AF lock on Lumix G7 G85 etc
Started May 3, 2021 | Discussions
Summitron Regular Member • Posts: 342
On all my Lumix cameras, the AF lock works for video, I lock the focus, hit the video button and the focus is locked. I can turn the focus ring &c and the focus stays the same (great for prevented ruined shots when the camera is adjusted or bumped).
However, in pinpoint mode, when I hit the record button after locking, the AF hold is cancelled. I'd really like to be able to use the focus magnifier with pinpoint mode and lock it down, Anyone know a workaround? Tx.
 Summitron's gear list:Summitron's gear list
Sony a7S II Panasonic Lumix DMC-GX85 Panasonic G85 +5 more
Panasonic G85 Panasonic Lumix DMC-G7
alcelc
alcelc Forum Pro • Posts: 19,006
I think you can
Set AF+MF = OFF, MF Assist = OFF.
Albert
** Please forgive my typo error.
** Please feel free to download the original image I posted here and edit it as you like **
OP Summitron Regular Member • Posts: 342
Re: I think you can
Thanks for your answer. In pinpoint mode, the AF lock button *says* it is locked after pressing, but hitting the record button (for video) unlocks it, even after using those settings. Not the end of the world, but it would be nice if it worked.
alcelc
Re: I think you can
Could you use single focus box option in its smallest size?
Albert
alcelc
Re: I think you can
Could you try using single focus box and in its smallest size?
Albert
Re: I think you can
Good idea, not exactly the same but similar. Tx.
