Shutter broken after 105.00 shots, isn't that too early
Started May 16, 2021 | Discussions
Ed Agter Regular Member • Posts: 300
My 750D shutter is broken. How many shutter movements can the Canon 750D make at least? My shutter broke after 105,000 shots. Isn't that too early?
I thought I could make at least 150,000 shots.
Ed Agter The Netherlands
 Ed Agter's gear list:Ed Agter's gear list
Nikon D850 Nikon Z9 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 800mm f/5.6E FL ED VR Nikkor AF-S 300mm f/4E PF ED VR
Canon EOS Rebel T6i (EOS 750D / Kiss X8i)
Digirame Forum Pro • Posts: 41,857
Re: Shutter broken after 105,000 shots, isn't that too early?
The shutter being broken after 105,000 shots, is within the range of expectation from what I read.  If you had time, you could try to change the shutter yourself, with some help from YouTube.  I only took a P&S camera apart once.  Taking apart a DSLR camera looks a lot more difficult.
Lepewhi Senior Member • Posts: 2,105
Re: Shutter broken after 105.00 shots, isn't that too early
Well, having your camera repaired will probably be cheaper than a new camera.
Slippery when wet.
 Lepewhi's gear list:Lepewhi's gear list
Panasonic Lumix DC-GX9 Panasonic Lumix DC-G100
mdmarqphoto Senior Member • Posts: 1,460
A quick Google search says the shutter on the 750D is rated for 100,000 actuations.  Sounds like you did ok.
 mdmarqphoto's gear list:mdmarqphoto's gear list
Canon PowerShot S5 IS Casio Exilim EX-ZR800 Canon EOS M Canon EOS 90D Canon EF 85mm F1.8 USM +7 more
tkbslc Forum Pro • Posts: 17,523
It was about a $750 camera when new.  So that’s 133 pictures per dollar paid.  Pretty good value, I’d say.
OP Ed Agter Regular Member • Posts: 300
Thanks for the information. Replacing the shutter is about € 200.00 in our country.
YIKES!! A lot of money, but still cheaper than buying a new camera.  If you like it, repair it.
Slippery when wet.
€ 200 is cheap for a 750D
The decision making process right now just needs to be "do I want to buy a used 750D for € 200?".   Because you can get a working 750D for that price after repair.   The cheapest I see on Ebay are quite a bit more expensive than that.  So if you like the camera, that seems like a bargain.   If you do not repair it, any replacement camera is likely to cost a lot more as well.
