Lamp for Canon WP-DC54 housing
Started May 10, 2021 | Discussions
(unknown member) New Member • Posts: 2
Hello,
at the time I am using a Canon G7X with a Canon WP-DC54 housing for underwater photography. I am looking for a lamp to add to the Canon housing and am wondering what you would recommend. Ideally I'd like to mount it on the shoe of the housing. Do I need an adapter and a lamp for this or do you know any all-in-one solutions?
Best regards
Chris
Canon PowerShot G7 X
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
Re: Lamp for Canon WP-DC54 housing
If by lamp you mean strobe, the Ikelite AF-35 should work.  I used one on a Canon SD-630 back in the day.   It uses an optical sensor to trigger off a camera's pop-up flash.   Put diffuser on housing, turn flash power down for camera strobe, and adjust power of the AF-35 with a dial.
If by lamp you mean some sort of continuous focus light, the Kraken 3500 is good.
If by lamp you mean something for video, I don't know.
Phoenix Arizona Craig
www.cjcphoto.net
"I miss the days when I was nostalgic."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
OP (unknown member) New Member • Posts: 2
Thank you very much for your post. I mean a continuous focus light.
How would I mount the Kraken 3500 in the cold shoe of the housing? Do I need a flexarm, so that I can adjust the position of the light more easily or can I just use a small hot-shoe-YS adapter?
PHXAZCRAIG
I'd say you could do a hot/cold shot to ball mount (products are available), but that seems to me to be a little bit limited, and possibly risky to the housing mount. I have mine on a big rig on one of the posts and a clamp. I can rotate and lean it a bit - though I must say I normally just have it pointing straight ahead. But there are times I have the camera pointed sideways and the light pointed straight to light my way.
I'd rather have it on the end of a flex arm of some type for the added capability (flexibility of positioning).
By the way, I've only had two focus lights ever, the first in 2015. I had a Fishlite V24, which gave 2400 lumens of light. The Kraken 3500 gives 3500 lumens. Both had red lights as well, and the Kraken has a blue one. I normally just use the brightest white light - except for battery life.
On the V24, running at full power the light ran about 40 minutes. So I reduced the power on it a lot as I normally do hour long dives. The Kraken is much better. Full power the whole hour. I do then change batteries between dives, so buy a spare no matter what light you get.
The Kraken is around $500 - bright light plus battery life isn't cheap. It's also not really bright enough for video, though it works for macro distances. There are a selection of other lights at various price points here:
https://www.bluewaterphotostore.com/underwater/lighting/focus-lights
If you want to see how mine is mounted, you can pick it out of these images of my rig:
https://www.cjcphoto.net/uwcamera/all.html
www.cjcphoto.net
kelpdiver Veteran Member • Posts: 5,564
chrisr340000 wrote:
Hello,
The cold shoe mount keeps the light a bit close to the lens, though with a longer one and a 6" arm, can have reasonable set up positions.
https://www.backscatter.com/Nauticam-Strobe-Mounting-Ball-for-Cold-Shoe-Long
I think you're better off going this route:
https://www.backscatter.com/Ultralight-Tray-for-Olympus-Canon-SandS-Polycarbon, can use the strobe arm as a handle as well. And it will work for any future compact camera housing.
unfortunately, the canon housing doesn't allow for 67mm screw ons, like the ring light from kracken.
