K1 II and Best cameras for landscape photography in 2021 article
Started May 28, 2021 | Discussions
Phil A Martin
Phil A Martin Veteran Member • Posts: 8,363
Re: K1 II and Best cameras for landscape photography in 2021 article
PentUp wrote:
egk4260 wrote:
Phil A Martin wrote:
DuncanM1 wrote:.........
And noting the weakness of Nikon AF and dismissing it as not relevant to landscape, whilst downgrading Pentax because of the AF? There is no logical explanation for this..........
As I read it your perceptions seem to differ with what they actually stated:
K1-III: "Limited AF point coverage, Unreliable AF tracking"
"The camera's 33 autofocus points are concentrated toward the center of the frame, and is looking limited by modern standards. Likewise AF tracking lags behind the competition in terms of reliability. The K-1 II can focus in very low light, down to -3EV, but AF points barely light up making it difficult to know what you’re focusing on."
Z7: "Autofocus interface a bit clunky"
"Autofocus performance is generally good, and face/eye AF continues to be improved with firmware updates. The interface isn't as refined as it could be, and you'll have to decide whether to use subject tracking, face detection or a simpler AF area mode, which is automatic on some of its rivals. The results tend to be very good, though."
As I said, I've never had any issues with AF for landscape photography, with any Pentax camera going all the way back to the MZ5n.
I guess you are correct in regards to still focus for landscapes. But, kudos for an exceptionally artful dodge of actually responding to my post. Politics are certainly an option if the photography thing does not work out for you.:-) I narrowed the scope of my query by editing the text. Hope you have been able to enjoy your new camera.
I think that you may be (perhaps deliberately) missing the point of this thread entirely. The group of cameras under discussion are being compared in regards to landscape photography, a subject in which autofocus generally, and AF-Tracking, face/eye AF and subject tracking specifically are somewhat irrelevant.
Exactly
robgendreau Forum Pro • Posts: 10,926
Meh, that article is nothing but a listicle.
I like some of the cameras there, but the analysis of each re landscape shooting is non existent.
Some factors I would have considered important would have included things like weatherproofing; seemed that would merit more than a mere mention. To some GPS is a great feature for landscape. HDR shooting.
And the old "limited lens" canard, which is really quite indefensible since we're talking landscape here, where manual focus is easy.
And what about night shooting? nothing in the list can touch the K-1 cameras, or even their APS-C cousins, for say Milky Way shooting with Astotracer. And with yeah, say a manual lens.
Geez. I think there are problems with their judgments on some of the others as well. In short, not at all helpful as a guide to landscape equipment.
 robgendreau's gear list:robgendreau's gear list
Pentax 645Z
LightBug Senior Member • Posts: 2,818
DuncanM1 wrote:
I downloaded the test images for the K1 II and the Nikon Z7II and the Pentax in pixel shift mode is just completely superior and yet the Nikon gets the nod as best camera? What gives? I can understand that for action shots the Nikon might be better, but for landscape resolution is king and the Pentax is far, far superior.
Which test images did you evaluate? Were they from DPR's studio comparison tool?
Pixel shift has its uses in close range still life, macros, landscapes and architecture. I am not convinced it will provide more resolution for subjects that are far away, due to atmosphere/air turbulence in between camera and subject that will smear details.
Joey
 LightBug's gear list:LightBug's gear list
Pentax 645Z Pentax Q-S1 Pentax KP Ricoh Theta V Pentax smc DA 15mm F4 ED AL Limited +19 more
miles green
miles green Veteran Member • Posts: 7,827
I haven't used the Z7 but have a K1ii. I do use pixel-shift for landscapes when i take a tripod, and there is a big difference imho.
Also Pentax ergonomics and landscape features are great for landscapes, especially at night.
  • Leds illuminate the body so you can find your way aroud without using your phone
  • you can adjust the screen illumination so you don't destroy your night vision. You even have "red mode"
  • the screen articulation is awesome
  • you have pixel shift
  • you have astro-tracer
  • you have build quality and weather sealing
  • and horizon correction,
  • and composition adjustment (shift)
it's a long list of features that set the Pentax K1ii apart. Analyzing the sensor output by doing a "fair" comparison (ie not using any of the above features) doesn't cut it for me.
I tried to shoot the night sky with a friend's Fuji once... it has a very capable sensor and good lenses, but it felt like i was using a spoon to cut my steak.
Miles Green
Pentaxian since 1997!
Corfu, Greece
N.B. All my images are protected by Copyright
 miles green's gear list:miles green's gear list
Pentax K-1 Pentax K-1 II Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +7 more
miles green
Gary Martin wrote:
All the cameras mentioned are strong contenders, and the reason they chose the Nikon is simple: they prefer the DR advantage of an ISO64 setting over the value of pixel-shift. That would be my opinion as well, although the K-1 has more than enough dynamic range for my needs as is. Your Mileage May Vary.
They obviously haven't seen the DR advantage of a pixel-shift image, which is FAR above the DR of ISO 64.
Miles Green
Corfu, Greece
miles green
you're unlikely to run into air turbulence problems until you reach long focals lengths, of 200mm ish about, in my opinion.
Miles Green
Corfu, Greece
Not necessarily.
I've run into problems with much wider lenses on some days. It manifests as those horrid green squigglies all along say a distant horizon line. And it doesn't happen if there's more turbulence, because there's no sharp line, and doesn't happen if the air is clear and still, as in lots of my desert shots. But it can happen, and for me it's more annoying than for things I can more easily fix in post like water and foliage, which often I don't care about being sharp.
I didn't mention it earlier, but even Tony Northrup, no fan of Pentax in general, said the K-1 was maybe the best landscape camera out there. I still agree. And one of the other ones I like, the 5Dsr, didn't even make the list (it does show up in other listicles, just not here).
Pentax 645Z
miles green
Not necessarily.
Sure, if there are large differences in air temperature, is can be seen sooner. I have found that on hot summer days, i will get a sharper shot if i walk the water, rather than shoot over 5 meters of hot sand that is just in front of the water. That said, this is a real phenomenon, not some aberration created by the equipment, so it should be in the picture. I've got lots of sunset images with squigglies!
My point is that air turbulence is an argument against the usefulness of pixel-shift as much as it is against high res sensors and long lenses.  In other words, not a very good one.
I remember that episode.
Miles Green
Corfu, Greece
miles green wrote:
Not necessarily.
Ah, good point. Heat waves in the desert are features, not bugs
Pentax 645Z
