Anyone taken TG-6 deeper than the rated depth of 50 feet?
Started May 27, 2021 | Discussions
mostlyboringphotog Forum Pro • Posts: 10,427
I dive recreationally and mostly around 60 feet depth - not sure if I would take a chance or what...
I left my scraped up trusty TG-4 (used only for snorkeling) on some taxi and trying to decide to replace it with TG-6 (f/2.0, raw) vs Nikon W300 100feet depth rating.
I do have A6300 with housing but it does get cumbersome.
Maybe carrying paralenz is enough in case the kraken shows up or something but it does not have GPS.
Hoping to go on a diving trip and rambling on.
Thanks for any thoughts.
P.S, short of another housing, is there anything that can be done to better the odds for TG-6 surviving 60-70 feet diving. Silicone grease? Pack rice
If I am a paranoid minded, I would think Olympus rates it 50 feet to sell their housing but I am not paranoid - just cheap
 mostlyboringphotog's gear list:mostlyboringphotog's gear list
Panasonic Lumix DMC-GM1 Pentax 645Z Nikon 1 J5 Fujifilm GFX 50R Canon EOS RP
Olympus Tough TG-4 Sony a6300 Sony Cyber-shot DSC-W300
Barmaglot_07 Contributing Member • Posts: 633
Re: Anyone taken TG-6 deeper than the rated depth of 50 feet?
I have seen a testimony from a user who had a bare TG-4 working down to 25m; deeper than that had it started throwing memory card errors, which did not go away until he shallowed up to 15m. At 45m, the display cracked and camera died.
Are you running strobes? If not, a phone housing might be an alternative to a TG-6.
 Barmaglot_07's gear list:Barmaglot_07's gear list
Sony a6300 Canon EF-S 60mm f/2.8 Macro USM Sony E 30mm F3.5 Macro Sony E 18-200mm F3.5-6.3 OSS LE Sony E 10-18mm F4 OSS +5 more
kelpdiver Veteran Member • Posts: 5,564
The only coolpix I've seen was abandoned (and flooded) in the sand.   You don't see the UW shops selling them.   But is that for a reason, or just that Olympus has much deeper history in our niche?
so is the question motivated more about the potential waste of $300 versus the slight increase in bulk that the housing represents?
The problem i see with all of the models in this class is the tiny doors.   It's harder to have a bullet proof oring when it's doing a lot of tiny 90 degree angles, versus one big square.   You have to be very fastidious about greasing it to the right level, not getting tiny hairs or grit in, and eventually about changing it.   Or else.
The housing also should make it less negative buoyant- I like the camera to be just slightly negative so it was stay down, but not so much that it crashes into things.
Though I'm not a super fan of the brand. Sealife's Micro 3 is a sealed camera with an internal battery and 64gb card.   Maybe worthwhile for your situation.
To your main questions-
yes, there is some leeway in ratings, and as noted, the first thing that happens is you can't push the buttons.   If you honestly stick to 70 or less, I suspect you could last a long while.
but...if you're diving down aggressively, or big wave action above, the dynamic pressure can be substantially higher than what a static 50ft of pressure represents.   That's why watches that say depth resistant to 50M don't work for diving.
What can you do to improve your odds?   Not much on the prep side.   Just remember that extra silicon lube is usually counterproductive.   Keep it on a secure lanyard without too much free play - so it doesn't bounce around at max depth and bang into anything (or worse, fall 20ft below).   The post dive fresh water rinse keeps salt crystals from forming along the seal points.
OP mostlyboringphotog Forum Pro • Posts: 10,427
Re: Anyone taken TG-6 deeper ... thanks!!
Thanks to both of you - I needed to hear what I kinda knew already
bartjeej Regular Member • Posts: 416
I just took an aging TG-2 (also rated for 15m / 50ft) down to 18m / 60ft last week, and it worked well. Gave a depth warning but all the buttions functioned as they should.
Relative pressure changes between 50 and 60 / 70 feet are not awfully great so if the opportunities are special enough I'd personally risk it.
Not shooting raw on the TG-2 was a PITA for white balance though, its underwater WB settings are more appropriate for snorkeling. Would've loved to have a TG-6 available, also for the slightly less cramped button layout (zoom rocker on top rather than on the back).
