RF 24-105 F4L horrible purple fringing
Started Apr 28, 2021 | Discussions
phatgreatwall Regular Member • Posts: 182
left top branch exhibits strong purple fringing
picture taken with R, raw format, converted in DPP, also tried LR and Luminar, could not remove the purple fringing in the branches.
bigshledge Contributing Member • Posts: 596
Re: RF 24-105 F4L horrible purple fringing
Purple fringing happens most with blown highlights.
 bigshledge's gear list:bigshledge's gear list
Canon EOS R6 Canon EF 100mm f/2.8 Macro USM Canon EF 8-15mm f/4L Fisheye USM Canon EF 100-400mm F4.5-5.6L IS II Canon RF 28-70mm F2L USM +1 more
SonyX
SonyX Senior Member • Posts: 1,238
 SonyX's gear list:SonyX's gear list
Nikon D4 Sony a7R II Panasonic Lumix DC-G9 Sony a7 III Nikon AF-S Nikkor 24-70mm f/2.8G ED +10 more
Tazz93
Tazz93 Veteran Member • Posts: 3,473
Try applying lens correction in DPP or in camera. They should nearly eliminate this stuff. IMO, Canon has relied too heavily on the correction side and too little on the design side. It almost feels like they decided to take short cuts, but I'm sure its more complicated than that. Either way, they really have been relying on the correction to save some aspects of the lens design and optically correcting the stuff that can't be easily corrected for in body or in post. I hoped they would go away from this, but it appears that's not the case.
Like others have said, you can minimize the effect by omitting that kind of massive contrast between light and dark. Normally, it will even make you images better, as that particular transition isn't normally appealing.
Mike Jackson - Wildlife Photography Enthusiast
https://www.flickr.com/photos/mj_flickr/
 Tazz93's gear list:Tazz93's gear list
Canon EOS-1D Mark II N Canon EOS 5DS Canon EOS R5 Canon Extender EF 2x II Canon EF 70-200mm F2.8L IS II USM +11 more
Leigh A. Wax Senior Member • Posts: 1,621
Stopping down also reduces Chromic Aberration.   F4 on a high contrast scene "invites" it.
Karl_Guttag Senior Member • Posts: 1,883
Modern software deals with this well, in particular, DXO PL4 works well on purple fringing (it could not do DeepPrime as the file was not raw).  I ran you picture through DXO PL4 and applied purple fringe removal. DXO PL4 also did some lens distortion correction (not sure if it should have, but it was enabled by default and it also did some sharpening/detail improvement).
I started with the Purple Fringing "automatic" settings and it suggested 100% and size=8, but I upped the size to 10 as it seemed to kill more of the purple. BTW, I would suggest punching up the saturation by about 20% (not done to the picture below) and the picture looked better IMO as it was a gray overcast day and the purple fringing did not come back.
DXO PL4 HQ mode with Purple Fringe = 100% and  size=10
 Karl_Guttag's gear list:Karl_Guttag's gear list
Canon EOS R5 Canon RF 15-35mm F2.8L IS USM Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 24-240mm F4-6.3 +14 more
BlueRay2 Forum Pro • Posts: 14,816
yeah, that is perfect condition for "purple haze"  extreme contrast! some high IQ expensive lens has very little fringe, and rf 24-105 is not one of them, unfortunately.
Absence of evidence is not evidence of absence!
OP phatgreatwall Regular Member • Posts: 182
thanks for all the info.  i downloaded a trial of DXO and it works like magic.  DPP/Luminar could not completely eliminate it, which is surprising since DPP is supposed to be Canon's official software that covers their lens flaws.  also the fact that an L lens exhibits such bad purple fringing is a shocker, i would've thought L for the price would be at least better than my iphone.
I think you may be expecting too much out of the lens
I'm not an expert on this, but my understanding is that purple fringing is largely due to the UV light getting to the sensor (see: https://en.wikipedia.org/wiki/Purple_fringing). UV light is out of the range of wavelengths for which the lenses are designed, but which the camera ends up detecting as purple.
Even people with very high-end lenses will get purple fringe in the right conditions. It turns out the overcast days have a lot of UV light which makes the problem worse.
In the cases where purple fringing becomes seriously bad, it can be easily removed. But you may not want to process it out all the time due to the computational effort and time and the risk of damaging something else in the image.
thunder storm Forum Pro • Posts: 10,139
No, it's not shocking at all.
1. You just should have stopped down. I really don't see a reason to use anything wider than f/8.0 for this shot.
2. If you didn't want to stop down you should have used a prime.  A prime also allows you to shoot at a bit wider aperture than f/4.0 giving you more separation still being stopped down enough to keep the fringing very low.
3. You should have exposed for the highlights
4. A polarizer filter would have helped a little too in this case
Look, I can imagine 2, 4 and even 3 are too much hassle, no problem. But 1 is just user error. Yes, it's an L lens, but it's only 1200 euro, and most important: it's just a zoom, and therefor it should be treated just like that.
There are some primes with (close to) zero fringing wide open, but at the 24mm focal length even expensive primes need to be stopped down a little to avoid fringing.
I love 50mm (equivalence)
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
Tristimulus Veteran Member • Posts: 9,998
Re: I think you may be expecting too much out of the lens
UV light does not reach the image sensor at all. Cameras have UV and IR block filters over the image sensor.
Purple fringing is caused by dispersion. Red or blue light is slightly out of focus.
Nope.
But get some branches closer than the focus point towards the corners of the image. Add a large aperture. Then you will provoke purple fringing most effectively.
Yes.
Nope. Just remove secondary chromatic aberration in post processing without fear!
Longitudinal chromatic aberration however is rather pesky.
Mako2011
MOD Mako2011 Forum Pro • Posts: 28,706
Not....
That's not completely true.  The filter stack does block most (99%+)  UV that might affect normal shots but not all.  The only time where you might see the effect of some UV light getting trough is at very high shooting altitudes..well above 10,000 feet...and it usually manifests with a bit of "haze".  Using an IR filter on the lens (A vs B comparison) makes it pretty obvious.  Very Very few folks will run into the issue and the degree will vary by model.  I only know because I've done a lot of shots above 18,000ft
My opinions are my own and not those of DPR or its administration. They carry no 'special' value (except to me and Lacie of course)
AshleyMC Senior Member • Posts: 2,228
It’s not the lens.
The title of your post should have been: Horrible purple fringing in this image of mine.
I can easily create “purple fringing” with dry branches sticking out on overexposed sky, using any lens on any camera.
Cheers!
Tony D Senior Member • Posts: 1,074
This is by far Canons worst RF L lens (based on the one I have, but its approximately 1/2 the cost of most other RF L lenses and suffer also most as much as the RF 600/800 non-L lenses, uncorrected, from such distortions). I think the older EF 24-135 has better performance out of the box.
Whilst you can correct it with careful exposure control or post processing the raw images, without these correction, suffer highly from several distortions - I have it but stopped using it after I purchased the L trio (RF 15-35 L, 24-70 L. & 70-200 L) which suffer much less from such . Mine pocket now suffers instead (their all at least twice the price of the 24-105). The downside is their weight and 3 replacing 1 lens.
 Tony D's gear list:Tony D's gear list
Sony RX100 VI Canon EOS 5D Mark III Canon EOS M3 Canon EOS R Canon EOS RP +13 more
