K1 II and Best cameras for landscape photography in 2021 article
Started May 28, 2021 | Discussions
DuncanM1 Contributing Member • Posts: 819
8
I downloaded the test images for the K1 II and the Nikon Z7II and the Pentax in pixel shift mode is just completely superior and yet the Nikon gets the nod as best camera? What gives? I can understand that for action shots the Nikon might be better, but for landscape resolution is king and the Pentax is far, far superior.
Pentax K-1 II
PentUp
PentUp Veteran Member • Posts: 4,188
Re: K1 II and Best cameras for landscape photography in 2021 article
Shh... they might hear you
 PentUp's gear list:PentUp's gear list
Panasonic Lumix DMC-FZ300 Canon G7 X II Pentax K-x Pentax K-5 II Pentax K-50 +12 more
ellover009 Senior Member • Posts: 1,003
Tiny bit more resolution on the Z7 II.
Maybe they don't consider pixel shift a practical application for most people because they won't bother with the extra steps necessary to massage the files.
Maybe they like the handling, or the menu or the lens selection, it's hard to know if they don't elaborate on it.
Only thing I could thing it's better at would be 4k 60fps recording, and possibly better a/f but neither metrics are essential for landscape.
At the price of the Z7 II thou you could get a fuji 50R when it's on sale for a little more, or get a 2nd hand one.
I looked at the studio comparison too. Unfortunately it doesn't offer a tangible expression for landscape because of it's controlled lighting, but I popped in the Sigma sdh, that thing has an unique crispness to it, the 5dsr looks good at base iso, but they get murdered once you increase ISO, and turn in pixel shift on the Pentax.
I'm still waiting for the K1 III, hopefully it will be a substantial upgrade, hopefully Pentax doesn't destroy itself by not being flexible enough.
 ellover009's gear list:ellover009's gear list
Canon EOS 30D Pentax K-1 Canon EF-S 17-55mm f/2.8 IS USM Pentax FA 28-105mm F3.5-5.6
ozdean
ozdean Forum Pro • Posts: 28,665
It depends on the size they are viewing the image; you have to remember when you view at less than 100% either on paper or monitor you are compromising the image.
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-3 Mark III Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 15mm F4 ED AL Limited +14 more
Paul_R_H Senior Member • Posts: 1,166
11
I'm not a great believer in pixel shift. It's great for shooting brick walls when you're using a tripod. But in real life? Harder to justify.
First you need a tripod. Second you need the subject not to move. No trees or vegetation blowing in the wind. No water. Unless you layer the files later and scrub out the relevant areas of three of the shifted images, thus nullifying the pixel shift effect.
People say pixel shift is good for high-ISO images. But again, if you have a tripod and the subject's not moving, just lower the ISO duh.
I've had a k3 ii for years and never used pixel shift except as an experiment the first day I had the camera.
So to me pixel shift isn't a factor in appraising Pentaxes as landscape cameras. There are other advantages, mind – light weight, robustness, huge choice of lenses because MF is fine for landscape, et cetera.
Pixel shift useful for studio at base ISO I guess.
Paul
Phil A Martin
Phil A Martin Veteran Member • Posts: 8,363
5
And noting the weakness of Nikon AF and dismissing it as not relevant to landscape, whilst downgrading Pentax because of the AF? There is no logical explanation for this.
I've been using Pentax cameras for landscape ever since the MZ5n (MZ-S, K20, K5 & KP) and never had issues with AF for landscape and similar static subjects.
Phil A Martin
6
It's also great for shooting still lives, buildings and interiors without moving people and landscape on very still days.
Obviously but most landscape photographers just use tripods as a matter of course.
That is a personal experience and that's fine but remember, it only applies to your choices, other people might well have different requirements and a different experience.
Paul
Yes, by 'studio' at the end of my comment I guess I should have said 'still life'. But I thought this conversation was about landscape. Agree with you on architectural work too. I should have remembered that architecture falls, for many, into the general category of landscape.
Do you mean about the ISO? I might have misunderstood how pixel shift is useful at higher ISO. Didn't mean to be dismissive. Perhaps you would put me straight.
Paul
Paul
JeremieB Senior Member • Posts: 2,041
6
Why wouldn't it be useful for landscape at base ISO, if nothing moves (or even, if some parts move, as there's a mode for this) ?
With PSR you have more DR and better details at any ISO level. Both seem fine for landscape as far as I know.
Paul
 JeremieB's gear list:JeremieB's gear list
Pentax K-70 Pentax K-3 Mark III Pentax smc FA 50mm F1.4 Pentax smc DA 18-55mm F3.5-5.6 AL Pentax smc D-FA 100mm F2.8 Macro WR +9 more
Fotoni Senior Member • Posts: 1,091
Pixel shift does not work with motion
The glory days of Pentax K-1 Mark I in 2018-2019 when they costed around $1300-1500 and pixel shift was a rare feature...now that was a real deal. Nikon D850 price was about double. Then a K-1 Mark II came and now the price is around $1800 with minimal improvements.
Nikon ISO 64 works with motion. It requires 2/3 EV more exposure, but that is rarely a problem with landscapes. There are loads of opportunities to get a successful pixel shift with landscape photography. Just don't do it when it is windy and more than 4-shot pixel shift is becoming risky in many situations. The worst thing what can happen with pixel shift with landscape photography is that you have to mask failed parts with a normal photo parts. Automatic motion compensation in different softwares can do this pretty well, but not always perfectly. Usually you need to see a bit extra trouble to salvage a partially failed pixel shifted photo.
So basically when pixel shifting is successful enough, K-1 wins, but otherwise Nikon D850/Z7 series win. K-1 seems to have a bit edge at ISO 100 vs ISO 100 comparison though. Might help a little, if you need to record motion in lower light landscapes.
But we are forgetting that Nikon Z7 series are pretty d... expensive compared to K-1. If only Pentax decided to go with Mark I instead and keep the old price...it would be even more impressive in this comparison.
 Fotoni's gear list:Fotoni's gear list
Pentax K-1 Pentax FA* 50mm F1.4 SDM AW Canon PowerShot SD4000 IS
Gary Martin
Gary Martin Veteran Member • Posts: 5,301
All the cameras mentioned are strong contenders, and the reason they chose the Nikon is simple: they prefer the DR advantage of an ISO64 setting over the value of pixel-shift. That would be my opinion as well, although the K-1 has more than enough dynamic range for my needs as is. Your Mileage May Vary.
 Gary Martin's gear list:Gary Martin's gear list
Ricoh GR III Pentax K-1 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 56mm F1.2 R +9 more
Mike Arledge Senior Member • Posts: 2,465
Personally, I don’t buy my gear because it makes such or such list. I research the gear, evaluate my needs, see what I can afford and buy accordingly. I owned a K-1, its good. I sold it last weekend because some other stuff fit my needs better. If money were no option, I think the Z-7 would be the way to go for me for landscape, but not much else.
 Mike Arledge's gear list:Mike Arledge's gear list
Nikon Z5 Nikon Z fc Sony a7 IV Canon EF 24-70mm F2.8L II USM Sigma 28mm F1.4 DG HSM +5 more
BryantP Regular Member • Posts: 406
Re: Pixel shift does not work with motion
Fotoni wrote:
"The glory days of Pentax K-1 Mark I in 2018-2019 when they costed around $1300-1500 and pixel shift was a rare feature...now that was a real deal. Nikon D850 price was about double. Then a K-1 Mark II came and now the price is around $1800 with minimal improvements."
A K-1 mk1 at $1300-1500 would be a real deal, however in North America I've never seen a sale price lower that around $1700.  As for the K-1 mk2 its rarely on sale for less than $1900.  A new K-1 at around $1300 would have been very hard to resist.
Bryant P.
Indianapolis, Indiana USA
 BryantP's gear list:BryantP's gear list
Pentax *ist DS Pentax K-5 Nikon D750 Pentax KP Pentax K-3 Mark III +9 more
egk4260 Contributing Member • Posts: 939
As I read it your perceptions seem to differ with what they actually stated:
K1-III: "Limited AF point coverage, Unreliable AF tracking"
"The camera's 33 autofocus points are concentrated toward the center of the frame, and is looking limited by modern standards. Likewise AF tracking lags behind the competition in terms of reliability. The K-1 II can focus in very low light, down to -3EV, but AF points barely light up making it difficult to know what you’re focusing on."
Z7: "Autofocus interface a bit clunky"
"Autofocus performance is generally good, and face/eye AF continues to be improved with firmware updates. The interface isn't as refined as it could be, and you'll have to decide whether to use subject tracking, face detection or a simpler AF area mode, which is automatic on some of its rivals. The results tend to be very good, though."
 egk4260's gear list:egk4260's gear list
Carl Zeiss Apo Sonnar T* 2/135
Phil A Martin
As I said, I've never had any issues with AF for landscape photography, with any Pentax camera going all the way back to the MZ5n.
epfler Regular Member • Posts: 313
The other day I had the comparison directly at hand, and PS would win by far, taken against a shot without. Talking about this one:
https://www.flickr.com/photos/187518201@N02/51175488314/in/album-72157715868735698/
Found the version with PS better already with viewing per 100% in comparison (before upload), there is something in the acuity (not talking about resolution then), which the version without PS would not deliver in this case. Made the difference here for the result being somehow useful vs. not because of missing fine details.
(Btw. RawTherapee, which is used here, has fine support for PS, but normally I try to avoid such amassing of data, which PS brings along.)
The oxen in the rain didn't move during the 4 shots. Talking about stills here.
On different occasion I had by chance taken an image of a train passing by, having forgotten to switch PS off, which was perfect then, as only one of the takes was useful, the other ones where blown-up in wrong timing. With RawTherapee one may ignore the other takes when only one is to survive.
DuncanM1 wrote:.........
And noting the weakness of Nikon AF and dismissing it as not relevant to landscape, whilst downgrading Pentax because of the AF? There is no logical explanation for this..........
I guess you are correct in regards to still focus for landscapes. But, kudos for an exceptionally artful dodge of actually responding to my post. Politics are certainly an option if the photography thing does not work out for you.:-)  I narrowed the scope of my query by editing the text. Hope you have been able to enjoy your new camera.
Let me guess it's more simple than that, journalism is about le jour, views of the day, so it's leaving out underlying phenomenons if those have been lost in coarse of the flow of short-living thoughts of the day.
I'm thinking here of having been for many years a happy user of the Foveon cameras, which makes the point here for the phenomenons, which comes back with pixel shifting, thanks to the vibrating sensor.
The difference is to have one pixel worth of reality with each pixel of the image. Principle of Bayer instead is a principle of guessing in fine detail, which pixel belongs to which colour out of quadruples. Foveon doesn't have this software guessing by principle, so it makes for astonishing fine images, but one pays with not that much sensitivity of the sensor plus slightly reduced dynamics (and Sigma seems for now to have stepped back in continuation, with its new series of cameras).
Maybe better don't expect jour-nalists that much to overlook things beyond of those of the day when scratching at phenomenons for which not a sales instance has invented wording of le jour for how to sell it.
I don't think, this advantage in acuity (to take this word for it, after having each one pixel for one pixel worth of reality) is related to dynamic range. That's for sure a different topic again. Within such acuity instead, advantage should be given in impression of a calm and steady representation, when software guesses for representation of fine details are set aside.
Ok, with the huge waste of resolution which is normal now, this is not much a difference any more. But in times of the 12 Mpix Bayers for sure it was. And still in case of doubt the 3x14 MPix Merrills seem to me to give more acuity than the K3, only K1 looks to me beyond of such guesses now.
PentUp
I think that you may be (perhaps deliberately) missing the point of this thread entirely. The group of cameras under discussion are being compared in regards to landscape photography, a subject in which autofocus generally, and AF-Tracking, face/eye AF and subject tracking specifically are somewhat irrelevant.
Phil A Martin
Pardon me for being on topic but I thought this discussion was about the suitability of Pentax cameras for landscape photography.
