New Information on K3III
Started May 5, 2021 | Discussions
PhotoHawk Contributing Member • Posts: 849
5
Bill Claff has some information on his site - see https://www.photonstophotos.net/Charts/PDR.htm
Bill's graphs do not normalize ISO - he uses the vendors ISO. So its hard to compare DR across brands. However within brands its not a stretch to say that the ISO calibration is similar model to model. So the comparison of the K3III to a K1II or KP would be fairly representative of performance differential.
The DR points before the Accelerator adds NR looks similar (not identical) to the K3 I, II and KP. It appears that the Accelerator kicks in sooner than in the KP and is stronger in its application.  It appears 8 stops of DR (or more) is available all the way up to ISO 3200 (4000)
I would opine that the the DPReview Image Comparison tool would be somewhat similar to what we see in the KP but more so and a bit sooner in the ISO range. In fact the line looks very similar to the K1 II after ISO 800. That is not a bad thing at all!
For JPeg shooters it will be great. For raw shooters with access to state of the art NR tools like DXO, maybe not so much.  Still the performance in DR and noise is unlikely to disappoint!
Pentax K-1 II Pentax KP
The Squirrel Mafia
The Squirrel Mafia Senior Member • Posts: 1,017
Re: New Information on K3III
https://www.dpreview.com/forums/thread/4571492
^ There was a previous thread about this.
 The Squirrel Mafia's gear list:The Squirrel Mafia's gear list
Pentax K-3 II Pentax smc DA 21mm F3.2 AL Limited Pentax 11-18mm F2.8 Pentax DA* 16-50mm F2.8 ED PLM AW Pentax K-50 +10 more
Mark Ransom
Mark Ransom Veteran Member • Posts: 8,209
5
So the question is, how did they manage a score that's better than perfect?  They have some kind of super-secret NR going on, they won't describe it and they won't let you turn it off or bypass it.
 Mark Ransom's gear list:Mark Ransom's gear list
Pentax K-7 Pentax K-01 Olympus E-M5 II Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR +6 more
Kobie M-C
Kobie M-C Contributing Member • Posts: 701
It's signal processing that they have going on which happens to include NR as well, but there's more to it than just straight NR. Color correction at high ISO is also part of the signal processing. I just did a test comparing ISO from 100 - 1.6 million. (I skipped 12,800 by accident and went from 10,000 -25,600) between jpeg at default camera NR settings and DNG raw. The amount of detail the raw maintains is quite amazing and doesn't smear at high ISO how the jpegs do. The jpegs also seem to drop the red/magenta tone higher up in the ISO chain  (25,600). Loss of detail was much less evident with the raw files in comparison.
I'll upload them to my Flickr account tomorrow so you can all have a look.
I am not a Pentax insider. I just have a unique way of gaining insight.
 Kobie M-C's gear list:Kobie M-C's gear list
Pentax K-30 Pentax K-3 Pentax K-3 Mark III Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR Pentax smc DA 50mm F1.8 +6 more
Lotz Forum Member • Posts: 58
I asked the question to Bill, how he comes to that perfect DR curve, and he explained everything about the slope (which is absolutely clear) and that shot noise DR is poisson distributed resulting in a SNR of Sum(e)/Sqrt(Sum(e)) = SQRT(Sum(e)).
So the totplolgy of the curve is well explained and quite clear. ( i am also developping cameras for driver montioring and traffic sign recognition systems in automtive).
But I have no clue about the offset of the curve, why DR is limited to 11.57EV @ ISO 100. Is this based on a total electron flux? For me , that induces that there is an upper limit of FWC depending on sensor size, as with no read noise, DR translates to SQRT(FWC).
By the way, an equivalent full frame lens has ~2,25times the entrance pupil of an APSC-lens, thus 2,25x higher light flux. But this is projected on a 2,25x higher area, so the luminance denisty is the same. Per pixel you are integratin 2,25x the light assuming the same resolution, so that's why the DR of FF is ld(2,25) above that of APS-C. Everything clear, but the explanation of the absolute values is somehow missing. Unfortunately, the thread did not allow furhter posts, otherwise I had asked bill for that.
BR
Markus
 Lotz's gear list:Lotz's gear list
Pentax K-3 II Pentax KP Pentax K-3 Mark III Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 15mm F4 ED AL Limited +15 more
Sjak
Sjak Veteran Member • Posts: 7,318
Colour-correction is incredibly valuable! I can deal with noise als long as it's sort-of uniform, but I highly dislike colour-noise when I want to make a colour-pic.
Let's hope that this tech will also be put into the K-1 sucessor.
 Sjak's gear list:Sjak's gear list
Leica M Monochrom (Typ 246) Ricoh GR IIIx Pentax K100D Pentax K10D Leica M-Monochrom +1 more
JeremieB Senior Member • Posts: 2,041
I think this page from Bill's site is what you're looking after:
https://www.photonstophotos.net/GeneralTopics/Sensors_&_Raw/Sensor_Analysis_Primer/Engineering_and_Photographic_Dynamic_Range.htm
BR
Markus
 JeremieB's gear list:JeremieB's gear list
Pentax K-70 Pentax K-3 Mark III Pentax smc FA 50mm F1.4 Pentax smc DA 18-55mm F3.5-5.6 AL Pentax smc D-FA 100mm F2.8 Macro WR +9 more
MarBa Senior Member • Posts: 1,038
Yes .. let's hope it is in the K-1 III, however, with the possibility to control the process. You know, give the user the option to use the camera creatively, choose what functions are on and off .. like with so many other features on Pentax cameras! That is why we love them ... it's the flexibility!
 MarBa's gear list:MarBa's gear list
Pentax K-1 Pentax K-3 Mark III Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +6 more
Sjak
I'm not quite sure what kind of feature you refer to, possibly due to my ignorance on the subject.
Do you have examples of camera's with features that allow tuning of the proces of the signal-to-raw-file?
As for using the camera creatively, I believe that's the user's responsibility, not the manufacturer's
I am not so sure, as this is all based on the Nikon D300 photon transfer curve, which for sure does not represent an ideal form of a sensor.
He is stating something of 14EV as an endpoint, which might result from 14bit AD-values, but take into account, that for a white level, you have 3 stimuli adding to the total value, not just one! So maybe, there is a value of ld(3) missing. Green is not white!
Also in display metrology, white is way brighter than one of the three primaries, which sum up to white, in the end.
Color matrix calculations always take into account all three primaries for the total integral flux, that's why color matrices are 3x3 matrices.
BR
Markus
Kobie M-C
I couldn't upload the DNG's to Flickr so here's a google drive link to the folder of all 30 images jpeg and DNG at default NR levels right out of the camera.
https://drive.google.com/drive/folders/1JAUo-csVGKrYh6s7_6gMI-gUre793v0P?usp=sharing
bclaff Forum Pro • Posts: 13,929
Lotz wrote:
But I have no clue about the offset of the curve, why DR is limited to 11.57EV @ ISO 100. Is this based on a total electron flux? ...
Yes, there is a formula that relates ISO to flux.
Which implies a Full Well Capacity (FWC) per unit area.
If you can achieve more FWC per unit area then your base ISO can go down.
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
Mark Ransom
Yes, but that's limited by the aspects of the camera that can be controlled by the user.
Imagine if Pentax decided they had perfected auto exposure and removed the ability to set your own aperture or shutter speed.  Do you think anybody would accept that?
Tibor1 Regular Member • Posts: 131
Thanks for uploading the samples Kobie M-C, much appreciated!
Indeed, pretty amazing perceived detail/noise ratio in DNG files as well as the color consistency!
Perfectly usable auto ISO 100-6400 in real life for me. Cool.
This is exactly what I wanted to see - I have no plans to study single pixels under 200 percent magnification taken by apsc format camera. Using a cropped sensor camera somehow motivates me to concentrate much more on the process of taking the picture - enjoying the moment of photography. It's much less about spending hours behind my monitor doing post-processing.
Well done Pentax.
Tibor
Hi Bill,
thanks for your pateint replies. That can take me a step further
Do you have a soruce, where I could find that formular correlating ISO to total flux? that would be very interesting for me.
Thanks in advance
Markus
Fotoni Senior Member • Posts: 1,091
Are these comparisons fair anymore?
Most of the cameras have noise reduction turned off, but some Pentax cameras have forced noise reduction. Why they are listed as equals in that table? At least put an asterisk mark next to them or something.
The thing about noise reduction is that people have different preferences and algorithms evolve all the time. Those Pentax cameras do not allow you to enjoy from that flexibility.
 Fotoni's gear list:Fotoni's gear list
Pentax K-1 Pentax FA* 50mm F1.4 SDM AW Canon PowerShot SD4000 IS
Lotz wrote:
Hi Bill,
Thanks in advance
Markus
S = 10 / H
where S is ISO speed and H is lux-seconds
This is at 18% saturation
Re: Are these comparisons fair anymore?
Interesting idea.
On the charts there are symbols to indicate things like noise reduction but the tables doesn't take this into account.
I'll think about this.
Thanks, Bill.
DougOB
DougOB Veteran Member • Posts: 3,176
bclaff wrote:
Interesting idea.
When do you qualify it as noise reduction?
Pentax has a history/reputation of getting better results out of a sensor (e.g., on K-5, K-1) than other camera manufacturers (e.g., Nikon, Sony).  This well pre-dates the accelerator chip. So they are doing better signal processing than others.  Is this noise reduction?
In the past this was seen as a selling point, not a concern.
Have they simply upped their processing and with the accelerator chip are simply applying it to varying degrees at different ISOs?
Measurements might suggest that X is going on, but maybe it is Y...
My thoughts,
Doug
 DougOB's gear list:DougOB's gear list
Ricoh GR IIIx Pentax K-3 Pentax Q-S1 Pentax K-70 Pentax KP +36 more
