Pentax 50mm 2.8 FA Macro...
Started 2 months ago | Questions
TomWret
TomWret Veteran Member • Posts: 4,162
I'm looking for a lens hood. It appears to be an internal screw lens mount. Where to buy?
Thanks, Tom W
 TomWret's gear list:TomWret's gear list
Pentax K-1 Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Pentax smc FA 31mm F1.8 AL Limited Pentax smc D-FA 100mm F2.8 Macro WR Pentax smc D-FA 50mm F2.8 Macro +7 more
KPM2 Senior Member • Posts: 1,366
Re: Pentax 50mm 2.8 FA Macro...
Hello TomWret
Thanks, Tom W
The FA 50mm and FA 100mm macros, have there front lens a little inside of the lens, therefore it's like they already have a lens hood. I use always a lens hood with my lens, but never need one with this lens, maybe sometimes my hand in extrem situations.
If you need a hood, the lens has a 52mm filter diameter.
best regards. KPM2
TomWret
OP TomWret Veteran Member • Posts: 4,162
Thanks KPM2, you know I ordered a 52mm lens hood and still have it but it does not fit...go figure.
Tom W
iso rivolta Contributing Member • Posts: 845
Thanks, Tom W
Hi Tom,
Look at the first two links, on the F and FA versions, it says no hood required but also that the RH-RA52 clip-on hood is compatible with the FA. This is a short hood made of rubber.
http://kmp.pentaxians.eu/lenses/normal/f50f2-8-macro
http://kmp.pentaxians.eu/lenses/normal/fa50f2-8-macro/
https://ricohimagingstore.com/hood-rh-ra52-s0034764.html
In my opinion, the 50mm macro could hardly make use of a normal hood. When shooting at large distances the front element is shaded by the helicoid front. When shooting at close to 1:1, the front elements is almost exposed but the working distance is small. Maybe the short and flexible hood will work.
The D-FA version is using another hood, PH-RBC 49mm.
 iso rivolta's gear list:iso rivolta's gear list
Pentax K-3 II Pentax KP +3 more
TomWret
Much thanks iso for answering my question.
Tom W
