Diagonal Streaks In Sky on Select Shots (NOT Posterization)
Started Apr 28, 2021 | Discussions
OP Platographer Contributing Member • Posts: 884
Re: Crepuscular rays
CarlitosM wrote:
Tristimulus wrote:
GSWayne wrote:
CarlitosM wrote:
Tristimulus wrote:
CarlitosM wrote:
Tristimulus wrote:
GSWayne wrote:
One way to try to verify if it is sun rays would be to use a program (like PhotoPills or TPE) that determines the sun angle at the particular time and place you took the photo and see if the angle matches.
Or just take a look at the foreground of the image...
The shadows in the foreground and the streaks make different angles relative to the horizon. The foreground shatows' angle appear to be smaller. You would expect the opposite if they were both from the sun.
Rectilinear wide angle lens and distortion away from the center spot...
The different rays/shadows should all still come from the same source.
When I tried comparing the angle of the streaks to the angle of the shadows on the pier they were within a few degrees. I think you cannot directly compare the two angles because the angle of the shadow on the pier will depend on both the position of the sun and the relative location of the pier horizontal beam and the object that is causing the shadow. Likewise the exact angle of the streaks in the sky will depend on the location of the clouds that may be causing the streak.
+1
I don't have huge confidence in my ability to mentally do the 3 dimensional trigonometry to figure out these angles so I this may not be a correct analysis, but I think the streaks are in the sky, not in the lens. Unless you compare the lenses at almost exactly the same time I would be concerned that you could have changes in the lighting conditions that would make a direct lens comparison difficult.
Where ever the rays break through the clouds they go straight to the sun. They should also not run towards each other when you follow them away from the sun like the two brighter ones. Have a look at the first of the last three images the OP uploaded and play with the contrast, there are odd streaks in the sky all along the image.
Why did the photo from the same place taken 14 minutes earlier not have the streaks? If it is a problem with the lens, you would expect to see the streaks in the second image. (I am referencing the three photos from my last post.)
CaliforniaDave Senior Member • Posts: 2,305
Re: Diagonal Streaks In Sky on Select Shots (NOT Posterization)
Does your Tamron 28-200 have the latest firmware?
I just checked and it does not. It looks like the latest update, version 3, came out in November 2020, around the time I bought the lens. I will update the lens firmware. I doubt that is the issue, but it's always good to have the latest firmware and at least be able to rule that out.
I also doubt the firmware is an issue, but it is good to remove as a variable.
Tristimulus Veteran Member • Posts: 9,434
Platographer wrote:
CarlitosM wrote:
Tristimulus wrote:
+1
Clouds move and crepsular rays come and go. Even the very faint ones.
