Femme views forest! - or: Where would *You* put the focus plane?
Started 4 months ago | Polls
wood_gnome
wood_gnome Regular Member • Posts: 134
Hi!
Here is a little focus bracketing sequence. Where would *You* put the focus plane? And why would You do so?
1. hairs end - closest to camera
2. closer to the hair tie
3. hair tie in focus
4. focusplane at the back of the head
5. focus somewhere in the middle between the back of the head and the right ear
6. focus plane across the auricle
Photo sequence shot with my good old mighty SD9 and the Carl Zeiss Jena (GDR) M42 Pancolar 1,8/50mm fully open at f/1,8
Greetings and thanks in advance for Your feedback and suggestions!
 wood_gnome's gear list:wood_gnome's gear list
Sigma DP1 Sigma DP1s Sigma DP1x Sigma DP2s Sigma DP2x +5 more
POLL
0.0% 0  votes
0.0% 0  votes
hair tie in focus
8.3% 1  vote
8.3% 1  vote
66.7% 8  votes
16.7% 2  votes
  Show results
Sigma SD9
xpatUSA
xpatUSA Forum Pro • Posts: 19,858
Re: Femme views forest! - or: Where would *You* put the focus plane?
wood_gnome wrote:
Hi!
Voted #5 because, at that f-number, it gives a good impression of depth without too much blurring of the nearest part.
Now I double hate you because I had that same lens on a Praktica MTL-3 for many years before it too broke.
Pedantry is hard work, but someone's gotta do it ...
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +13 more
D Cox Forum Pro • Posts: 29,340
xpatUSA wrote:
wood_gnome wrote:
Hi!
I had a 50mm Pancolor on my Exakta for years and foolishly sold it (with other Exakta lenses). Never dreaming that one day there would be digital cameras that I could use them on.
Now, they are expensive.
What happens if you focus stack those pictures ?
Don
Sigma fp
pforsell
pforsell Veteran Member • Posts: 4,203
Is this a trick question? Makes no sense.
Either focus on the scenery beyond her, or ask your model to turn around. Backs of peoples’ heads are disgusting.
Peter
_
Jedem das Seine, mir das Meiste!
 pforsell's gear list:pforsell's gear list
Nikon D1X Nikon D2X Nikon D3X Nikon D3S Nikon D4S +25 more
wood_gnome
OP wood_gnome Regular Member • Posts: 134
No! To be honest I am surprised to read about such a mental connection.
Thanks for Your opinion! Of course there are "turned around" versions of this shooting. (Which I will not show due to privacy concerns.)
xpatUSA
Impolite and provocative.
It is obvious to everyone except you that the scenery is deliberately out-of-focus as an intended part of the composition.
Comment already address by the OP
You are entitled to your opinion which may not be shared by anyone here ...
docmaas
docmaas Veteran Member • Posts: 7,023
While I chose the last auricle location I would also jack up the aperture if similar bokeh were available.  Front and back bokeh work well for a subject in the middle of the image not so well when the subjects closer view also is less in focus.  JIHMO
Mike
"Laoma shitu" "An old horse knows the road" Chinese Proverb                                        "Dao ke dao, fei chang dao. Ming ke ming, fei chang ming" Laozi
"At every crossroads on the path that leads to the future, tradition has placed 10,000 men to guard the past."
Maurice Maeterlinck
rick decker
MOD rick decker Forum Pro • Posts: 17,727
5
More disgusting stuff comes out of the front of peoples heads than the back. In addition there are  some areas where disgusting stuff comes out that are one of the most popular shots by male (especially) photography.
You have my express consent to edit any of my images that I post on DPR. If you want to edit an image that does not belong to me that I have edited and posted, you need to contact the owner.
http://www.lightreflection.com
http://www.rickswavepics.com
sattva Regular Member • Posts: 405
wood_gnome wrote:
Hi!
Hello wood_gnome,
Interesting exercise
I chose the above, as personally i would consider it a photograph of someone in contemplation. And therefore the focus on the head area primarily .
Of course, there are many possible approaches based on one's perceptions!
These are very good photographs...and i am reminded of the exact same lens i used to have quite a long time ago...
Thank you for sharing and regards!
Sattva
 sattva's gear list:sattva's gear list
Sigma DP2s Sigma SD14
wood_gnome
Hi guys!
Many thanks for Your feedback so far. I am still collecting votes and will reveal what I think about it in a week or two.
Thanks again, greetings, and have a nice weekend!
PS: Special thanks Ted & Rick for Your support!
