Pentax Spotamatic F
Started May 5, 2021 | Discussions
Kalimetric Forum Member • Posts: 50
Pentax Spotamatic F
Hi, I have the opportunity to buy a Pentax Spotamatic F.
Although I've enjoyed taking pictures with the digital, I feel that film has this quality which surpasses the digital print.
So, I've been thinking of picking up a film slr to complement my digital.  Hopefully carry both bodies at the same time (I have a Pentax k50 already).
So, would the Spotamatic be worthwhile?  It comes with 150/4 and 28/3.5,  although I'm thinking that I would prefer a zoom lens that matches the kit on the k50.  Primes are good, but I always feel that composition is more precise on a zoom.
Pentax K-50
kypfer Contributing Member • Posts: 985
Re: Pentax Spotamatic F
8
Unless I really wanted to "get back to basics" I'd choose a camera with a Pentax bayonet mount, rather than a screw-mount, simply for the ease of lens handling, but if you feel you must, at least check that the meter is working and that meter batteries are readily available … else you'll be looking for a hand-held lightmeter as well
Good luck!
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
OP Kalimetric Forum Member • Posts: 50
Ah, this would be a gamble purchase.  It's being sold as an antique, so no way of knowing whether the lightmeter is working!
As regards lenses, I used to change them all the time, but recently I've been finding myself just sticking to the kit lens.  I think I've missed a lot of shots in the past due to trying to fit a shot into a prime lens.  I think I'm done with that.  So I would probably seek out an m42 zoom that goes from wide to middle.  Of course, I'd happily keep the 28mm around, but my shoulder can only take so much weight nowadays.
KentG Veteran Member • Posts: 4,825
The Spotmatic F is an M42 screwmount lens camera so you can't use K-mount lenses on it, although you can do the other way around. It also has aperture coupling with Pentax SMC screwmount lenses. I have a collection of those camera bodies and lenses. While its a very basic and capable system its not for beginners. You would be better off with a K-mount, and especially a K-mount AF camera so you existing Pentax lenses would be compatible. Problem is that those early Pentax AF cameras are likely to need work after so much time. If you just want to drop some film in a camera and see what develops (:-D) then the Spotmatic F would be fine. If that one lens is a Super Multi Coated Takumar 150mm F4 it is a very good lens, one of the best in that era according to many.
Kent Gittings
 KentG's gear list:KentG's gear list
Pentax K-3 II Pentax K-1 Canon EOS 80D Pentax smc DA 16-45mm F4 ED AL Sigma 120-300mm F2.8 EX DG HSM +7 more
The problem is that zooms in that era were not particularly good with a couple of exceptions.  There was little or no ED glass in those days. Zooms usually had restricted ranges because of that.
Kent Gittings
SmcTak New Member • Posts: 8
There aren't many good M42 zoom lenses, to put it lightly.
If you insist though, I'd recommend looking for Carl Zeiss Jena vario-pancolar 35-70 or hunting for Vivitar Series 1 28-90mm which I believe also came in M42 (but this is pretty big and heavy lens). Bear in mind though, that open aperture metering linkage on Spotmatic F may prevent some off brand M42 lenses from mounting (I had that problem with Mamiya Sekor 55/1.4). Can't say whether the aforementioned pancolar or vivitar mount without problems.
Another option worth considering is to get tamron adaptall adapter with M42 screwmount (Tamron made one with open aperture metering for Spotmatic F & ES) and go with one of the Tamron SP adaptall zooms.
From the lenses you mention, neither 150/4 nor 28/3.5 Takumars are what I'd call good lenses. The best Takumars which (are also affordable) are 55mm, 35mm 3.5 and 135/3.5, maybe also 200/4 (not sure what prices are these days). I'd especially recommend the 35/3.5, this is small, compact lens that is quite sharp and at least in Super-Multi-Coated version, handles flare surprisingly well.
Sjak
Sjak Veteran Member • Posts: 7,318
If you're looking to get back into film without too much complexity, a used ME or KM are very nice options in K-mount. In my experience, these have been extremely reliable.
 Sjak's gear list:Sjak's gear list
Leica M Monochrom (Typ 246) Ricoh GR IIIx Pentax K100D Pentax K10D Leica M-Monochrom +1 more
OK
In that case I can recommend the Tamron Adaptall-2 28-200mm https://www.pentaxforums.com/userreviews/tamron-af-28-200mm-f-3-8-5-6-xr-di-aspherical-if-macro.html as a good all-around lens. Try to find the model #171A (not the earlier #71A). It has relatively advanced aspherical LD optics and a polycarbonate body, so it only weighs 500gm!
I only retired mine when it developed fungus deep inside and I couldn't get it fixed
Good luck
Phil A Martin
Phil A Martin Veteran Member • Posts: 8,363
Period m42 fit zooms would be awful. Better to stick to the Pentax primes, that are noted for their quality.
Phil A Martin
For me, the whole point of using period cameras, is to use the lenses that came with it and in this case would be the Pentax M42 lenses, of which there are many.
Thanks, everyone - that's a lot of responses!  Looks like the zooms are not recommended then. Hmmm, maybe I'll just use the Spotamatic with primes then.  I think I already have a tak 55/1.8, plus a Zeiss 50, so well stocked in that department.  My real reason for changing over is green envy at the images produced on film.  They just look so much more real.
My reason for not looking at a Kx, Km, K1000 is that I am buying in Switzerland, and the prices seem to be quite high for those.  I'm just looking for something cheap to complement my digital.  Also, I've been shooting for 10 years or so, and did a small amount of large format photography, so I'm not completely new to the film world.  I wish I had bought into medium format when the prices were still low...
alex_virt Veteran Member • Posts: 3,044
If you are new to 35mm film and looking for a cheap camera, take a look at the Pentax MZ series. Very capable cameras with screwdriver autofocus, can work with modern-ish lenses, even those without aperture rings. The DA 35mm/2.4 and DA50mm/1.8 work perfectly with film, and you can use them on digital as well. If you want a zoom, I recommend the Tamron 28-75mm/F2.8. MZ cameras often come with battery grips for AA batteries.
There is an Achilles heel though – a plastic cog in the mirror control mechanism that can easily break. However, those cameras are very cheap and finding a new one is not a problem.
Phil A Martin
May I recommend the MZ5n or the MZ3. They are quite handsome cameras and function very similar to classic Pentax designs such as the MX and LX.
Okay, I'll take a look into this.  Shame about the plastic cog, though.  However, you're right about them being cheap - current bid on the auction site I use is 2 francs.
Phil A Martin
I've had mine for years without any issues
"Period" zooms may well be wanting, by today's standards, not that there were many, but Tamron was making M42-compatible lenses, via their Adaptall-2 system, well into the '90's and incorporated the latest technology of the day into the later-model lenses, you'll not be disappointed
I haven't experienced the problem myself, just read about it in reviews.
Phil A Martin
Yes I often wonder about reviews. Whether they are from people's actual experience or if they're repeating what they've been told
The other thing to consider is that the Spotamatic F just looks really nice.
I mean, if I look cool walking around with my camera, then my pictures will automatically look better as well, right?
Some of my photos here.
https://www.instagram.com/kalimetric/
Do you want checkers or ride? If you want a cool fashion accessory, definitely buy the Spotmatic – the most beautifully designed camera ever. If you want to actually take pictures, get something more modern.
