Lunar Eclipse PICS with the EOS Ra, EOS R6 & EOS M6
Started May 29, 2021 | Discussions
Thomas A Anderson Senior Member • Posts: 1,360
Re: To: Mr Anderson
Sittatunga wrote:
That lens came out in December 2008. The EOS 5Dii from a month earlier only offered peripheral illumination correction in camera. The 5Ds which came out seven years later added chromatic aberration correction but no distortion correction in camera. Relying on drastic automatic distortion correction only really came in with mirrorless camera lenses. Another thing is that a lens with a small enough image circle to give missing corners would look pretty horrible through a reflex viewfinder while you can correct that distortion automatically through an EVF. I think Marco's problem with that lens on the EOS Ra had a different cause.
Hmmmm….well don’t different wavelengths of light have different refractive indexes that would then require the Ra mod to reposition the sensor or adjust the lens focus differently?  Maybe the filter itself can’t handle the angle of incidence of incoming light and causes it to miss the microlenses?  Anyway, seems like there must be something about the Astro model if the lens is that old.  Either way, I’m sure he’ll figure it out.
 Thomas A Anderson's gear list:Thomas A Anderson's gear list
Canon EOS R
gianstam Senior Member • Posts: 1,072
Re: Lunar Eclipse PICS with the EOS Ra, EOS R6 & EOS M6
Thanks.
(A bit of contrast and saturation)
Marco Nero wrote:
I have no objection. Nice edit, btw.
 gianstam's gear list:gianstam's gear list
Nikon Coolpix 990 Samsung TL500 Canon PowerShot G1 X Pentax K20D
Marco Nero
OP Marco Nero Veteran Member • Posts: 7,582
Re: EOS Ra + Vignetting with the EF 24mmL lens
Thomas A Anderson wrote:
The black area outside of an image circle isn't attributed to vignetting. The EF 24 f/1.4L II was designed for digital bodies that have distortion correction, which means that like most wide angle lenses, very similar to those on fixed lens cameras, it is designed to actually not fully cover the sensor in the corner but instead relying on correction to crop and then correct the extreme distortion around the edges.
Don't worry about a solution with this combo, even Canon is mystified.  The F 24mm wasn't designed with Peripheral Illumination correction in mind since there were no capable cameras with this feature available at the time of release. But they were developing upcoming cameras that were designed to reduce corner vignetting with Light Falloff. The two models that did possess this feature came out a short while later but everyone who owned earlier models of DSLR and wanted the successor Mk 2 version of this lens snapped them up in such larger numbers that there were delays on obtaining mode. No notable complaints were observed beyond 'soft vignetting' in the corners when shooting wide open... and that was entirely expected due to the nature of the lens.
So like the G1X and G7 X, if you go find a viewer that will show the uncorrected RAW file you'll see black corners on the wide angle end. MOST modern digital wide angle lenses are designed with image circles that don't fully cover the sensor.
Most of the Compact cameras with 1" and 1.5" sensors have vignetting when certain focal lengths are used with RAW settings... which is why Canon avoided releasing models with super-wide FOV. Vignette refers to both Hard and Soft Vignetting. Hard vignetting is where the light is physically blocked (mechanically) from reaching the edges of the sensor. Light Falloff (soft vignetting) is a characteristic of lens character and lens design... where the thickness of the lens varies, especially with wide-aperture, wide FOV lenses. The black corners from the EOS Ra are indeed defined as 'vignette', as noted by DXO Mark when they assessed this lens... which Canon described as their "best performing and best built 24mm autofocus lens". It was considered to be "optically excellent" upon release. In most ways, this is a true statement. It's a lens that has always been in very high demand by professional photographers and the higher price bracket had most regular consumers looking at other alternatives. This lens was developed and released into a market a month before introducing any cameras that were capable of applying Peripheral Illumination Correction. The problems didn't surface until the release of the EOS 5D Mk IV... which came out in September 2016.
TIMELINE.
2008 - Canon EF 24mm f/1.4L II USM released. (September)
2008 - Peripheral Illumination Correction announced. (November)
2012 - Chromatic Aberration Correction introduced.
2016 - Diffraction Correction introduced.
2016 - Canon EOS 5D Mk IV released (September).
But as you can see from this screen-capture I took last year (which was posted in 2010), this is indeed a problem with this lens but ONLY on certain camera bodies... The only two that come to mind are the EOS 5D IV and the EOS Ra. In both instances this vignette is Hard (physical) but no reason has yet been offered by Canon. Upon contacting Canon, they suggested the use of a lens adapter might be the only possible reason that came to mind. My communications with Canon Europe and Canon International (Canon Global) were bounced around within the company, only to be met with bewilderment. This isn't an issue about the sensor being seated a millimeter too deep... this is something quite unexpected and nobody seems to have an answer. What is equally baffling is that this is not an issue on the EOS R6 and it's not an issue with the popular (for Astro) EOS 6D.
Now I spoke with Canon's lens developers who modeled the "new" EF 24mm f/1.4L II USM lens back around 2012 when I was still distantly connected to Canon's local branch (before they moved the service center). It was the best in it's class as of July 2008. There was never any discussion about in-camera corrections simply because this was a new feature that was still being addressed at the time this lens was in development. Whilst APS-C users won't need to concern themselves with lens correction, Full Frame cameras VARY quite considerably with this lens....
Screencap from June 2, 2020 Showing vignette variance with different bodies. The worst performing is the EOS 5D Mk IV - which scored -2.9 EV
As you can see from the screencaps above (from a year ago), the very same lens performed better on numerous other cameras. Even the EOS 6D (which I still have) did not vignette as badly as the EOS 5D Mk4.
Whilst Canon have since introduced lens correction for many of their lenses and on many of their DSLR and mirrorless cameras, back when this lens was released, the options were limited. The original 5D wasn't as gifted - but the 2008 release of the EOS 5D Mk II and EOS 50D is what introduced Peripheral Illumination Correction to correct for vignetting (which includes 'light falloff' and 'corner shading' within the definition). Things didn't really improve until 2012 when the EOS 1D X and EOS 5D Mk III were released.
The answer for the EOS Ra with this lens is to either crop the images in-Camera or to crop them in the computer at home. The in-camera crop may reduce the 30MP to 11MP, which would be excessive and undesirable. Tests made without the lens hood and without any filters were attempted and offered no change. The problem remains unsolved by members of this forum (we had a monster thread on this last year) and even by Canon themselves. I'm told the EOS Ra was discontinued recently, which is in line with Canon's past Astro models only being available for a short time. This is also a way for Canon to wash their hands and wait another 10 years before releasing an alternative.
Unless used on the EOS 5D Mk IV (or the now discontinued EOS Ra), there's no problem with this lens at all and it continues to perform superbly.
Marco Nero.
 Marco Nero's gear list:Marco Nero's gear list
Canon EOS M6 Canon EOS Ra Canon EOS R6 Canon EF-M 32mm F1.4 Canon RF 85mm F1.2L USM +20 more
Sounds like quite a mess that Canon wasn't anticipating with the Ra.  As was pointed out elsewhere as well, the lens is older than I thought....shocked that Canon hasn't updated it since 2008.  Anyway, that sucks.  Maybe its just one of those things that has no solution and would take a team of scientists to figure out.
Canon EOS R
Marco Nero
Re: Astro modded Canon cameras, future lenses...
Canon didn't stop production due to a fault, they did so because these Modified cameras for astrophotography are a "Limited Edition/Special Edition" model.  It's hard to believe it's been over a year and a half since release of the Ra.  Most stores won't stock them since they have to pay for their stock in advance - so they call out to the Canon warehouse when customers request one (it's classified as a "special order" in most countries) and Canon lets them know how many are on hand.  I believe Canon Australia was only issued between 5-10 units during the 2020 pandemic period.  Canon's past Modified Cameras were only available for about a year before discontinuation and were released in 5 and 9 year intervals. So there's a lot of unhappy people out there right now who waited too long to obtain one.  Admittedly, the high price was influential.  If you can live without the 30x magnification (which is very, very useful), an EOS R or RP can be modified as a more affordable alternative.
Past Canon Modified Digital cameras for Astrophotography were:
* EOS 20Da - [APS-C] - June 2005.
* EOS 60Da - [APS-C] - August 2010.
* EOS Ra - [Full Frame] - November 2019 (incorrectly listed here as Nov 2018)
The two features the Ra has that are different to the regular EOS R camera are:
* 30x Magnification on the LCD.
* Factory Modified Infra Red Sensor.
The two issues with the EOS Ra camera are:
* Odd vignetting with the EF 24mm f/1.4L II Lens (at least on mine).
* Flare at the surface layer of the sensor with bright subjects with wide apertures.
Considering that many professional telescopes with custom built sensors (some of them in the many millions of dollars in price) produce far worse flare that is usually uncorrectable, I don't have an issue with this at all.
The EF 24mm f/1.4L II USM lens is one of Canon's best Primes and was one of the first remodels of previous essential L-series lenses.  Even today, Canon doesn't have anything that offers a suitable alternative and the image quality is simply gorgeous.  I just went through my samples-folder (put together before buying this lens) and some of the images are breathtaking. It was also my favorite lens on the EOS M for this reason.  Most 2008/2009+ lenses are considered pinnacle technology lenses. This particular one has Canon's UD glass and high precision GMo Aspheric elements for correcting CA. But it also has a unique defocus (specifically bokeh) effect due to the diaphragm design. Yet less distortion than Leica was offering. Though not specifically mentioned on the brochures (which is strange), this lens also has SWC (Sub-Wavelength Coatings) to better minimize ghosting. Diffraction spikes from this lens are great with smaller apertures and it's one of the few Full Frame lenses to perform nicely on APS-C cameras.
Sigma immediately reverse-engineered it to offer up a cheaper version which had slightly more correction on coma but was plagued with AF problems that annoyed owners. But the Canon was suitably expensive for years and that's why so few enthusiasts and hobbyists bought it. It's mainly found in the kit of professionals for this reason alone. But the closeup ability and overall performance in the hands of journalists, landscapers and produce photographers (especially car enthusiasts) is what caught my attention.
I believe that there's an RF 24mm version in the works but I'm torn between using that or adopting the upcoming RF 35mm lens (which may yet be an f/1.2L lens). These are both a little way off still and either would be very useful. But despite my efforts to identify the cause of the hard vignetting from this lens on the EOS Ra, I'm no closer to an answer. My best guess is that there's a unique aspect to this specific lens where just a millimeter or so in tolerance differences is enough to cause an imperfect image projection onto the sensor. Neither my lens not my camera have been subject to abuse.
I think Canon knows that the 35mm focal length (on FF cameras) is highly desirable for journos, travelers etc so they'll likely earmark that one for release first.  It probably won't vignette on the Ra but the new lens construction methods (ie coma reduction, syntheric fluorite UD elements, optical coatings and flange distance etc) ought to add some benefits for Astro work.  For everyone else (that doesn't do astro), the RF 35mm ought to have BR optics technology to match the EF 35mm f/1.4L Mk II version, which is a magnificently sharp lens.
Marco Nero.
