Your sincere thoughts about my photos
Started May 19, 2021 | Photos
dark_matter New Member • Posts: 9
5
I have been using Lumix G7 for about 8 months. I have only a kit lens with me(14-42mm). I always use manual exposure for filming.
I am sincerely requesting you to share your thoughts about my photos and camera settings(positives and negatives). Also some tips for improving my photography. Kindly look at some of my photos attached below.
aperture ƒ/5.6
Shutter Speed 1/60s
ISO 400
Focal Length42.0mm
Aperture ƒ/5.6
Shutter Speed 1/320s
ISO 400
Focal Length 42.0mm
Aperture ƒ/5.6
Shutter Speed 1/500s
ISO 400
Focal Length 35.0mm
Aperture ƒ/6.3
Shutter Speed1/60s
ISO400
Focal Length 42.0mm
Aperture ƒ/8.0
Shutter Speed 1/80s
ISO 200
Focal Length 42.0mm
Aperture ƒ/5.1
Shutter Speed 1/125s
ISO 800
Focal Length 23.0mm
Aperture ƒ/5.6
Shutter Speed 1/60s
ISO 400
Focal Length 42.0mm
Aperture ƒ/5.6
Shutter Speed 1/30s
ISO 400
Focal Length 42.0mm
Aperture ƒ/5.6
Shutter Speed 1/60s
ISO 800
Focal Length 42.0mm
Aperture - ƒ/5.4
Shutter Speed - 1/200s
ISO - 400
Focal Length - 34.0mm
Comment & critique:
Panasonic Lumix DMC-G7
Redhenry Senior Member • Posts: 1,169
Re: Your sincere thoughts about my photos
Hi,
I think you have made a good start. Some of these pictures are very pleasing but there are a few points which would improve them. Two things occur to me:
1. Composition. In some pictures, the subject needs to be a little larger in the frame - those nice red chilli peppers are quite far away and would have more impact if you move in a bit. The same applies to the pictures of the white flowers and to that vine or creeper tendril. When I was a novice photographer, my dad would say, "that looks like a pea on a drum - get closer and fill the frame!"
2. Your pictures of the white flowers suffer from something which often happens with white subjects in photographs- they are underexposed. Your camera's metering system is exposed to such a subject and thinks, hey, there's a huge amount of light coming from those white flowers - I'd better go for a faster shutter speed in case they picture is overexposed. This is why the whites are a little dull. This often happens with pictures taken of snow scenes or on a sunny beach and is why most cameras have 'beach or snow' among their 'scene modes'. It's to tell the exposure metering system that there really is supposed to be lots of bright light! To correct this for white subjects, adjust the exposure compensation to something like plus one, or if you use raw files instead of jpegs, adjust the exposure until those whites are nice and bright.
Best wishes and have fun!
 Redhenry's gear list:Redhenry's gear list
Sony RX100 II Apple iPhone 13 Pro
Bassam Guy Veteran Member • Posts: 4,890
Next time, please put in a little description of each, so comments can easily distinguish which they're talking about. If I have nothing meaningful to title them, I'll at least use "#1", "#2", ...
My opinions are meant humbly.
#1 Peppers
Tasty! Excellent lighting, perhaps a tad too much on the 5th one.
aperture ƒ/5.6
Shutter Speed 1/60s
ISO 400
Focal Length42.0mm
#2 Buds
Honestly? Uninspiring. Move in closer & remove the bottom & right to accentuate the stem and highlight the flower bud? IDK?
Aperture ƒ/5.6
ISO 400
Focal Length 42.0mm
#3 Coleus
No distinct subject. Eye wanders and it all looks too much the same.
Aperture ƒ/5.6
ISO 400
Focal Length 35.0mm
#4 White Flower Pair
Underexposed and too centered, add 0.5 stops in post & crop to recompose
Aperture ƒ/6.3
Shutter Speed1/60s
ISO400
Focal Length 42.0mm
#5 decapitated buds(?)
Nice. I'd brighten it a bit and add this to my background folder to rotate in occasionally
Aperture ƒ/8.0
Shutter Speed 1/80s
ISO 200
Focal Length 42.0mm
#6 Leafy Thing
Composition could work but don't know why I'm not impressed. Fuller lighting? Deeper DOF? IDK
Aperture ƒ/5.1
ISO 800
Focal Length 23.0mm
#7 Fern
Like. I would crop off some of the semi-distracting right area
Aperture ƒ/5.6
Shutter Speed 1/60s
ISO 400
Focal Length 42.0mm
#8 Blueish Purplish Flowers
Nothing spectacular
Aperture ƒ/5.6
Shutter Speed 1/30s
ISO 400
Focal Length 42.0mm
#9 Red Plus
Nothing spectacular
Aperture ƒ/5.6
Shutter Speed 1/60s
ISO 800
Focal Length 42.0mm
#10 Moody flowers
Like. I'd crop out some of the background & try brightening highlights a bit
Aperture - ƒ/5.4
ISO - 400
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
C Sean Veteran Member • Posts: 3,423
Just be aware, I do watch Fstoppers Critique the Community. So nothing personal.
aperture ƒ/5.6
Shutter Speed 1/60s
ISO 400
Focal Length42.0mm
I like the concept but the image may work better if the peppers were focus stacked. You have seven peppers, seven subjects and each one isn't fully in focus. By focus stacking, the peppers should look pin sharp.
Aperture ƒ/5.6
ISO 400
Focal Length 42.0mm
To make the photo work I would try flash to darken the background so the subject would stand out. And I would also look at the composition too.
Aperture ƒ/5.6
ISO 400
Focal Length 35.0mm
I like it.
My advice is to do more photos of these and try different compositions. What made this photo work is you used the leaves to create a nice pattern.
Aperture ƒ/6.3
Shutter Speed1/60s
ISO400
Focal Length 42.0mm
My rule for keepers are the following..
  • Is it good enough to be printed and mounted on the wall?
  • Is it good enough to be publish in a magazine?
  • Does it document something?
  • Does it capture a special moment aka baby photos.
My recommendation is to go back and try to do it better. All I see if seeing a flower and you took a snap shot hoping it turn out to be good.
Aperture ƒ/8.0
Shutter Speed 1/80s
ISO 200
Focal Length 42.0mm
A good photograph and I like it a lot.
Aperture ƒ/5.1
ISO 800
Focal Length 23.0mm
Nothing wrong with experimenting or getting experience. However its a good idea to go back and try to out do your previous attempt.
Aperture ƒ/5.6
Shutter Speed 1/60s
ISO 400
Focal Length 42.0mm
Nothing inspiring about the subject and the blurred out plant to the right is distracting.
Aperture ƒ/5.6
Shutter Speed 1/30s
ISO 400
Focal Length 42.0mm
So so and the spider web is distracting.
Aperture ƒ/5.6
Shutter Speed 1/60s
ISO 800
Focal Length 42.0mm
Keeping experimenting with your compositions. However, the blurred out flowers to the right is out of focus.
Aperture - ƒ/5.4
ISO - 400
Excellent...
I like the composition and colours.
So overall some quality photos in my opinion, some need more work and others needs purging from your hard-drive when you get better.
ahaslett
ahaslett Forum Pro • Posts: 12,662
In brief
I like the buds because the composition works and the execution is good. It would make a nice restful print in a meeting room - good work.
The image EXIFs don’t have lens data but these look as though you took them handheld without stabilisation from the lens. You used quite short exposures and the images are quite noisy. I’d shoot these kinds of subjects on a tripod or set base ISO and rely on the IBIS in my EM1.2. For still life images indoors, you can control the lighting.
Several of the images look as though you missed focus. If you use a tripod, then you can get critical focus on the exact point in MF. I prefer that. Some of the images would benefit from either deeper depth of field or focus stacking.
The noise, focus and depth of field issues mean that most of the images only work at small sizes.
You had comments about composition from others. Note that what works for one person may not work for another. Unless you are photographing for someone else, then be your own critic - what do you like about each image and would you keep it for years?
Not sure if these are JPEG’s out of the camera or you shoot RAW. Some people believe in capturing the exact shot in camera, maybe using scene modes or jpeg settings to get the effects, tone curve etc they want. I shoot RAW and agree with many others who think that processing the image after capture is a key part of achieving the image you want.
I make no claim of excellence, but I admire you asking for feedback. Here is a flower image where I applied the approaches above (taken on a tripod).
Andrew
PS If you post in the weekly image threads, you will get feedback from far better photographers than me.
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
Please feel free to edit any images that I post
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
G1Houston Veteran Member • Posts: 3,188
Shutter speeds too low?
For a 42.5mm lens, you need a minimum of 1/90 sec to prevent camera shake that reduces sharpness.  Plus, in nature, objects are rarely completely still as breeze can cause them to move.
 G1Houston's gear list:G1Houston's gear list
Nikon D7100 Panasonic Lumix DC-GX9 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G 14mm F2.5 ASPH Nikon 85mm F1.8G +6 more
jeffharris
jeffharris Forum Pro • Posts: 11,411
5
Some nice shots, you need to work on composition.
It's rare when a photo with the subject plopped dead center in the frame is very interesting compositionally. To me, that's catalogue or field guide photography.
Finding things that counter balance or oppose the subject or move the eye around the image help tremendously.
Look at paintings and photographs. And practice. Good start, though.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 42.5mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Panasonic Lumix DMC-GX8 +26 more
jalywol
jalywol Forum Pro • Posts: 12,302
NOTE: I am not going to critique sharpness or motion blur, just composition.
Nice shot. A wee bit too much black background. Experiment with cropping it.
For this kind of shot you need to be either much closer in or further away with a very long lens. As it is the background distracts from the subject.
Nah. There is no area that draws your eye and engages you. It's a Coleus, but that's about all you can say about it.
This shot has potential. Try cropping a bit and brightening it a little in post processing. If you were to shoot it again, experiment with different apertures to maybe blur the background a bit more, but that's an individual choice. Maybe add some vignetting.
I LOVE this shot.
There are things that are interesting here, but the background is a bit distracting, Maybe try and convert it to B&W and experiment with post-processing it?
This one does not succeed on just about any level, unfortunately.
Flowers are tough. Experiment with different angles, close up lenses, etc. It takes time to get a feel for the best approach to them. This has potential, but you need to be in closer and/or crop the background a bit.
This one is more successful than the previous, but again, too much background. Adding vignetting to this one would I think make it really stand out.
I like this shot a lot. The background in this one has some very interesting things happening, yet they complement the subject rather than distract from it. You should do a bit of cropping on the top and sides, however, which will draw the eye into the flowers more, rather than the space above them.
OP dark_matter New Member • Posts: 9
Redhenry wrote:
Hi,
First of all, thanks for your sweet feedback. I admit that the composition in some of the pictures needs to be a little larger in the frame. But the problem is that I am owing a kit lens, so I can't go too much closer to the subject. The minimum focusing distance of my lens is about 0.2m. My kit lens has a max focal length of 42mm, so I can't zoom that much.
In the post-processing, I can't crop the image so much for filling the frame,because my camera has 16MP only. So I don't get that much resolution for the picture.
I will also admit that I don't how to properly expose the subjects in the black background. I need to master those skills. Anyway, thanks for your feedback. Expecting your feedback for my future photos.
I think that some of the comments made in the other replies are useful. Don't worry too much about perfection. Some people insist on an image which is absolutely sharp from front to back, has no noise and which follows those rules of composition like not having the subject in the centre. I take a lot of plant and flower pictures and to achieve sharp pictures, I usually use a monopod ( not a big heavy one, just a collapsible walking stick with a camera screw on the top). I also make sure, as one of your other correspondents pointed out, that the shutter speed is at least the reciprocal of the focal length. If the light level is low, I turn up the ISO but I don't usually go beyond 800. I also tend towards wider apertures if I want to isolate flowers, so that the background is blurred. It is difficult to guess exactly what the best aperture is for any situation, as you do need to have all of the flower in focus but if you bracket your exposures, you should get it right. Wind is the flower photographer's worst enemy - I have heard of photographers using clothes pegs to keep plants still. Bear in mind that I have had 16 megapixel pictures published  all over the world and I use jpegs straight from the camera and have no idea how to do 'focus stacking'! Your camera is good enough.
Lepewhi Senior Member • Posts: 2,107
You will read a different opinion from each of us. Sometimes, it just a matter of taste.  I'd say to join a photo club or camera club.  You can ask questions and learn from more experienced photographers.  Also, learn different techniques, as well as have fun.
That being said, I like the one with the white buds.  I find it pleasing.  Enjoy your new camera.
Slippery when wet.
 Lepewhi's gear list:Lepewhi's gear list
Panasonic Lumix DC-GX9 Panasonic Lumix DC-G100
rsmithgi Senior Member • Posts: 2,939
I would add that you need to be more careful with the background. For these types of shots, anything that doesn't contribute to the image is a distraction.
Strive for clean backgrounds and no distracting elements on the edges of the frame.
Images #2, #4, #7, and #10 would benefit from better backgrounds. I realize that this is difficult with limited focal length and max aperture.
Images #1 and #5 are nice.
 rsmithgi's gear list:rsmithgi's gear list
Olympus E-M1 Olympus E-M5 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 17mm F1.8 +5 more
Hi,
In reply to your request for examples, here are three pictures which have been published several times. I do not pretend to be an expert, and the pictures are intended to be illustrations, not works of art. The pictures which I get published via a photo library are generally used on websites and for sizes up to a half-page in a magazine. I take them because I like them and just send the better ones to the agency. I will view them on a computer screen and occasionally print them at A4 size. They will never be used on a billboard or a cinema screen. None of them required specialist equipment. The ring of allium flowers was taken with a Fuji X100s, which was quite an expensive camera but it just had the standard 23mm lens. The other two were taken using very modest equipment. The butterfly picture was taken on a tiny Fuji XF1 compact with a small sensor and the picture of the 'bleeding heart' flowers was taken with an original Nikon 1 with a one inch sensor and the kit lens. As a recent correspondent says, you will get a different opinion from everyone. There are people who think you need the latest 100-megapixel marvel and a lens which costs as much as a car. This is not true. I will be moving over to Micro Four Thirds later this year and will probably buy an Olympus OM-10 with the 16 megapixel sensor, the same as your camera has. It's not about counting the pixels! I hope you enjoy your photography.
PhotonBeam
PhotonBeam Contributing Member • Posts: 538
I put a few thoughts below. Overall, i agree with previous comments about the benefit of filling the frame. I would also encourage you to think about the subject and the reason why you decided to take a picture of a particular flower/object instead of the one next to it. You can use composition and light to emphasize those attributes.
Lastly, I love reading books on composition. It took me a few books before the concepts started to sink in 😂.
aperture ƒ/5.6
Shutter Speed 1/60s
ISO 400
Focal Length42.0mm
This picture is quite good. The pepper arrangement looks good and the red contrasts with the black background. However, the peppers are quit small in the frame. I would crop in to emphasize the subject and maybe reduce highlights a bit.
even though your camera is "only" 16 megapixel, you should not be afraid big cropping. I have a 13x19 print of a 3 megapixel crop from a 16 megapixel camera on my wall. It holds up surprisingly well. (Though I typically try to keep 10 megapixels.
Aperture ƒ/5.6
ISO 400
Focal Length 42.0mm
I am not sure if I see what you were going for in this photo. If you are able to explain why you were drawn to this particular subject, it might help me better identify ways of modifying composition.
Aperture ƒ/5.6
ISO 400
Focal Length 35.0mm
This photo is quite pleasing and well exposed. It does lack a clear subject, which prevents it from being a great image.
I may have tried emphasizing one of the large clusters of flowers and then let the smaller ones fill in the background.
Aperture ƒ/6.3
Shutter Speed1/60s
ISO400
Focal Length 42.0mm
What is the story you were attempting to tell here? I see a flower in full bloom and a wilted flower, which may make a compelling story. I would have recomposed the shot to emphasize those elements by getting closer, changing the angle by stepping to the left, and likely only including a left white flower and the wilted flower.
With that said, the story you saw may have been different.
Aperture ƒ/8.0
Shutter Speed 1/80s
ISO 200
Focal Length 42.0mm
Fantastic! Nice use of a pattern.
Aperture ƒ/5.1
ISO 800
Focal Length 23.0mm
This one is ok. I think it may have been better if there was enough depth of field to get the entire plant in focus.
I may have experimented with getting closer to make it more of an abstract image.
Aperture ƒ/5.6
Shutter Speed 1/60s
ISO 400
Focal Length 42.0mm
The lighting on the leaf is quite nice, but I personally don't find the picture very inspiring. But I feel the same about most leaf pictures unless there is something special that adds to the image (e.g., color, texture, context, extraordinary composition, etc.).
I wonder how the picture may have looked if you placed the camera by the stem and shot along the stem (so the stem becomes a leading line to the rest of the leaf).
Aperture ƒ/5.6
Shutter Speed 1/30s
ISO 400
Focal Length 42.0mm
This one is good. Maybe not a wall hanger, but I would be happy with it.
Aperture ƒ/5.6
Shutter Speed 1/60s
ISO 800
Focal Length 42.0mm
I would have gotten closer to emphasize the pattern of the buds with a flower in the middle.
Aperture - ƒ/5.4
ISO - 400
This one would be fantastic if you got a bit closer (or cropped the image). Nice light! Notice how the flower pops out of the dark background.
 PhotonBeam's gear list:PhotonBeam's gear list
Olympus E-M5 II
Beautiful.  Well done you!!
Slippery when wet.
kcdogger Veteran Member • Posts: 4,357
I like them.  Keep shooting.
Peace.
John
 kcdogger's gear list:kcdogger's gear list
Olympus Stylus 1 Panasonic ZS100 Sony RX100 VA Panasonic Lumix DC-ZS80 Olympus TG-6 +37 more
bluevellet Veteran Member • Posts: 4,172
My first impressions...
Boost exposure, saturation and contrast levels, get closer and/or crop, focus on what you want to show, make the rest disappear.
Tried to quickly work on some of your jpegs.
 bluevellet's gear list:bluevellet's gear list
Panasonic Lumix DMC-GM5 Nikon Z6 OM-1 Sigma 35mm F1.4 DG HSM Art Olympus M.Zuiko Digital ED 8-25mm F4 Pro +23 more
