Re: blade test... and bleed, ghosting, halo or whatever it is called
SterlingBjorndahl wrote:
Halina3000 wrote:
switching between lenses doesn't seem to improve things but maybe there is an optical improvement that I have not come across.
You could try using greater magnification to take partial, overlapping images of your target and stitch them together in post-processing, sort of like we commonly do to create a panorama. If part of the cause is because of flare inside the glass, this should reduce the flare-to-image ratio (I'm not an expert so I just made that term up) so that at equivalent magnifications the flare should be less noticeable.
What is your output target? Print? Web? For a "reality check" make sure you're not zooming in more than what your viewer/customer will use. Printing an 8x10 may help you determine whether this problem is serious or not.
Sorry missed your message earlier. Output target... could be web or print depending on the photo. Some are family shapshots that will be shared with other family members online, others are images where I hope to get a decent quality print. Mainly I'm trying to make a decent stab at digitising my slides where previous attempts have failed... partly because of poor quality results and partly because of the time spent waiting for scans.
I'm really not set up for overlapped multi frame captures... basically I want to get the best result that I can achieve from a single DSLR frame.
Having thought about the halo/flare issue some more I've come up with a multi part sanity check...
1. Problems with the real slide should be the same regardless of capture optics. Problems with the capture optics should change with the optics... not that I have a vast range of different optics to swap.
2. Both of the above can be detected by pushing the contrast with curves. This shows that there is a real issue but it is only perhaps 25% of the scale that I'd first thought. It doesnt vary with the two lenses that I've been using so could be ghosting from the skylight filter on the 35mm SLR or the mediocre optics of my first camera.
3. If a fringe remains the same size when the image is zoomed then it's not a problem with the image. This seems to be the more prevalent issue. Now that I've seen it by peering at photos I am also seeing it on other screens with web pages etc.
4. If it's my eyes or brain and not the screen then masking the light side of the boundary of my test SVG with some card should make the halo vanish... which it does. I see the same effect with each eye if I try one eye at a time. Using the card to mask the photo on screen also has the same effect.
So there you are - it seems that the issue is maybe 25% real halo and 75% down to me, the observer.
I don't think this needs to delay my slide digitising project further but I can't say that I am altogether happy with the 75% part of the conclusion.
