What is the best sling bag for my photographic equipment?
Started Apr 28, 2021 | Discussions
fernandojval
fernandojval Regular Member • Posts: 428
I have a Fuji X-T4 next to the 18-55mm lens (with the hood), plus the loose 50-140mm lens (with the hood turned) and a small Meike MK320 flash. In addition to batteries, cables, tissues, a spare mask and some other small accessories.
I am looking for a sling bag to carry every day. I have the 6-liter Peak Design and the gear fits, but too tight. I think that the Peak Design 10 liters is going to be too big and Peak Design does not make bags between 6 and 10 liters.
Does anyone recommend a sling bag for that photographic equipment? It may be from other brands, but I want it to be black and discreet.
 fernandojval's gear list:fernandojval's gear list
Fujifilm X-T4 Fujifilm XF 50-140mm F2.8 Fujifilm XF 70-300 F4-5.6 R LM OIS WR Tamron 17–70mm F2.8 Di III-A VC RXD +3 more
aukirk Regular Member • Posts: 164
Re: What is the best sling bag for my photographic equipment?
I like the Think Tank sling bags... I don't have those lenses, so not sure about sizes, but imagine the ThinkTank MindShift Photocross 10 would fit what you describe:
https://www.thinktankphoto.com/collections/photocross-sling-bags
 aukirk's gear list:aukirk's gear list
Sony RX1R II Fujifilm X-Pro3
Meeces
Meeces Contributing Member • Posts: 561
I would suggest checking out mountainsmith descent sling.  Not sure if it would be discreet enough, but I have the larger of the two sizes and really like it.  Both have expandable zippers.  The small one can go from 6 to 8 liters and the larger one goes from 11 to 14 when they are each expanded.  It’s very similar to suitcase/luggage that has zipper expansion.
Big one fits my x-t4 w/100-400 mounted and X-T2 w/16-55, a filter pouch, straps, batteries, 1.4 ext., macro extension tube, a prime (usually the 56 1.2).  Expand it and I can pile in more stuff.  The large one has a attachment strap/point for attaching even more things, or allowing the ability to slide the leg of smaller/travel tripod in to carry as well.
I also had the larger 10L peak design sling and got rid of it because it was too big/similar to the descent sling when I wanted to go ‘smaller’.
The thinktank urban access slings look really nice.  I think the size 8 would correspond to 8 liters?
Have to keep reminding myself, I don’t need more bags, I don’t need more bags.
Matt
instagram.com/matticus390
http://www.flickr.com/photos/akita/
Fujifilm X-T2 and X-T4. 23/35/56mm, 16-55, 50-140 and 100-400mm, 1.4 ext.
 Meeces's gear list:Meeces's gear list
Fujifilm X-T2 Fujifilm X-T5 Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 100-400mm F4.5-5.6 OIS WR +4 more
baobob
baobob Forum Pro • Posts: 18,248
I have a Lowepro and I'mvery satisfied
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
sshapiro Senior Member • Posts: 1,018
I have a Think Tank Urban Access 10 which I use to carry an X-T3 with XF16-55mm mounted, Godox 860 Flash, flash trigger, blower, spare batteries, and 77mm filters. I configured the bag so the camera/lens is sideways, not facing down, when you open the side panel. This provides very easy access to getting the camera in and out but does reduce the amount of space for other items. If you store the camera so the rear of the body faces you when the flap is open, you should be able to store an additional lens.
I tried the Urban Access 8 but found it was too small for my needs. Also, the bigger version allows me to carry an iPad Air 3 when needed.
21William Contributing Member • Posts: 866
Don’t discount buying a camera bag “insert” and putting it into the bag of your choice. For my gear I just bought a Messenger bag and added some padding and separators.
 21William's gear list:21William's gear list
Pentax K-5 Fujifilm X-H1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 10-24mm F4 R OIS
mistercharlie
mistercharlie Forum Member • Posts: 50
I have the black Wotancraft Pilot, the 7-liter version. Carries an X-Pro3 Nikon film slr, and a couple of Fujifilm lenses, or one Nikon lens, or one flash. Not too big, not too small.
https://www.wotancraft.tw/en/product/pilot-travel-camera-sling-bag-7L-blackC
fernandojval
OP fernandojval Regular Member • Posts: 428
I would like to know if the 50-140mm f2.8 lens fits upright in the Think Tank Urban Access 8 bag
Thanks !!!
doctorharrison Regular Member • Posts: 199
Consider F-Stop Bags -  either the 11 liter Fitzroy or 21 L Dalton. My Fitzroy is my go-to bag for everyday use, else it is the 50L Tilopa for purpose driven projects or the LowePro Protactic AW.
You cannot do wrong with ANY of these bags. My days of mistaken purchasing are behind me.
doctorharrison
Instagram: @doctorharrison https://www.flickr.com/photos/145673467@N08/sets/72157677654149536
X-T4 / X-H1 / X100V / 10-24 / 16 / 23-2.0 / 27 / 35-2.0 / 90 / 16-55 / 18-135 / 50-140 / 100-400 / 1.4TC
