Ignorance is bliss.
Started 1 month ago | Discussions
JustUs7 Senior Member • Posts: 2,160
Ignorance is bliss.
Before I really started investing time in learning photography, I didn’t know what I was missing.
I NEED a 70-200 f/2.8, but it ain’t in the budget. 😁 First concert for the kids since Covid started and now I know what I’m missing. F/6.3 at 240 just doesn’t cut it.
What lens did you not realize you needed until you started learning more?
Yes, need is a relative term (which is why I’m living with the higher ISO’s for now).
 JustUs7's gear list:JustUs7's gear list
Canon EOS RP Canon EOS Rebel SL1 Canon EOS 1000D Canon EOS M6 II Canon RF 24-240mm F4-6.3 +7 more
Laotze Forum Member • Posts: 78
Re: Ignorance is bliss.
I consistently feel the need for more light collection ability as well... Even switching to the fastest primes will only get me around 1 more t-stop right now. Damn you physics!
So, I started looking at other solutions. Have you checked out Topaz Denoise A.I.? It might be a suitable stopgap for you until you bite the bullet on the faster glass.
 Laotze's gear list:Laotze's gear list
Canon EOS R5 Canon RF 15-35mm F2.8L IS USM Canon RF 28-70mm F2L USM Canon RF 70-200mm F2.8L IS USM
MediaArchivist
MediaArchivist Veteran Member • Posts: 5,599
Nifty fifty
A stereotypical answer, perhaps?
A friend I respect recommended I buy one and shoot with it exclusively for a while. So I bought a 50/1.4, and used it (almost) exclusively for a few months (I take several sets of photos every week). Not only did I learn how important a nifty fifty is for the type of work I do, using it exclusively taught me quite a bit about photography!
Want a roXplosion!?
 MediaArchivist's gear list:MediaArchivist's gear list
Sony a99 II Sony 24mm F2 SSM Carl Zeiss Distagon T* Sony 135mm F2.8 (T4.5) STF Sony Carl Zeiss Planar T* 50mm F1.4 ZA SSM Tamron 15-30mm F2.8 +25 more
OP JustUs7 Senior Member • Posts: 2,160
Re: Nifty fifty
I have an 85 f/2 I brought. Just wasn’t close enough. Used it for some though.
bastibe Regular Member • Posts: 417
My fastest lens is f/2.4. Through many experiments, I discovered that I don't need super-fast lenses.
 bastibe's gear list:bastibe's gear list
Ricoh GR Panasonic LX100 II Fujifilm X100T Fujifilm X-T2 Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR +3 more
Phil A Martin
Phil A Martin Veteran Member • Posts: 4,970
I've bought plenty of lenses I thought I needed but eventually rarely used and my "learning" actually increased, when I bought a TLR with a fixed lens, so I could concentrate on making images, rather than fretting about which focal length to use.
Wingsfan
Wingsfan Contributing Member • Posts: 513
After my kids took up competitive swimming, I realized I needed a weather sealed f2.8 telephoto (natatoruims are not well lit places, plus splash and moisture intrusion issues).
I ultimately ended up with an F 2.0 zoom to complement my f2.8 lenses, which was really great as a portrait lens also.
I shoot m43, so while people shooting full frame might be able to safely use F 4.0, or crank up the iso, the F 2.8 & F2.0 zooms gave me the safety buffer I needed.
At this point, I rarely use primes or kit lenses.
 Wingsfan's gear list:Wingsfan's gear list
Olympus XZ-1 Canon PowerShot G7 X Nikon Coolpix S9100 Nikon Coolpix 4100 Panasonic ZS100 +17 more
lilBuddha Veteran Member • Posts: 6,201
My learning, and results, increased when I started using primarily zooms. Wide angle zooms, in particular. Experimenting with different focal length and distance combinations opened up much creativity.
yardcoyote Forum Pro • Posts: 13,597
A real macro lens.
Instagram: @yardcoyote
 yardcoyote's gear list:yardcoyote's gear list
Fujifilm X10 Fujifilm X100T Pentax K-5 IIs Fujifilm X-T10 Fujifilm X-M1 +18 more
Glen Barrington
Glen Barrington Forum Pro • Posts: 21,672
Yes, and I'm incredibly happy.
The Olympus Zuiko Pro 12-40 f/2.8! Before, I made do with the DSLR 14-54 (which I still love), and the native kit, Zuiko 14-42 f/4. (great walking around lens, but I tend to walk around with the other two)
But after I got the 12-40, I realized I NEEDED an optional add-on grip for my E-M5 III.  I'm trying to maintain my ignorance for as long as I can!  It's cheaper that way.
 Glen Barrington's gear list:Glen Barrington's gear list
Olympus OM-D E-M10 II Olympus E-M5 III Olympus Zuiko Digital 14-54mm 1:2.8-3.5 Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 +11 more
yardcoyote wrote:
A real macro lens.
Not going to lie. I have a couple half macro lenses that have created quite an itch. That new RF 100 1.4x macro isn’t helping.
Near as I can figure, I’m about $7,500 shy of true happiness.  But then I’ll need to upgrade my camera body.
Maybe I’ll pick up some:
YWG Senior Member • Posts: 1,076
I didn't start off with a kit lens. I started off with faster primes, F2.8 zooms. I had always read how one should upgrade from the kit for superior image quality. As I got away from low light venues and more personal travels, I found during the day I was stopped down. I decided to give a run of the mill 18-55mm a try and then later 14-42 and 12-32 in m43. They were surprisingly good and saved weight.
The last few years I've tapered into low amplitude event work. Just documenting things at the job. I used to be bothered to carry a 70-200mm F2.8 equivalent but all the images get squashed down into newsletters and webpages. So, I just ended up carrying a 75mm F1.8 (150mm equiv). Take a few steps back or forward. Toggle the 2x digital teleconverter for 300mm equiv which takes a 5MP cut of the 20MP image and upsizes. I still have the original file where I can do my own crop but for quick turn around, the quality is very good.
 YWG's gear list:YWG's gear list
Canon PowerShot G5 X Olympus Stylus 1s Olympus E-M1 Olympus E-M1 II
KCook
KCook Forum Pro • Posts: 19,581
I often lust after specialized lenses.  But end up rarely using them.
ohwell
 KCook's gear list:KCook's gear list
Canon EOS 50D Olympus PEN E-P5 Panasonic G85
John Crowe
John Crowe Senior Member • Posts: 1,186
Thirty-eight years in, I have always known what I needed.  It has always been,  "how can I afford it?"
Now, I am only one or two away from my perfect set.  It has been quite an evolution.  I bought a used Canon FD 800mm f5.6 L, a few years back, mostly on a whim since it was so cheap.  I had always wanted one, really just for the heck of it.  I really didn't think it would benefit my photography and I did not anticipate keeping it, but it is now entrenched in my system.  Relying on it allowed me to rearrange my other supertelephoto lenses to better suit my other needs.
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Venus Laowa 12mm F2.8 Zero-D Kenko Teleplus Pro 300 AF 1.4x +15 more
Phil A Martin
ohwell
My point exactly.
john Clinch
john Clinch Veteran Member • Posts: 4,335
So you're saying that when you display the pictures of the event, however you intend to use them, they don't meet your needs? Or are you saying at 100% on screen they are a bit of a mess?
I work in a college and took some photos, of a concert, with a 70mm f4.5 lens on 12MP dx sensor. I thought they'd be fine on the web. I shared the processed images with the music teacher. Months later I found he'd printed them all A4 and made a display. They looked great
Phil A Martin
I can't imagine what anyone would shoot an an 800mm lens.
Bob
Bob Senior Member • Posts: 2,887
12
My big epiphany was realizing I needed studio lights for professional looking photos. Good lighting trumps all else (megapixels, lens quality, etc.).
Wildlife.  Outdoor sports. The moon. Thinking a little more about it, I can see a few instances where it would allow me to merge distant elements in the landscape.
Not worth the dosh for me, though.
Not even saying this.  I’m probably taking better event photos of my kids than I have at any point in their lives.  A little more understanding than I had before is making this possible.  I understand better the compromise between motion and visible noise, and I know which compromise is the more acceptable to me.
I just said, “ignorance is bliss”, in my op because I now have the knowledge that a couple extra stops of light via aperture vs pushing ISO would make even better images in that setting.  That knowledge reduces my happiness with the current images, even if only a little bit.
For my actual needs of preserving memories, they really are good enough.  Just doing a little drooling while window shopping.
I added it up.  $7,500 to $10,000 in NEEDS that just aren’t going to happen.  😁
