Canon Pro-1000 ink alternatives?
Started 8 months ago | Discussions
Michael Todd
Michael Todd Senior Member • Posts: 2,913
I've been on backorder notification lists at Adorama and B&H or a month or more to get ink for my printer.
I have run out of the stores I had, so I took a look at the tanks going out soonest and ordered those two off of Amazon, at higher prices.
I've only had this printer for 9 months, and have always used Canon inks.  Are there other alternatives that you folks have had good luck with?
I just don't want to have invested in this system, then have to still send my print jobs out to labs because I can't find ink for my printer.
Thanks.
-Todd Muskopf
www.classicbeautyproject.com
FB/IG #classicbeautyproject
 Michael Todd's gear list:Michael Todd's gear list
Canon EOS-1Ds Mark II Canon EOS-1Ds Mark III Canon EOS-1D X Mark II Fujifilm X-T20 Fujifilm X-T3
palombian Contributing Member • Posts: 530
Re: Canon Pro-1000 ink alternatives?
Thanks.
The PRO-1000 uses the same inks as the higher models 2000/4000/6000.
With some effort you can refill from cartridges for those models (same quality at a lower cost/ml).
You also can buy 3th party ink.
Jose Rodriguez on youtube will explain everything.
 palombian's gear list:palombian's gear list
Canon EOS 7D Canon EOS M6 Canon EOS M100 Canon EOS M6 II Canon EOS R5 +26 more
Michael Todd
OP Michael Todd Senior Member • Posts: 2,913
Thanks Palombian
-Todd Muskopf
john isaacs Veteran Member • Posts: 6,377
Thanks.
Individual tanks on Amazon are $60, except for Croma Optimizer which is $55, for a total of $715 for a full set.  That's $16 over the cost of a refill kit, so I wouldn't really call it "higher prices".
I use Precision Colors refill ink on my Pro-1000.  It costs $382 for a full refill kit.  They are using OEM ink for four of the colors because they couldn't match them.  Refills for the OEM are $35.  If you don't want to use third party ink, you can get OEM for all colors. the difference is $23 per color for the 8 colors, or an additional $184.  So, an OEM refill kit is $566, for a savings of about 20%.
One advantage of using the refill ink set, is that Precision Colors has profiles for a lot of non-Canon paper.  So you don't have to go to the expense of getting custom profiles if you want to use non-Canon paper.
Or, you could shop on eBay.  I've gotten sealed OEM cartridges for as little as $35.
 john isaacs's gear list:john isaacs's gear list
Panasonic Lumix DMC-GH4 Olympus E-M1 II Panasonic GH5 Olympus OM-D E-M1X Olympus E-M5 III +16 more
Gesture Veteran Member • Posts: 9,235
I admire Precision Colors for acknowledging that it couldn't match some of the ink positions.
What do you mean by "Refill Kit."
Michael Todd
Thanks for your input.  I'll look into that.
-Todd Muskopf
A Canon Pro-1000 refill kit is 8 PC inks ($12), 4 OEM inks ($35), 12 chips ($12), and a refill cap ($2).
https://www.precisioncolors.com/Pro-1000ref.html
