XE3 vs XE4 build quality perception?
Started May 19, 2021 | Discussions
Robmas4229
Robmas4229 Senior Member • Posts: 1,272
For those of you that have unboxed and handled both cameras, how does the perception of build quality compare between the two?
Some have stated that they felt the build quality of the E4 is better, but Chris Nichols in his DPR video review mentioned that it felt a bit "plasticky."
I have not handled an XE4 but 3 years ago when I purchased the XE3 IT felt kind of cheap and plasticky when I took it out of the box, but that impression faded after installing a battery and mounting a lens. Later however, the diopter wheel must have bumped into something and the internal workings of the viewfinder became loose and wobbly. Something inside must have broken. I have since epoxied the mechanism into place and it's functional but it left a sour taste that it was so fragile.
Reason for asking is that I am considering the purchase of another E series body for use with my smaller lenses when traveling. Not sure how I'd get along with the reduced controls of the E4 but if the build is more reliable it might be worth considering.
Thanks for your thoughts and impressions.
-Rob
 Robmas4229's gear list:Robmas4229's gear list
Fujifilm X-E3 Fujifilm X-T3 Fujifilm X-T30 II Fujifilm XF 18-55mm F2.8-4 R LM OIS Samyang 12mm F2.0 NCS CS +7 more
