Considering an x100t, have a question.
Started May 15, 2021 | Discussions
karuzo1
karuzo1 Regular Member • Posts: 166
Hello all,
I own several Dslr’s for semi professional work. So I’m looking for a different camera to carry with me.
‘the musts are:
fixed lens, and with aperture ring.
shutter control knob.
Found that the x100t might fit the bill for this purpose.
my questions are:
can you view in evf in real time the result of changing the aperture?
is there any other camera you’d recommend other than the x100t, must be fixed lens, as I don’t want to start investing in lenses, so the x-pro is our of the question. I would definitely consider earlier models if all I listed applies. Would you recommend the x100t?
thank you.
Doron
 karuzo1's gear list:karuzo1's gear list
Nikon D700 Minolta DiMAGE S414 Olympus C-8080 Wide Zoom Nikon Coolpix S01 Nikon Coolpix P7800 +14 more
Fujifilm X100T
The Lamentable Lens Senior Member • Posts: 1,112
Re: Considering an x100t, have a question.
karuzo1 wrote:
Hello all,
‘the musts are:
my questions are:
I have a later model X100, and I've not used the X100T, but according to the manual, yes, the EVF display "gives you a preview of the final picture (including depth of field...)."
You can also assign "Preview Depth of Field" to a Fn button. Pressing it will adjust the aperture to your setting and preview it in the EVF.
The X100 series is certainly well-regarded, and it's a fine choice. The Ricoh GR series is often compared to the X100 series because it's another small, fixed-lens APS-C camera. But as someone who has used both cameras, I can attest that they're very different animals (the GR is meaningfully smaller than the X100, which is nice, but it has no EVF, and no aperture ring, and it has a wider lens).
The other option would be the Panasonic LX100ii ,which I've not used. That's a micro four thirds camera, so it's a smaller sensor than the X100, but you pick up a zoom lens (24-75mm eq.) along with IBIS, and it's a bit smaller/lighter than the X100T. It's a bit odd in that it has a marked aperture ring on a variable aperture lens, but I suppose that's easy enough to get used to with time. Here's a spec comparison of the two cameras.
 The Lamentable Lens's gear list:The Lamentable Lens's gear list
Sony a7R III Sony a7C Sony FE 85mm F1.8 Sony FE 24-105mm F4 Sony FE 135mm F1.8 GM +9 more
(unknown member) Contributing Member • Posts: 726
With mirrorless cameras in general the EVF is WYSIWYG. You see all exposure, color, DOF in the EVF. This is why I stopped using DSLR. It takes a little while to get used to.
Of course the X-100 series also has the option of  viewing through the rangefinder style optical view finder at the flick of a switch.
Recommend the X-100 F.
Foxjet Contributing Member • Posts: 987
The X100T meets your requirements and is a fine carry anywhere camera. I bought mine when they first came out to do street photography and found it good for landscape and all around work. If buying today I would look at the X100V as the latest model is a sweet shooter.
 Foxjet's gear list:Foxjet's gear list
Fujifilm X-T3 Sony a7R V
karuzo1
OP karuzo1 Regular Member • Posts: 166
Thanks. After posting I went ahead and purchased the x100f.
karuzo1
The Lamentable Lens wrote:
karuzo1 wrote:
Hello all,
‘the musts are:
my questions are:
Thanks. As I own a mirrorless I should have known that. Thanks.
karuzo1
Thanks Richard. For my needs and budget, I went ahead and ordered the x100f.
Hope you enjoy yours as much as I do mine!
karuzo1
I know I will. Thanks.
uniball Veteran Member • Posts: 3,075
Interesting responses. After 4 of these gems, I must not know how to set them up.
The camera meters and focuses wide open. That’s default, as shipped by Fuji. A half press shows you dof. Release the half press and you can watch the iris slowly open up. Perhaps there’s a way to change this?
DarnGoodPhotos Forum Pro • Posts: 11,881
karuzo1 wrote:
Hello all,
‘the musts are:
my questions are:
thank you.
Doron
Do you plan on shooting a lot of high-ISO (1600 and above) JPGs of people?
The X100T is the earliest model from that line that I would suggest; it has a lot of handling and viewfinder improvements over the S. The first X100 had a unique 12MP sensor which a lot of people like but its AF is slower and its viewfinder isn't as good. Also, the cost of a used T is not much higher than a used S.
The other Fuji fixed lens cameras are the X70 and XF10 but they don't have viewfinders.
Personally I think you should stump up for the X100F, but if not the X100T is a great camera and fairly inexpensive used.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
karuzo1
DarnGoodPhotos wrote:
karuzo1 wrote:
Hello all,
‘the musts are:
my questions are:
thank you.
Doron
Thanks. I actually ordered the x100f. Getting it try all sort of shots, mainly excited about the film simulations.
karuzo1 wrote:
Hello all,
‘the musts are:
my questions are:
thank you.
Doron
Thats great, the F is a fantastic camera. Update your firmware once you receive it.
karuzo1
karuzo1 wrote:
Hello all,
‘the musts are:
my questions are:
thank you.
Doron
Thanks for pointing out. Will do.
karuzo1 wrote:
Hello all,
‘the musts are:
my questions are:
thank you.
Doron
Go ahead and research parallax correction and the frame lines in the F's OVF.
