Fujifilm XF 70-300mm F4-5.6 compatibility question
Started 2 months ago | Questions
Geoff Winterman Contributing Member • Posts: 631
Can anyone confirm that the Fujifilm XF 70-300mm F4-5.6 can be used with the XF2X TC WR teleconverter?
robert1955 Veteran Member • Posts: 5,815
Re: Fujifilm XF 70-300mm F4-5.6 compatibility question
Yes, there are examples in several threads by Baobab and earlier by iRanN
Helmers, Helmers, Helmers & Kinker
Attorneys at lost causes. Also forgettable poetry
 robert1955's gear list:robert1955's gear list
Fujifilm X-E3 Samyang 12mm F2.0 NCS CS Fujifilm 16-55mm F2.8R LM WR
baobob
baobob Forum Pro • Posts: 16,346
Yes, but  the results are not quite good with the 2xTC, leading to a loss of contrast and sharpness, a mushy rendition
The results however are different according to the distance: for near to close , with a good denoise software it is ok At far distances the results are really mediocre better to crop from the lens + 1.4TC
With the 1.4TC the results are good with a moderate loss of sharpness (see my posts)
Sony RX100 Olympus Tough TG-4 Panasonic ZS200 Fujifilm X-H1 Fujifilm X-T3 +10 more
OP Geoff Winterman Contributing Member • Posts: 631
Thanks for the assurance as well as the comments about the two converters- interesting.  I have the 100-400 with the x2 converter but due to my age and its size and weight it doesn't get enough use.
Except for fairly frequent imaging of the sun in my search for sun spots! (I would add - with the appropriate filter!)
I am planning to sell or trade in the "Big Boy" and go for the 70-300.
Craig268
Craig268 Senior Member • Posts: 1,573
Fear not, as the 2x TC works great.   Keep in mind, all TC's create some loss of IQ and the larger the TC, the more IQ loss can occur.
However using a TC is still usually preferable to enlarging an image taken without a TC. As expected, a smaller TC, i.e. a 1.4x will yield images with better IQ than with a longer 2x TC.
However, images with a 2X TC are usually perfectly acceptable and with just a bit of post work i.e. some sharpening, such images are just fine.
Fuji's 2X TC doesn't get a lot of love but with it's limitations (as with any TC) and applying a little post work, images are still excellent.
I use it regularly with my Fuji 100-400 with no complaints and the 2x TC will work well with your 70-300.
 Craig268's gear list:Craig268's gear list
Fujifilm X-T1 Fujifilm X-T10 Fujifilm X-T4 Fujifilm XC 16-50mm F3.5-5.6 OIS Fujifilm 50-230mm +8 more
Morris0
Morris0 Forum Pro • Posts: 20,442
XF 70-300mm with 2x example
Yes, great results are possible
This combination is unforgiving and requires great technique, particularly with the sub standard OIS of the Fuji 70-300.  Expect a lower than usual keeper rate when using this combination, yet when it works it's sweet.
Morris
Fujifilm X-T3 Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR Sigma 150-600mm F5-6.3 | C XF 90mm Fujifilm 50mm F2 R WR +12 more
baobob
Re: XF 70-300mm with 2x example
Morris
I don't agree about OIS that I find excellent about 5 stops, even with the 1.4TC I can shoot at quite slow speeds
hectorpatrick Regular Member • Posts: 177
"sub-standard OIS of the Fuji XF 70-300" is quite a bold statement - any evidence for it?
 hectorpatrick's gear list:hectorpatrick's gear list
Fujifilm X100V Pentax K-1 Pentax smc DA* 300mm F4.0 ED (IF) SDM Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR +5 more
Morris0
I'm not the only person to have complained.  Lower your shutter speed and watch what happens.
Morris
baobob
It is not all my experience I find OIS really excellent like many reviewers as well...
An issue with the copy ?
Sub-standard implies there is a standard to which the IS can be measured.
Below are four images taken handheld with the 70-300 with TC1.4 and X-T4 from 1/250 to 1/15 - I would suggest that in the circumstances the IS of the system is good by any standard (allowing for image degradation from the uploading process here):
1/250
1/125
1/60
1/15
Morris0
1/250
1/125
1/60
1/15
Thank  you for demonstrating the problem.  Only the first image lacks motion blur.
Morris
Morris0
I like this lens as it's light and very sharp.
I wondered about having a defective copy yet Hector just demonstrated the pore OIS:
https://www.dpreview.com/forums/post/65117421
Morris
Samuraidog Contributing Member • Posts: 936
It does better with the 2xTC than the 100-400 IMHO.
 Samuraidog's gear list:Samuraidog's gear list
Fujifilm X-E2S Fujifilm X-T30 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +10 more
baobob
Substandard OIS really ?
SOOC JPEG
baobob
Not at all my experience...
baobob
Tack sharp 1/20 sec at 420mm
SOOC JPEG
baobob
I agree, usable at mid distance nor far distance
baobob
Re: Tack sharp 1/25 sec at 600mm
SOOC JPEG
Morris0
baobob wrote:
SOOC JPEG
Hi Bob,
Are you using the electronic shutter?
Morris
