Alex H2009 wrote:
Can you outline the workflow that you follow? I see a lot more noise than I would expect at 200 ISO. Photos from yesterday at 200 ISO, F6.3, 1/60, with the 12-40mm lens at 19mm were softer and noisier than I would have expected. Raw files unprocessed with the noise filter set at Standard. I would be interested to try your approach. Any theory why importing into Lightroom would degrade the quality of the photos?
Here's my work flow that stars with a simple straight forward conversion from Raw to Tiff with Olympus Workspace.
First I set up a folder on my desktop for the days images. Then I open the SD card and copy all the files into that folder, Raws and JPEGS. Drag that folder onto the WS desktop icon and all images will be opened.
I then cull through the images in WS and assign a color code to those I want to keep and process. I don’t do any adjustments in WS. Within WS I create a second folder and, selecting all the color coded Raws, I export them as 16 bit tiff files into that folder. If I want to add any JPEGS to the folder I do a copy and paste. Do not export the JPEGS or WS will compress them again and they become unusable.
This second folder is then copied to its permanent location on my external hard drive and all images imported into Lightroom for final adjustments. I use Topaz DeNoise AI plugin if additional noise reduction is necessary.
This process eliminates the ACR conversion altogether, and I get much better results.
Here's 2 recent images (tight crops both) that were shot at ISO 1000 and processed with the above workflow. I should mention that the latest Sony sensors and firmware that reside in the E-M5 III and E-M10 IV are really almost noise free at ISO 1000 if you use WS for the initial conversion.
E-M5 III with Olympus 75-300
E-M10 IV with Olympus 40-150 f/4-5.6
