camera shutter remote not triggering flash
Started May 1, 2021 | Discussions
Dondog New Member • Posts: 20
Hello DP community,
I am new here, and struggling with my first off camera flash setup while trying to do some self portraits :
I have my camera on a tripod with a radio transmitter and my flash is on a stand with a radio receiver.
when i press the shutter from the camera, everything goes well : flash triggers and camera takes the pic.
Now : when i release the shutter using an infrared remote instead of pressing the shutter from the camera, the camera take the pic but the flash does not trigger. The remote triggers the camera but it doesn't trigger the strobe.
Any idea or leads why its not working?
Thank you in advance
Iam using :
canon 5Dmkiii
canon rc6 infrared remote
600ex-rt flash
JCC JF-U1/JF-U2 radio transmitter receiver
MarshallG
MarshallG Veteran Member • Posts: 9,264
Re: camera shutter remote not triggering flash
What happens if you put the canon flash in the hot shoe? Does it fire with the RC6?
 MarshallG's gear list:MarshallG's gear list
Canon EOS R5 Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 16-35mm F2.8L II USM Canon Extender EF 1.4x II +4 more
OP Dondog New Member • Posts: 20
Hi
thank you for taking the time to answer.
Iam not sure what happenned and how it could be related  but I updated the camera firmware and it is not working.
apersson850 Senior Member • Posts: 2,175
What is not working? The whole camera, or just some function?
Anders
 apersson850's gear list:apersson850's gear list
Canon EOS 40D Canon EOS 400D Canon EOS 7D Canon EOS-1D X Canon EOS-1D X Mark II +26 more
Hi J
I ust wanted to say I solved the problem, it works with viewfinder activated but not in liveview mode...
Thank you all for taking the time to answer.
When using live view, make sure you turn off all versions of silent shooting. If the camera doesn't support that feature, you can't use it like that. But I would assume a 5D Mark III does support it.
Anders
