Re: BEST BACKPACK / RUCKSACK FOR HIKING PHOTOGRAPHERS (2021, Post 3)
starfly wrote:
Well, I received the Quechua MH500 40L today. It's a nice backpack, but a few things I think will be a challenge with it, primarily making it work with a tripod.
They don't have deep side pockets where you can stash a tripod. And in the front mesh part you could put a tripod, but I'm uncertain about the durability of that mesh in the long-run if I keep putting a tripod there.
Yes, this was covered in my article, tripod feet will tear the mesh, often sooner than later. With this pack and many others we tested, the best way to attach a tripod is with the hiking poles attachments (if your tripod is heavy, slide the lower part of one foot behind the lower side compression strap, then wrap the whole thing with the bungee.) It's slightly off center and does not affect balance when the pack is properly fitted (it's a TMP.) You can also stick it horizontally under the lid if you like.
There's one trick I forgot to add, which is used by a few folks in our community. You can actually stick a tripod inside a mesh pocket if you keep it inside its bag (but that's not something most want to bother with on the trail) OR, use this method:
Make a cut around an empty 1.5 liter plastic bottle about 8 inches up and throw the top in the recycling can. Flip the bottle and drill 3 small holes in the bottom. You now have a round-ish, self-draining receptacle for your tripod's feet, which you can insert inside a side or central mesh pocket. This rounded shape will help the mesh last far longer.
My Peak Design Medium Cube does fit in it, though it's a tight fit of course. And I think with any ICU used in this pack, fitting a laptop in the bladder compartment will be a very tight fit. Far from ideal
Also, the TMP suspension back doesn't leave a lot of space between the pack itself and the mesh/your back. Just very little, to be frank, so I doubt it will keep you as cool as some of the other TMP packs.
I just double checked all the notes I have on the daypacks' testing and this was not an issue for anyone who tested the Decathlon MH500 (the only under-performing was with the Zulu which cooling wise is not much better than a PP pack.)
It's possible that the frame on yours was "flattened" during shipping or stocking. Feel inside the bag to find the vertical parts of the frame and curve them a bit more to add more space behind the mesh.
I just looked over an in-depth video of the Photohiker 44 (in German, which I don't fully understand, but the video itself speaks volumes). And, I've decided to order it. Looks like a great pack, and the included ICU should fit my needs.
In fact, I'll also cancel my pre-order for one of the Atlas packs, as I think the Photohiker 44 will overall be a better pack
I agree, it's not even a contest here.
(especially in hot climates!).
It also works great as a ski pack (see my review.)
I'll just need to use a black sharpie to color in the Photohiker branding, as I don't want anything on there that screams it might be a photo pack
You must hike or travel in some really scary areas! LOL.
Sending you a PM shortly. Let's continue the conversation that way.
