Slide holding for Scanning - Ohnar and Other Options
May 21, 2021
I'm having another attempt to digitise my collection of Kodachromes. I've tried two flatbed scanners in the past and an OpticFilm scanner but have always found that the results take a lot of effort and lack the dynamic range to capture what I can see with my own eyes on the slide.
The current project will use my Canon crop frame DSLR. By googling and trial and error I have arrived at an optical setup using a BPM bellows unit and an 80mm enlarger lens. Initial tests with this setup and using bracketed exposures and HDR have been very promising.
Now I need to turn my table top lash up into something that will be easier to use for repetitive work. I fully expect some DIY design and build and creative upcycling of 35mm kit. The current question is how to hold the slides.
I think I've ruled out the BPM holder. I have two of these. One is less dirty than the other but they don't seem designed to allow cleaning of the side facing the slide. Getting the slide out after use is also awkward.
I've also ruled out the holder from the OpticFilm - I was always nervous about damaging slides when using this because the springs seem too stiff
I've also bought an Ohnar duplicator from eBay. It isn't the right model for the crop sensor but the slide holder seems less awful than the other options. At least I can get slides in and out without too much risk of damaging them or dropping them.
It does puzzle me though... why are there two slots (pic below) ? The rear one seems designed for some sort of sliding frame but mine did not come with anything to go in here. How can two slots work with fixed focus optics anyway?
Any other ideas for reasonably priced slide holding options?
