Sound absorbing mat or isolation pad for desktop PC
ggeinec Contributing Member • Posts: 784
I'm looking for some kind of sound absorbing mat or isolation pad (or material) to slip under my desktop PC so that it doesn't transfer a low level hum to the desk.
Ideas?
Thanks!
sludge21017
sludge21017 Senior Member • Posts: 2,840
Re: Sound absorbing mat or isolation pad for desktop PC
Probably some generic gym mat would suffice.  There are anti vibration pads for washing machines - but those are pretty thick...it would depend on your case feet if they fit.
Mine is on the carpeted floor, so no issues.
I know what you mean - I have had external hard drives hum irritatingly on my desk.. I'm like what is making noise now!?!!
NickZ2016 Senior Member • Posts: 2,300
Is this your fans? You might want to look at the fan profiles if you haven't.  In a newish system there isn't really anything else in motion.
 NickZ2016's gear list:NickZ2016's gear list
Nikon D800 Nikon AF-S Nikkor 50mm F1.4G Nikon AF Nikkor 35mm f/2D Nikon AF-S Nikkor 50mm F1.8G Nikon 85mm F1.8G +4 more
Billiam29 Senior Member • Posts: 2,001
On that note, I'll suggest looking into Yoga mats. They seem somewhat on the "reasonably thin" side. I've never owned one myself but I've seen a fair number of people cut them up for alternative uses like shelf or drawer liners.
SC489 Senior Member • Posts: 1,373
The foam insulation you use to sound deaden cars would work but you don't need much. I guess the sound is transmitted by the four feet. try putting a thick insulating material like a strip of foam draught excluder or felt under each foot.
 SC489's gear list:SC489's gear list
Sony Cyber-shot DSC-HX80 Panasonic Lumix DMC-GX7 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G Vario 14-42mm F3.5-5.6 II ASPH Mega OIS +4 more
Sean Nelson
Sean Nelson Forum Pro • Posts: 14,622
If you happen to have some bubble wrap lying around it would be worth a try.  Lots of Amazon goods come in bubble wrap envelopes.
One thing. If you have bottom air vents don't block them with something . Make sure the clearance stays the same or increases.
IanYorke Veteran Member • Posts: 4,580
Ideas?
Thanks!
Look for something like this as a replacement for the existing feet on the PC. Much neater than a mat.
https://www.amazon.co.uk/Hudson-Hi-Fi-Platinum-Hemisphere-Isolation/dp/B075KHNK62/ref=sr_1_28?adgrpid=54016985980&dchild=1&gclid=Cj0KCQjwytOEBhD5ARIsANnRjVj4lSzF-Hc45WCaG69pXKZHVoj7EiPAJh60vEu0hbS0hETwdiyur10aAtR5EALw_wcB&hvadid=259097241743&hvdev=t&hvlocphy=1007103&hvnetw=g&hvqmt=e&hvrand=16612253031312227834&hvtargid=kwd-336460589724&hydadcr=28176_1821089&keywords=sound+isolation+feet&qid=1620386959&sr=8-28
gscotten
gscotten Senior Member • Posts: 2,143
I'd recommend a barry mount. They make a million styles and sizes. Vibration reduction is what they are designed for. In the old days, you could buy them at any music store. I have some somewhere that I used under my turntable to minimize feedback from my speakers.
George
 gscotten's gear list:gscotten's gear list
Canon EOS RP Canon RF 24-240mm F4-6.3
sam45
sam45 Regular Member • Posts: 440
Rubber feet or bumpers. Minimizes contact, so less transfer.
 sam45's gear list:sam45's gear list
Sony RX100 V Sony a7R Sony a6000 Sony a5100 Nikon 1 J5 +12 more
Sean Nelson
Never heard of these before, very cool.   Thanks for the tip!
charleyd Senior Member • Posts: 1,219
I use round rubber coasters under my sound bars. They stop the vibrations and they are cheap.
Jay J Hector Regular Member • Posts: 161
This is what I use for various sound isolation of devices:
https://www.amazon.com/BXI-Sound-Absorber-Absorption-Polyester/dp/B077Q2HYMW/ref=pd_rhf_ee_s_rp_c_3_2?pd_rd_w=ijhMd&pf_rd_p=26d392db-8b78-4d00-b33d-2981cba34f91&pf_rd_r=ABMGQKEVK81H932FJRQR&pd_rd_r=28c0fda6-b3ee-419c-bcf4-56b4d64ca278&pd_rd_wg=Nig7D&pd_rd_i=B077Q2HYMW&psc=1
BXI Sound Absorber - 16 X 12 X 3/8 Inches 6 Pack High Density Acoustic Absorption Panel, Sound Absorbing Panels Reduce Echo Reverb, Tackable Acoustic Panels for Wall and Ceiling Acoustic Treatment
skyglider Veteran Member • Posts: 5,872
Ideas?
On amazon do a search for "shock absorbing pads" and many styles will be found.  Pick one that suits you.
OP ggeinec Contributing Member • Posts: 784
... snipped ...
Thanks for your reply.
Yes, I thought about piecing off a small section, or one for each foot, of a gym or yoga mat but I don't have an old one of those lying around.
While searching I saw the anti vibration pads for washing machines and that certainly seems like overkill on several levels even if they would fit.
No, it's not the fans. It's a WD Black HDD that periodically spins up and then spins down again a while later when it goes back to sleep.
Overall the PC itself is very quiet. It's just that WD HDD that's sending out a subtle low level hum through the feet of the case when it's spinning. It's like low frequency tinnitus.
Yes, this basically is what I have been looking for, hoping I had something lying around here that I could repurpose that way but no such luck. It doesn't hurt to ping others for ideas I haven't thought of.
Funny, for kicks I tried cutting up one of those white Amazon bubble wrap envelopes for a temporary solution but that was too thin. Esthetics prevented me from adding layers . . .
IanYorke wrote:
Ideas?
Thanks!
I had seen those and others that are very similar. They come very close but I prefer not to use anything that has adhesive. It also seems, through my searching, that when I factor in the particular item of something like this that I need to support the weight of my case they are out of stock or quite expensive. This may be a temporary supply chain issue like with lots of other tech products.
skyglider wrote:
Ideas?
Yes, I have spent way too much time doing that. Unfortunately anything I have found so far that looks like it could be what I am looking for is out of stock, too expensive, or requires buying way more than I would use.
