Concert videography: GH4 vs GH5 vs GH5s? And lens recommendation?
Started May 25, 2021 | Discussions
rumiates New Member • Posts: 22
Hello,
I shoot live classical music concert videos, and am looking at these three Panasonics. I could use advice as to whether the price jump from GH4 to GH5 would be worth it (or the GH5s)? The advantages I read about don't seem particularly relevant for my own work.  A few notes:
- my camera is always mounted on a tripod
- the stage is always well lit.
- there is no movement on stage. I don't need to re-focus once the shoot has begun.
I am looking for great dynamic range and sharpness, with 4K shooting. I currently shoot on an FZ2500 and am looking to upgrade the quality.
ALSO - I would love recommendations for one good zoom lens to obtain with any of these cameras.
Thank you!
 rumiates's gear list:rumiates's gear list
Pentax K-50
Panasonic FZ2500 Panasonic GH5 Panasonic GH5S Panasonic Lumix DMC-GH4
sbszine
sbszine Contributing Member • Posts: 806
Re: Concert videography: GH4 vs GH5 vs GH5s? And lens recommendation?
The GH5s probably suits your use case best (tripod, manual focus, best 4K IQ).
 sbszine's gear list:sbszine's gear list
Olympus Tough TG-2 Olympus OM-D E-M5 Olympus PEN E-PM2 Olympus E-M5 III Panasonic Lumix G 14mm F2.5 ASPH +8 more
Sranang Boi Senior Member • Posts: 2,860
You might wish to add the GH5 MKII and G9 to that list.
Lens wise, it all depends on how long a range you need. The ones to consider could be:
10-25mm f1.7
PL 12-60mm f2.8/4.0
35-100mm f2.8
50-200mm f2.8.4.0
I only have the 12-60mm and 35-100mm from that list, and it works quite well for me. They don't lose focus when zooming in or out. For when I need the best possible shutter speed to avoid video lag I use the 15mm, 25mm, and 42.5mm, which are f1.7.
 Sranang Boi's gear list:Sranang Boi's gear list
Panasonic Lumix DC-FZ1000 II Panasonic Lumix DMC-GX8 Panasonic G90 Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH +1 more
pannumon Veteran Member • Posts: 4,130
G7, G85, GH4, GH5
Are you going to do post processing to maximize the dynamic range, i.e. shoot with log profile? If yes, then I recommend at least GH4R (or GH4 with vlog upgrade).
EU version of GH4 has 30min recording limit, but GH4R does not have that limit. GH4 with vlog update still has that limit. Versions sold outside the EU should not have the 30min limit.
GH5 is of course better and does not have these limits, but is much more expensive. GH5s is even better in terms of image quality and I believe dynamic range.
You could also get the little sister of GH5, the G85. It does not support VLOG, and has less professional features than GH5. In Europe the camera is sold as G80 and G81, and these cameras have 30min recording limitation, but G85 does not have this limit.
Cheaper still is the little sister of GH4, the G7. It has 30min limitation, but it can be disabled by entering the service mode.
Considering image quality, there is difference between G7, GH4, G85, GH5 and GH5s, but I don't think most of the people could not tell the difference without comparing the footage next to next. There are some footage comparison videos available, such as: https://youtu.be/GHY0VDMbJRk
Considering lenses, what are the focal lengths (and apertures and sensitivity (ISO) values) you have typically been using with your previous camera?
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
Danielvr Veteran Member • Posts: 6,860
Parfocal?
Are you quite sure? If I remember correctly from past discussions, no M43 lenses are truly parfocal (with the possible exception of cinema lenses).
edit: Well, where the PL 12-60mm is concerned, this person agrees with you that it behaves parfocal: https://www.dpreview.com/forums/post/63286508
 Danielvr's gear list:Danielvr's gear list
Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Carl Zeiss Planar T* 1,4/50 Panasonic 20mm F1.7 II +2 more
(unknown member) Contributing Member • Posts: 726
I suggest a pair of GH5.
One with a static wide shot plus stereo room mic. Another for telephoto shots of section/soloists. Shoot in 4K. Cut between the two in post.
GH5s is good too, but the IBIS in GH5 makes it useful for occasions when hand held work is desired. GH4 can do the job, but will split long recording files into 4GB (if I remember correctly) sections that need to be joined in post.
Pass on variable aperture zooms . Not good for video. 12-35mm f/2.8 and 35-100 f/2.8 would do well if the light is constant. Even better the 10-25mm f/1.7 and 42.5mm f/1.2.
What about audio? Can you get a feed from a sound mixer? The XLR1 accessory is essential.
Also consider power. Battery grip plus AC/DC converter? You will want a steady source of power.
I would not depend on any zoom lenses to be par-focal. The Sigma 18-35 came closest in my experience. And do not rely on C-AF.
Don’t bother fooling around with LOG profiles until you have had a lot of time to experiment and practice. I would go with standard profile with reduced highlights and contrast to start. White balance is most critical. Use a proper target to measure color temperature. Not auto!
Michael Meissner
Michael Meissner Forum Pro • Posts: 28,013
I was going to say add the newly announced GH5 MKII.  However for a concert, I would suspect that you don't want the G9 as it can't record more than 30 minutes of continuous video.
Between the GH5 and the GH5s, the GH5s drops IBIS stablization (which you don't need on a tripod), but it adds higher ISO sensitivity.  It depends on how dark the concert hall is.  Note, the GH5 is more suited towards both photo stills and video, while the GH5s is more tuned to just video.
10-25mm f1.7
PL 12-60mm f2.8/4.0
35-100mm f2.8
50-200mm f2.8.4.0
Panasonic also has a 12-35mm f/2.8 lens that would be in between the 10-25mm f/1.7 lens and the Panasonic 12-60mm f/2.8-4 lenses in terms of low light behavior.  Plus there are a slew of Olympus lenses as well.
There is a newly announced 25-50mm f/1.7 lens that was just announced.
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus TG-5 Olympus E-M5 III OM-1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
Interceptor121 Veteran Member • Posts: 8,691
How far are you and do you know the focal length you need?
If the stage is well lit there won't be significant differences between GH5 and s
But a good lens makes all the difference and if you need a zoom this complicates matters further
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
Mr Giggles Contributing Member • Posts: 950
the GH5S .... hands down
its an absolute monster
if anyone challenges me on this lets hear your first hand experience -not just something you read on line and now think you are an expert on
Michael Meissner
Re: G7, G85, GH4, GH5
Note, the G85 is a 4 year old camera. I own the G85 and use it for video.  One downside is it does not have a headphone jack so you can monitor the sound as it is being recorded.  I lost about 13 minutes of sound from a show I was recording because I didn't realize the microphone wasn't plugged in correctly (since I didn't monitor the sound).
There is now a replacement for it: G90/G95 which uses the 20mp sensor.  It has a headphone jack and no video record limit even in the G90 European version.  However, the G95 in the USA comes bundled with a lens you may not want for low light settings.  Also unfortunately, the G90/G95 has a heavier crop of the lenses when shooting in 4K mode (1.26x vs. 1.1x for the G80/G81/G85 vs. none for the GH5/G9/etc.).
The G85 being a middle camera, it often doesn't get firmware updates to add features like you see in the high end models (GH5, GH5s, G9).
If you are buying used, consider with todays announcement of the GH5 mark II and notification that the GH6 will be announced within the year, there may more GH5's on the used mark as people want/need to upgrade to the current best.
Audio levels can be monitored on the screen, but of course this is not the same thing.
This happens very easily for various reasons: mic is not properly plugged in, mic is not on, battery is empty (because microphone accidentally was turned on in the bag; Rode Stereo VideoMic is especially annoying in this sense: I store the 9V battery in reverse position inside the mic to prevent this happening).
I consider two devices recording audio as a must. An external audio recorder with built-in microphones is a good backup solution, and often it can be placed closer to the subject. Another solution is one or two more cameras. This also gives plenty of other benefits.
G90 may be a good choice, if the price is right. However, I expect that a used GH4 is cheaper than a new G90. Then again, new is new, and it may be possible to acquire a second hand G90 as well.
ivan bayu Regular Member • Posts: 380
rumiates wrote:
Hello,
Thank you!
if you have the money, then get the gh5s. it's a champ if you know to handle it properly. and if you want a another good performer you could also get the gh5 or the box that many olympus user the other side booing about, the bgh1 (you'll need to buy many addons, but it is worth for the quality that you'll get).
all of them got no limit to record, as long as your storage not full or your battery not depleted...
for the lens, i want to recommend you the panasonic 10-25mm f1.7, it's quite expensive, but i dunno about the FL that you need for the concert shoot and i quite don't care about any other m43 lens. just because i despise fully with passion any lens that focus by wire, the only zoom lens suite for my work better from m43 realm was the panasonic 10-25mm f1.7, and i always adapting lens from other mount system.
Re: Parfocal?
yes, that pl 12-60mm f2.8-4 is parfocal. also the 12-35mm and 35-100mm f2.8 are somewhat quite parfocal. then the expensive brothers: 10-25mm and 25-50mm f1.7 are parfocal.
Archiver Veteran Member • Posts: 3,755
The OP needs unlimited recording for concerts, which rules out the G9.
The GH4 is perfectly adequate for recording concerts in 4k. The limitation will come from memory card size in any of these cameras. As the footage is presumably for documentation and possibly online display and DVD production, only 4k 24p or 25p is necessary. The higher frame rates of the GH5/5/S are unnecessary. The GH4 can shoot in Cinelike-D with decent dynamic range for these situations.
The GH5S will give the best dynamic range, particularly when using v-log l profile. But this adds what might be unneeded work to the post production phase.
As for zoom lenses, this depends on how far the camera is from the performers. A mid-range zoom like the 12-35mm f2.8 or 12-60mm f2.8-4 might be all that is needed to capture the whole group.
Archiver - Loving Every Image Captured Always
http://www.flickr.com/photos/archiver/
Michael Meissner
Yep, I recently added an external monitor (Andycine C6) that I should be able to use headsets on to monitor sound, at least for spot checks. But mostly it was a call that I need to pay attention to the sound level.
I also bought an Olympus LS-P4 which does sound recording as well. I thought perhaps using it as the external microphone, but it may be simpler just use it as a separate backup sound source.
In this case, I actually had a second camera (LX10) that I was controlling via wifi. But I didn't start it up until the middle of the first performance, so I don't have the complete sound from either.
Live and learn. We'll see if the troupe that I've done recordings for comes back with new live shows that I can test this out.
And similarly for my friends that directed small renaissance faires where I recorded each of the performers, whether they will take up the mantle and do faires once again.  This one I'm less certain of.  They were pretty burned out when they stopped doing faire at the end of 2018 before Covid.
I wasn't sure if the GH4 had unlimited record time.
Re: Parfocal?
I think there is some kind of software controlled compensation going on. This would mean that strictly speaking (some of the mentioned lenses) are not parfocal, but in practice pretty much they are. I may be wrong.
Re: Parfocal?
Yes you need to focus at long range and then go back it will still be in focus and from there you can zoom in
Re: Parfocal?
I think  it is done via the power of mind control. I might be wrong.
Re: Parfocal?
Just because I did not have time to search for a reference, and because I admit that I may remember wrong does not mean that I made this up.
See the link below for more information about focus correction.
https://www.dpreview.com/forums/post/60814706
