Lens combo for M100
Started May 18, 2021 | Discussions
1SteveMac New Member • Posts: 2
Lens combo for M100
Just after some opinions or other options I might not have considered. Currently have the above camera plus 15-45 and 22 lens combo.
Looking at my photos from my last trip I kept 98 photos from the 15-45;
41 of those between 15-24, most at 15mm
11 of those at 28mm
12 of those at 35mm
34 of those at 45mm
If I want to upgrade my 15-45, what lenses should I look at? I'm probably only looking to travel with 2 or 3 lenses maximum, ideally 2.
With most of my photos at 15mm, it makes sense to get the 11-22mm as that would be a good upgrade and I can then go wider when required.
My thinking was then to pair that with either;
EF-M 32mm F1.4 - Looks great and would have covered off those at 28mm and 35mm
Sigma 56mm F1.4 - Looks great, to cover off those taken at 45mm.
EF 50mm F1.8 and adapter - Cheaper alternative to Sigma
EF 40mm F2.8 and adapter - Cheap and covers the 35mm and 45mm
I normally photograph landscapes/ocean/beach and city scenes, hence the 11-22mm, but unsure what to pair that with.
Am I missing anything? I think my preferred option is 11-22+32, but that is an expensive combination, hence looking for alternatives.
Canon EOS M100
IoannisZ
IoannisZ Regular Member • Posts: 499
Re: Lens combo for M100
6
My opinion is to use more your camera with your lens and take more than 3000 photos on different subjects. Then, you will have more clear mind of what you want.
Flickr. Giannis_
More pixels, less ideas
jkcz Regular Member • Posts: 168
In my opinion zooms are alright if you get decent copies but the primes are the ones that will give your pictures that wow factor. I like your 11-22 + 32 idea, I would do something along those lines. If you grab the 22 it might sound like an overkill but that is one gem which makes the M100/M6 body type extremely portable, which is a real benefit when travelling - especially if you like to be out at night. Otherwise the sigma 56 is another great option, has a bit more limited use cases because of the tighter FOV but this focal length can also get you some nice perspectives and background rendering.
TL;DR: IMHO the best travel/street combos are 11-22+32 or 11-22+22+nifty fifty or the sigma 56
 jkcz's gear list:jkcz's gear list
Canon EOS M100 Canon EOS M6 II Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +2 more
eldo472 Junior Member • Posts: 48
Stay with the combo You have.
The 15-45mm is good enough and it's small. Perfect for the small M100.
The lens have IS and You can stop it down to get the best picture quality.
If You don't want background blur the primes is not needed.
Except for the 22mm the other lenses is bigger and makes the camera not so pocketable.
rz64 Regular Member • Posts: 454
To my mind, the 11-22 (which I don't own) and the 32 mm is a good combination.
I also started with the 15-45, after that I added the 22mm and finally the 32mm.
Although the 15-45 offers more flexibility, it is especially the 32mm which offers a unique IQ. If I only had to choose one lens, it would be the 32mm.
Today my 15-45mm is only rarely used.
 rz64's gear list:rz64's gear list
Canon EOS M6 Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 55-200mm f/4.5-6.3 IS STM Canon EF-M 15-45mm F3.5-6.3 IS STM +3 more
DooS New Member • Posts: 15
11 of those at 28mm
12 of those at 35mm
34 of those at 45mm
I agree with loannisz, you need bigger sample size to really know what kind of focal lenght you prefer.
Also have in mind that it may all change depending on the situation. When I first got into M system, I would take with me adapted Sigma 17-50 f2.8 for travel. It was bulky and kind of ridiculous on small M body but did the job well, I could use it both outside and indors, and in the evening if there is enough of street lights. I had 22mm pancake with me in case I need it. I found out I am taking most of my photos wide so I got 11-22 guided by the similar conclusion you have. Next trip ended with me feeling I have missed some photos. In practice, I hate to change lenses all the time so I ended up with only wide photos during the day and all photos in the evening were 22mm pancake. So then I got m3 and next trip I went with two bodies and two different lenses, and it was kind of ok as a solution, as M system is pretty small. But this worked for me only when traveling, I found out that I am rarely using 11-22 in any other situation.
Also I have found out that if I have zoom lens on, I may, for example zoom from 32 to 50mm for a single photo but when there are two separate lenses, I will simply keep on 32 mm on all the time. So results of analising focal lenght of your zoom lens photos may not actually translate to what focal lengths will you keep on your camera when it's not just one lens. You may think that some focal length can be useful to you and find out that if you have to change lenses this one lens ends up unused most of the time.
My personal conclusion was that for M, adapted 2.8 zoom is necessary for me, even if it is bulky, and if I am in the mood and traveling, I may take second body with something wide. I ended up using long focal lenghts rarely, only when I intentionally go to take some portrait photos. 22mm is always a no brainer as it is small, and in the evening I used to take just a camera with a pancake. I have sigma 32mm for Sony, and always felt it is a bit narrow f.lenght for walk around and social situations - I would easily pay twice the price to have cannon 22mm on a sony mount So I am considering Viltrox 23mm 1.4 right now.
So in your situation, I would maybe go with 11-22 + 32 if you need something longer, and with a 22mm in the bag. But the thing is, if I was using only one body, with this combination I would be back from a trip without any 32mm photos.
Hope that any of this helps!
 DooS's gear list:DooS's gear list
Canon EOS M Canon EOS M3 Sony a6500 Canon EF 50mm F1.8 II Sigma 17-50mm F2.8 EX DC OS HSM +6 more
23speaker23 Contributing Member • Posts: 557
11 of those at 28mm
12 of those at 35mm
34 of those at 45mm
I would also suggest you keep shooting with your existing combo for a while and get a better feeling of it.
My copy of 15-45 is very good. I finally got the 11-22 since 17-40 was most of the time on my FF camera. And I had some money to spend.
My other lenses are sigma 56 and canon 22. These are the tiny gems that make the m6 for me. I am a 35/85 ff equivalence guy ))
I also have a bunch of ef lenses with the adapter but rarely use them.
Just my 2 cents.
