three lens kit that I will use regularly with nothing sitting on the shelf gathering dust.
The two Olympus lenses are my favorites and most used, so they aren't going anywhere. That brings me to the subject of this post; between the 30mm f2.8 Macro and the 42.5 f1.7 I have to decide which one I want to keep and which one to sell and I am struggling to make a choice.
  • No doubt the best use for the 42.5 is portraits, but I haven't shot a portrait in several years and don't expect to suddenly start now.
  • Because of the Covid lockdown, I bought the 30mm to get into macro in my wife's garden. But the weather has been terrible here this year, I haven't done any macro, and now that the Covid restrictions are starting to lift, I just don't see myself out in the garden hunting down little bugs or doing flower portraits.
  • My photography has focused around landscapes, historic homes and other buildings, plus travel, which includes some street photography. Thanks to Covid, there has been zero travel over the past year except to the surrounding towns but hopefully I will get in some extended travel over the summer now that the restrictions are lifting.
So I would appreciate any thoughts on which one of these would be a better choice as a general purpose third lens. Thanks.
Bill S.
www.flickr.com/photos/wrs1946
instagram.com@billschaffel
“Sharpness is a bourgeois concept”
– Henri Cartier-Bresson -
 bs1946's gear list:bs1946's gear list
Panasonic Lumix DC-GX9 Panasonic 20mm F1.7 II Panasonic Lumix G 14mm F2.5 II ASPH Panasonic 12-60mm F3.5-5.6 OIS Apple iPhone 12 Pro Max
Panasonic Lumix DC-GX9 Panasonic Lumix G 42.5mm F1.7 Panasonic Lumix G Macro 30mm F2.8
jalywol
jalywol Forum Pro • Posts: 12,302
Re: Panasonic 30mm f2.8 Macro vs 42.5mm f1.7, Which one would you keep?
Well, I would suspect it would depend on whether or not you are going to be doing any low light work. If you are, keep the 42.5.  If not, keep the macro.
I did pretty much the same thing; added in a 42.5mm f1.7 lens this winter since I have no other fast native lenses.  The 42.5mm has a pretty decent close minimum focus distance, so I knew I would find it versatile in close up situations.  However, I rarely shoot that focal length, so it was a toss up as to whether I would use it much, even with the close focusing ability.
For me, I would keep the macro (I have the Oly 30mm version, and I would never sell that, as I do use it for macro work), and sell the 42.5mm.  But, you need to figure out whether low light capability or the wider, slower, but true macro, is what you prefer, based on what you think you will be needing going forward.
-J
Felice62 Veteran Member • Posts: 5,079
Given the close focus abilities of the 30/2.8 if i had to choose it'll be the one I'd keep
I have it and love it. But i do also like my oly 45/1.8...
If only closed minds came with closed mouths..
 Felice62's gear list:Felice62's gear list
Olympus Stylus 1 Olympus Stylus Tough TG-850 iHS Olympus Tough TG-3 Panasonic ZS100 Olympus OM-D E-M5 +36 more
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
You have no redundancy here, and a nice sequence of prime focal lengths.
42.5 is also a good low light lens, and has OIS.
The 30/2.8 is larger and slower, and you're not fond of macro.
I'd replace the 30/2.8 with the much smaller 25/1.8.
(my prime sequence is 7.5/2, 15/1.7, 25/1.8, 42.5/1.7)
My 1.2kg small kit contains these 4 primes, plus the 12-32 and the 45-150.
Cheers
Eric
(Feel free to edit and repost any image that I have posted in a DPR, as long as you identify me as the original poster)
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +73 more
Sa7724473 Senior Member • Posts: 2,029
5
Only get the Macro lens if you had proper macro needs, which seems you dont.
The 42.5 f1.7 is a good general purpose lens, not optimised purely for portraits. Get the 42.5 f1.7 + an Olympus MCON-P02 macro adapter. I have one, it fits and works on that particular Penny lens. Will be more than good enough to satisfy any casual pseudo-macro curiosities: https://www.getolympus.com/ca/en/macro-converter-mcon-p02.html
Bassaidai Contributing Member • Posts: 801
SInce you have no lens giving you a decent tele photo range I'd keep the 42,5mm and drop the 30/2.8 macro. Get some cheap and light extension rings to enable closeup shots (macro-ish) with the lenses you've got.
Bass
If things appear to good to be true - they're usually neither of both.
 Bassaidai's gear list:Bassaidai's gear list
Panasonic GH5 Panasonic Lumix DC-G9 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +8 more
brentbrent Veteran Member • Posts: 5,766
Well, they both have OIS.  All Panasonic lenses (zooms or primes) that have a focal length greater than 25mm have OIS.
But I agree that if the OP is not going to do macro photography, the 42.5 would likely be more useful.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
Vermont3133
Vermont3133 Senior Member • Posts: 1,099
All points to something wider than the 4.2.5
And having the macro option is always good...you never know!
 Vermont3133's gear list:Vermont3133's gear list
Olympus E-M5 II Fujifilm X-T2 Olympus E-M1 II Fujifilm X-T4 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +7 more
sbszine
sbszine Contributing Member • Posts: 806
Sell them both and get the 60 / 2.8
That way you keep both the macro and the tele / portrait capability.
 sbszine's gear list:sbszine's gear list
Olympus Tough TG-2 Olympus OM-D E-M5 Olympus PEN E-PM2 Olympus E-M5 III Panasonic Lumix G 14mm F2.5 ASPH +8 more
john isaacs Veteran Member • Posts: 8,444
Clearly, you should sell both the 30mm and 42.5mm, as you have no need for either.
Sell those lenses, buy a second GX9, and just leave each lens on a body...no switching of lenses.  And you can carry both in nearly the same space as you would need for one body and three lenses.
Done.
DrHook59
DrHook59 Contributing Member • Posts: 856
I have both these lenses and the 30mm is by far and away more useful to me than the 42.5mm. I rarely use the latter unless I know I am going into poor light and might meet some faces. I find the 30mm a great general purpose walkabout lens (I call it my 'nifty sixty', good for street, landscape, buildings, cars, people and so on. Plus it has not just a macro capability, but the ability to take photos of anything at any distance - food, product, slides, flowers, and all of that stuff you can never get close to. And then it does macro too.
Macro photos from the 42.5mm with either extension tubes or an achromat are awkward in comparison to the macro capabilities of the 30mm. Optically I see little difference between them in good light and I like the way both lenses are finished. I do dislike the 37mm filter size of the 42.5mm. It wears a step-up ring as a result which is not a hassle.
I have some pics hereif you need any proof of what you can do with the 30mm. I hope you are happy with whatever you decide, of course. It's all good.
_____________________________________
Some of the coolest things in life are really, really small.
https://www.flickr.com/photos/roddyhays/
 DrHook59's gear list:DrHook59's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS Olympus M.Zuiko Digital ED 60mm F2.8 Macro Sigma 60mm F2.8 DN Art Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +2 more
(unknown member) Contributing Member • Posts: 726
The macro is the one I kept.
BBbuilder467 Veteran Member • Posts: 7,057
I bought the 30mm f/2.8 specifically for flowers and nature close-ups. It's perfect for that if you don't go much beyond 1:2, but 1:1 is nearly impossible in real world, so it's not much good for insects.
I use it as an all-purpose prime in place of a 25mm f/1.7, and it's just long enough for casual portraits and short enough for landscapes. It works well for tabletop photography with a tripod on the table.
I can always find an excuse to use it. I'd never get rid of it, but I do spend about 90% of my time outdoors in nature. I could spend all day in my garden with it.
DrHook59
I politely disagree. I admit it is may not be as convenient as the Oly 60 for macro, but it still takes a decent photo of a fly or two.
Absolutely!
SteveY80 Senior Member • Posts: 2,087
If you do decide to keep the 42.5mm, you could always add an extension tube to your kit for the occasional macro shot. The 42.5mm already focuses pretty close so a cheap set of 10mm+16mm tubes will take it to true macro magnification.
 SteveY80's gear list:SteveY80's gear list
Nikon 1 J1 Fujifilm X-M1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Sony a77 II +1 more
kodachromed Junior Member • Posts: 47
The 30mm F2.8 macro has no problem getting quite close to insects.
 kodachromed's gear list:kodachromed's gear list
Fujifilm X100V Panasonic Lumix DMC-GM5 Fujifilm X-H2 Panasonic Lumix G Macro 30mm F2.8 Fujifilm XF 23mm F2 R WR +2 more
Those are close-ups, not even close to 1:1.  A U.S. Dime is too big to fit in the frame at 1:1. I'm almost touching the subject to reach true 1:1.
JosephScha Veteran Member • Posts: 7,249
I assume you sometimes shoot macro shots and might do so again at some future time.  If I were you, I'd keep the 42.5mm f/1.7 (a very good portrait lens) and buy a set of macro extension tubes, I have Mieke automatic macro tube set (10mm & 16mm) I think about $19 on Amazon.   10mm behind the 42.5mm f/1.7 will give you good magnification.  16mm behind the 42.5mm/f1.7 gives you more magnification (and closer focus).  I have never tried both stacked but 26mm behind the 42.5mm f/1.7 should be incredible.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
Simon97
Simon97 Veteran Member • Posts: 3,444
Sounds like you don't need the 42.5 if you aren't doing portraits. It has other uses, such as when you need to isolate the subject. The short telephoto plus the wide aperture can give you nice background blurring.
Being a macro lens, the 30/2.8 is well corrected and sharp even at non macro distances (not that the 42.5 isn't sharp). It makes a nice lens for copy work plus the focal length is more useful.
 Simon97's gear list:Simon97's gear list
Canon PowerShot ELPH 360 HS Panasonic Lumix DC-G100
Gon Rough Regular Member • Posts: 103
Great Pics.
And it does appear to be a great lens.
R
 Gon Rough's gear list:Gon Rough's gear list
Olympus E-M5 II Olympus E-M1 II Sony a7R III Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 +6 more
