Query about filter sizes Canon RF 24-240mm
Started May 17, 2021 | Questions
robgendreau Forum Pro • Posts: 10,917
For anyone using the Canon RF 24-240mm lens, is it possible to use smaller than 72mm lens filters on it without significant vignetting?
It looks like the glass up front is significantly narrower than where the lens filter threads are. But I also know the lens already had vignetting that has to be corrected. But that doesn't necessarily mean that the hard vignette is the outside edge. On my 35mm eg I can use smaller filters with a step down, which is what I'd like to do with the 24-240mm.
Thanks!
 robgendreau's gear list:robgendreau's gear list
Pentax 645Z
tkbslc Forum Pro • Posts: 17,522
Re: Query about filter sizes Canon RF 24-240mm
Thanks!
What is your end goal? What is the benefit?
I did not try any smaller filters on mine, but 24mm generally needs the slim filters to avoid vignetting on any lens. So I would not expect you'd have luck. Especially on a lens that vignettes badly with no filter at all.
Maybe try buying the cheapest 67mm filter on ebay and see if you can get away with it. There are UV filters from China for under $3 shipped. But it is not like 67mm filters are cheaper or meaningfully smaller to carry. So I'm still confused as to why you'd need to do this.
OP robgendreau Forum Pro • Posts: 10,917
Thanks!
I don't use UV filters. We're talking much more expensive and harder to find IR and UV pass (not cut) filters.
I may just go with a rear filter if they're currently available.
Pentax 645Z
robgendreau wrote:
Thanks!
Is there a huge price difference between 67 and 72mm? Surely you have no hope of going smaller than that with a wide angle lens.   The UV filter suggestion was meant as a proof of concept test.
tkbslc wrote:
robgendreau wrote:
Thanks!
It's a matter of new filter vs $0 since I have filters in other sizes. A new 590nm or 665 or UV pass ranges from $130 to over $200, and some wavelengths are just not in stock. So I'd prefer not to spend hundreds on new filters if I don't have to. I can fudge 35mm quite a bit since the limitation is the edge of the glass on that RF lens. 24mm is wider, but the devil is in the details. And I can lose some of the lower range of the lens anyway depending on what I'm doing.
Ultimately one solution is a rear filter, but those are on pre order, although I might be able to get one custom-made. Just don't want to put my vendor out if I don't have to, and using some of the smaller ones would still save me some money for other wavelengths.
At least one of my astro filters is 77mm, so that's an easy solution.
Pentax 645Z
robgendreau wrote:
tkbslc wrote:
robgendreau wrote:
Thanks!
Well if you have filters, all you need is to buy a step ring and try it out.  The thickness of the filter is going to matter, so it's probably something you'll need to test.   $4-5 on ebay is some low risk.
tkbslc wrote:
robgendreau wrote:
tkbslc wrote:
robgendreau wrote:
Thanks!
Yep. Problem is the lens won't arrive until too close to departure date. Thanks for the help though.
Pentax 645Z
