Noise on the Olympus OMD EM 1 II
Started May 24, 2021 | Questions
mostlyboringphotog Forum Pro • Posts: 10,427
Re: Noise on the Olympus OMD EM 1 II - noise or artifacts?
Bruce DW wrote:
mostlyboringphotog wrote:
If you can upload the RAW file (dropbox?), I would try to process it with with DxO PL4.
See what comes of it,,,
That would be fantastic. Thanks so much.
https://1drv.ms/u/s!AlQzVfZ549zepI4HASQaQf50p2ISpQ?e=whVioZ
Others have already done a better job to analyze your "noise" but since I said I would work on it, here is my rendition... I added TOPAZ Sharpen AI
I think your "noise" is more of the processing artefact.
And good luck!!
 mostlyboringphotog's gear list:mostlyboringphotog's gear list
Panasonic Lumix DMC-GM1 Pentax 645Z Nikon 1 J5 Fujifilm GFX 50R Canon EOS RP
shinndigg Veteran Member • Posts: 4,689
Re: 3 things...
Bruce DW wrote:
shinndigg wrote:
... Why f9.0?
Why is 1250 in broad daylight?
Was this very underexposed? And was that purposefully?
I'm rather embarrased to say that I had the thing set to shutter priority, determined to rule any possibility of lens shake. Everything else played second fiddle. And I realise that is probably the root of my problem. Thanks for asking the hard questions.
No problem... It's all about learning
There is some very sound advice in this thread
shinndigg
www.pbase.com/shinndigg
 shinndigg's gear list:shinndigg's gear list
Panasonic Lumix DMC-FZ35 Olympus E-510 Olympus PEN E-PL1 Olympus E-M1 Olympus OM-D E-M10 +9 more
OP Bruce DW New Member • Posts: 23
Re: Adobe Camera Raw?
That is really helpful and interesting about the sensors and firmware on the more recent cameras
Re: Raw -> DxO Photolab4+DeepPRIME jpeg
Guy Parsons wrote:
From your raw file so kindly made available I got this DxO Photolab4 result using the default canned settings for your body and lens except for Clearview set at 36 and DeepPRIME added.
Does that make the feathers look a bit better?
Oh my goodness what a huge difference! That's amazing and very encouraging. I'll need to get a hold of that.
Re: 3 things...
shinndigg wrote:
Bruce DW wrote:
shinndigg wrote:
... Why f9.0?
There really is. Thanks for your 'hard questions'. Made me think.
Well that is definitely an improvement in the feather detail. Thanks so much for taking the time.
Astrotripper Veteran Member • Posts: 8,676
Looks good for ISO 1250
Looks good to me. This is ISO 1250, of course there will be noise.
In this particular case, you didn't have to use such high ISO. The subject was stationary, so there was no need for 1/2000 s shutter speed. 1/500 s would be enough, which would bring the ISO down to 320.
But in general, there's no way around dealing with high ISO with that combo. Shooting anything that requires a fast shutter speed will force you into high ISO territory even in broad daylight. Same goes for shooting when there's not too much light. That's the reality of shooting at f/9.
As for feather detail, lighting conditions have probably the biggest impact on that. Your example showcases probably the worst case scenario. Try shooting when the sun is fairly low in the sky and position yourself so that it's lighting up your subject more from the side. I'm sure you will see big improvement.
Good luck. And have fun with that lens. It's great fun shooting with it.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
You are most welcome
BTW, your acknowledgement of each commenter is very commendable.
DLBlack Forum Pro • Posts: 15,865
DxO Photo Lab 4 or Pure Raw are game changers.  So is Topaz Noise AI.  Any of these three programs will reduce noise without degrading the resolution mych.
 DLBlack's gear list:DLBlack's gear list
Pentax K-7 Pentax K-5 Olympus E-M5 II Olympus PEN-F Olympus E-M1 II +46 more
YWG Senior Member • Posts: 1,364
Bruce DW wrote:
I'm uploading a picture I took today with a crop of it. The pelican was fairly close to me. It shows the noise problem to perfection. So disappointing.
Anyone else had this problem? Any ideas?
Thanks in advance.
ISO 1250, 1/2000, F9, MC-14, 235mm
Did you raise the exposure, shadows in post at all? That will reveal noise like this. If that was the case, I'd expose enable the shadow/highlight loss indicators. You might be able to expose for the shadows to the point where you lose some highlights or unimportant areas. Dial back the highlights in post. That said, as an E-M1 mkII owner I am not surprised seeing this amount of noise at this ISO.
Occasionally/absentminded/heat of the moment  overshoot with super high shutter speeds and ISO but in hindsight, you can lower your ISO probably a stop or two.  1/2000 shutter is really fast for what looks like a fairly stationary bird, walking bird. I'd be comfortable with 1/500-1/1000. I'd lose the telecon too so you can drop a stop of loss there. The crop may be sharper too than an teleconverter shot.
There are also a lot of noise reduction options. I did a trail of DXO PhotoLab 4 and liked what I saw with their Deep Prime noise reduction set to 0-10 luminance. It won't add detail to your feathers but it would look about a stop cleaner. There is a practical limit however. ISO 6400 and above where things are going blotchy then you're just getting a cleaner blob slab.
Faster lenses help too. You can get the 50-200mm F2.8-3.5 for cheap with an adapter. A little short however for reach.
 YWG's gear list:YWG's gear list
Olympus Stylus 1s Canon PowerShot G5 X Olympus E-M1 Olympus E-M1 II
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
If I spent some more time on it maybe could make it look a little sharper when pixel peeped, plus the top of the head and the bird's back really needs some careful local attention to overcome the lack of detail due to local over-exposure. Plus as mentioned, the focus point seems to be a little past the bird.
DeepPRIME is of use to make any higher ISO or underexposed shots less noisy but is very slow on my notebooks, if using a desktop with an ambitious video board then it will be a lot faster.
All in all I find DxO Photolab4 easiest of ones I've tried to get better looking results. Costly but if patient can wait for their "up to 50% off" sale at Black Friday time when the program or its latest update comes in at about 40% off. Other times of the year they have occasional 30% off periods.
The recent addition of their PureRAW program as a "simple" version of Photolab4 has its limitations in adjusts, so better to pay the extra $$ to buy the full Photolab4 Elite version to get DeepPRIME and all other adjustable features of the raw conversion. Lots of videos about DxO's various programs and how to use them https://www.dxo.com/dxo-academy/
I have no association with DxO, just a happy customer for quite a few years now. I also use Olympus Workspace, Silkypix V10 Pro, Affinity Photo and Capture One Express (free) for Sony as they each have their uses but most shots by far are converted by DxO.
JosephScha Veteran Member • Posts: 7,249
Two things to say
1)  If you must shoot at ISO 1250 then you need serious noise reduction. I recently bought Topaz Labs Denoise AI, and I think it works very well.  Takes a few seconds for a full size JPEG, but it really does a great job.
2) If possible (and I'm sure it was possible, in bright sunlight) shoot at ISO 200. Or maybe 400.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
fourthirdcam Regular Member • Posts: 116
Nice shot, Bruce.
Looking closely, it looks like your sharpening mask is just set too low, so the algorithm is sharpening too many parts of the photo.  Sharpen it to the hilt, then pull up the sharpening mask while viewing at 100% and you'll get an idea of at what point it stops trying to sharpen noise.  Usually, I see this in blurry backgrounds where a low/off sharpening mask causes the blur to crystallize visually.
 fourthirdcam's gear list:fourthirdcam's gear list
Olympus E-1 Olympus E-M1 III +4 more
RSTP14 Veteran Member • Posts: 6,368
Martin Muehlemann wrote:
Bruce DW wrote:
First post here, so thanks in anticipation. I've read plenty of other posts and have learned a lot. However, I haven't found a solution to my issue. Noise.
I have been playing with the Olympus 100-400 on the camera and was sure that it would produce tack sharp pictures. ...
Thanks in advance.
Welcome to the Oly 100-400 with MC-14
I love the rendition of my EM1.3 using the 17mm Pro and the 45mm Pro, but when it come to long telephoto in mediocre conditions, i have not found a Oly solution.
Photolab 4 can help a lot
Cheers
Martin
Shooting 800mm equivalent require very, very good technique if you want sharp pictures, nothing to do with Olympus, and everything to do with the focal length. The 100-400 is pretty sharp, and a very high probability that soft images is the result of less than perfect technique. Even shooting at the low end 100mm, require careful handling, and hand held shooting with IS enabled while maintaining a very stable position and very gentle pressure on the shutter button to achieve anything near good sharpness. When I shoot at 450mm equivalent (APSC 300mm) I always use a tripod and timer release when possible for optimum result, and that's not even near 800mm equivalent.
Roger
 RSTP14's gear list:RSTP14's gear list
OM-1 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-45mm F4 Pro +4 more
Peter Budd
Peter Budd Senior Member • Posts: 1,373
I have not read all replies but many give good info.
I am attaching your photo run through DxO PureRAW + aq tad sharpened.
I have happily used your combo on an OM-D 1 MIII at ISO 6400 and run it through DxO PureRAW with excellent results. Prior to the DxO software, I would limit my shots if at all possible at ISO 1600.
Peter
GMT
 Peter Budd's gear list:Peter Budd's gear list
Olympus PEN-F OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 17mm F1.8 Olympus 40-150mm F2.8 Pro +5 more
tammons Veteran Member • Posts: 8,140
Thanks in advance.
Cheers
Martin
And use electronic shutter. Once I started doing that, instantly I had more keepers.
However, one of the real problems with this photo is, it is slightly back focused.
