Cheap macro lens for the Lumix G7
Started May 24, 2021 | Questions
dark_matter New Member • Posts: 9
Can anyone suggest the cheap macro lenses for the Lumix G7 which can give optimum output.
Panasonic Lumix DMC-G7
dlevitt Senior Member • Posts: 1,188
Re: Cheap macro lens for the Lumix G7
The cheapest option is an add on close up lens that may fit one of your existing lenses.
There are several macro lens choices with auto focus support from Panasonic and Olympus. I think the Oly 35 f/3.5 macro is typically the least expensive.
Save the Earth! Collect the entire set!
 dlevitt's gear list:dlevitt's gear list
Panasonic Lumix DMC-FZ50 Panasonic Lumix DMC-LX7 Olympus OM-D E-M10 II Olympus E-M1 II Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +7 more
Bassam Guy Veteran Member • Posts: 4,890
I have the Olympus and it is pretty good. However, I noticed on the faster Panasonic 50mm macro was on sale ($100 off) at B&H and probably other retailers, so it costs the same at least while the sale is on.
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
jalywol
jalywol Forum Pro • Posts: 12,302
Cheapest is an adapted manual focus vintage 50ish mm macro. Adapters are about $20, and the lenses range from about $30-100, depending on what brand you get. I have a 45 year old Nikon that cost about $50, and is still an exceptional lens.
If you want autofocus, either the Panasonic or Olympus 30mn macros are excellent.
-J
Typo corrected: Cheap macro lens for the Lumix G7
I have the Olympus and it is pretty good. However, I noticed on the faster Panasonic 30mm macro was on sale ($100 off) at B&H and probably other retailers, so it costs the same at least while the sale is on.
windmillgolfer
windmillgolfer Forum Pro • Posts: 17,782
 windmillgolfer's gear list:windmillgolfer's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-ZS40 (TZ60) Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GF7 +13 more
BBbuilder467 Veteran Member • Posts: 7,057
I don't think the G7 has IBIS, so you probably want the Panasonic versions with IS in the lens.
Based on your previous post, the 30mm f/2.8 would be a good fit for your nature close-ups, but 30mm is too short for insects. I don't think I've ever reached true 1:1 in real world outdoors, but it's nice for flowers and similar subjects that are normally 1:2.
