DIY lightweight and easy to attach L-bracket (< 50 g) for small cameras
Started May 29, 2021 | Discussions
jap2020 Junior Member • Posts: 28
5
I would like to share my craft project mentioned in the title.
The starting point was the realization that I was not able to find a convenient L-bracket for my Samsung NX mini for occasional use – especially at an aspired weight below 50 g. Handling of most L-brackets requires a tool and/or subtle fingers.
When I saw a round (!) Arca-Swiss compatible quick release plate (BGNing/FEICHAO 40 round quick release plate), an idea grew. Such plates could be used as knurled screw or nut. They were so inexpensive, that I "imported" some and went to the local hardware store to buy connecting angles of different dimensions. A size of 50 mm x 50 mm x 15 mm was perfect for the NX mini. I drilled two holes for the plates.
The mentioned plates have a short 1/4’’ female thread. So attaching the sideward plate was very easy.
To mount the camera a longer (countersunk) screw is needed. Because their head was bigger than that of the original screw, I had to modify the plate. After that I glued the screw into the plate.
Adding an anti-twist rubber pad as contact surface for the camera is useful.
Now I can quickly attach and remove the L-bracket just by turning the round qr plate.
Of cause it would be nice to have quick release plates optimised for this application.
- plate at the side: more pitches
- plate below camera: better coupling between screw head and plate (glue is suboptimal)
The connecting angles can also be found on the major Internet trading platforms.
Samsung NX mini
