New Information on K3III
Started May 5, 2021 | Discussions
bclaff Forum Pro • Posts: 13,929
Re: Are these comparisons fair anymore?
DougOB wrote:
bclaff wrote:
Fotoni wrote:
Most of the cameras have noise reduction turned off, but some Pentax cameras have forced noise reduction. Why they are listed as equals in that table? At least put an asterisk mark next to them or something.
Interesting idea.
On the charts there are symbols to indicate things like noise reduction but the tables doesn't take this into account.
I'll think about this.
When do you qualify it as noise reduction?
I think I've covered this multiple times elsewhere. But hear goes ...
There are ways to detect nearest neighbor signal processing in the firmware.
(This is distinct from various noise reduction and signal shaping done in hardware.)
The chief tool hear is 2D Fourier Transforms.
I deem that signal processing as noise reduction when there is a significant drop in noise.
I cross check against an energy spectrum analysis.
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
brett nz
brett nz Contributing Member • Posts: 597
There was an informative article on dp couple years back showing two stage burnt in nr on modern cameras, all at that time kicking in around iso400. I will try to find it and link. Pentax was not the first or only one by any means.
 brett nz's gear list:brett nz's gear list
Pentax K-1 Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 77mm 1.8 Limited Pentax FA 70-200 F2.8 Pentax FA 150-450mm F4.5-5.6 +2 more
MarBa Senior Member • Posts: 1,038
No .. that is something else. Here this shows an unprecedented level of noise removal. Nothing comparable to any other camera. It's not just NR on/off it's also about how much and at what ISO.. and also about whether this is by increasing the gain of the sensor or it's done after A/D conversion.
 MarBa's gear list:MarBa's gear list
Pentax K-1 Pentax K-3 Mark III Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +6 more
