D7000 auto focus
Started 2 months ago | Questions
William in Canada Forum Member • Posts: 99
D7000 auto focus
I found my D7000 seems have autofocus issue. I don't believe it is hardware issue I think i changed something.
The panel show my focus is AF-A. Each time, when I half press release button, it starts with area focus but always end up single focus. I did change the lens to A and change to AF in the body.
I use D7000 and 18-105 lens. What could be the reason. Thanks
Thanks in advance!
Nikon D7000
Nikon D7000
Mako2011
MOD Mako2011 Forum Pro • Posts: 27,517
Area....?
Witch means it will switch from AF-C to AF-S automatically depending on conditions.
Each time, when I half press release button, it starts with area focus ...
Do you mean AF-C?
....but always end up single focus.
Changing to AF-S from AF-C is normal for AF-A mode
My opinions are my own and not those of DPR or its administration. They carry no 'special' value (except to me and Lacie of course)
OP William in Canada Forum Member • Posts: 99
Re: Area....?
Do you mean AF-C?
make sense
Do you think my attached pictures have focus issue? I feel it is a bit blur
Nikon D7000
Mako2011
DoF
For the conditions, handheld and tight DoF given the subject distance, about what I would expect for that setup.  The 18-105 is can be a bit soft until closer to f8...but it's a convenient zoom and pretty cost effective
