200 dpi vs 300 dpi for best in larger size
Started Mar 30, 2003 | Discussions
Frank Vigil Senior Member • Posts: 2,578
In the February issue of Popular Photography magazine, there is an article on pixels, dpi and optimal printing combinations. Everything made perfect sense and was pretty basic until I got to their chart. In the chart, they imply that (prior to interpolation, essentially) with a photo that is 2560 x 1920 in size, The maximum, photo quality print size at 300 dpi is 8.5 x 6.4 " Yet, at 200 dpi, the maximum, photo quality print size is a much larger, 12.8 x 9.6" I'm confused, I can get a better print in the larger size by using a lower dpi ??
Frank
Whimsy is salvation for a life taken too seriously.
http://www.pbase.com/poetrunner/root
Tricia Veteran Member • Posts: 5,370
Re: 200 dpi vs 300 dpi for best in larger size
The chart is only showing the size print that a 2560x1920 image will give you at each resolution, without software interpolation . If you divide 2560 by 300, you'll get 8.533; 1920 by 300 is 6.4; 2560 by 200 is 12.8; and 1920 divided by 200 is 9.6.
For most non-Epson printers, these are considered the optimal settings because the basic printer resolution is 600 (or 1200) and 300 and 200 are even fractions of that resolution (1/2 and 1/3, respectively) - therefore there is less interpolation used in the printer itself, and the prints have fewer "jaggies" or printer-induced artifacts.
For Epson printers, the basic printer resolution is 720, so the magic numbers are 360 (1/2) and 240 (1/3).
Having said all that, I don't think it's as important as it used to be when printers were lower resolution - it used to make a huge difference with 300 and 360 dpi printers, but it's not something you'll notice with the 1200, 1440, 2880, etc. printers we use today. I think that people who use the dye sub printers that print at 314 dpi can still see the effects if they don't interpolate to that resolution.
Personally, I just pop my images into Qimage and let it handle getting my photos to the proper resolution for printing at every size.
Tricia
Minolta Dimage D7(UG), Epson 2200, PS7, Qimage
