American White Pelican
Started May 4, 2021 | Photos
larryj Forum Pro • Posts: 13,086
7
From the archives taken with the SD14 and the 150-500 mm OS lens.
Enjoy!
larryj
If you can see the light, you can photograph it
Quote from Myron Woods
 larryj's gear list:larryj's gear list
Sigma SD1 Merrill Sigma 24-70mm F2.8 EX DG HSM Sigma 150-500mm F5-6.3 DG OS HSM Sigma 105mm F2.8 EX DG OS HSM Sigma 18-35mm F1.8 DC HSM Art +1 more
Comment & critique:
Sigma SD14
Rudi Senior Member • Posts: 2,047
Re: American White Pelican
Enjoy!
Great shot with lots of details, Larryj.
BTW did you ever have the "freeze" problem with your SD14 ?
Rudi.
OP larryj Forum Pro • Posts: 13,086
Rudi wrote:
Enjoy!
Thanks for your kind comments Rudi: They are very much appreciated
Rudi.
Yes I did have the "freeze" problem on a few occasions, but found that removing the battery and reinstalling it fixed the problem.
larryj
Scottelly
Scottelly Forum Pro • Posts: 18,026
Rudi wrote:
Enjoy!
I did, but I was able to do entire shoots with models sometimes, and it didn't happen, so it was definitely not a big problem for me. I don't think I would have trusted that camera to shoot a wedding or some other special event though. It would definitely suck for it to freeze right at the wrong moment.
Rudi.
Scott Barton Kennelly
https://www.bigprintphotos.com/
 Scottelly's gear list:Scottelly's gear list
Sony SLT-A65 Nikon D810 Sigma sd Quattro H Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR Sony DT 18-55mm F3.5-5.6 SAM +27 more
Ceistinne
Ceistinne Veteran Member • Posts: 3,256
I had the "freeze problem" with my SD14 but after ensuring that the earth points were all raised slightly to touch the baseplate the problem disappeared and has worked perfectly ever since.
S
 Ceistinne's gear list:Ceistinne's gear list
Sigma SD1 Merrill Sigma dp2 Quattro Sigma SD9 Sigma SD10 Sigma SD14 +5 more
American White Pelican and SD14
larryj wrote:
Rudi wrote:
Enjoy!
Rudi.
Hello Larryj,
many thanks for your reply. After I bought my SD14 and used it for about a week or so, I also recognized the "freezing" problem with the same symptomes you described.
A search in the SIGMA forum here was really helpful and effective. There was a gentleman from Finnland who had put up some pictures for a cure of the problem.
Tried it out and my SD14 still works how it is supposed to be, until today. Freezing is caused by bad ground connections on the memory board of the camera.
So here those pictures in case somebody wants to try an old SD14 and has problems with the camera freeze :
(Just took off the bottom plate and solder in a few 0,75mm flexible wires and the damned thing works pefectly.)
Additional wires, where the red lines are drawn.
May be someone can use it.
Rudi.
