Snapped Lens Mount of XC 50-230 on 2nd outing... Advice?
Started Apr 26, 2021 | Questions
fujiian
fujiian Contributing Member • Posts: 718
Well, I guess you get what you pay for.
I was hiking yesterday with my brand new 50-230 when it leapt from the top of a mossy rock, dropped less than 3 feet, and completely separated from the camera.
No cracked glass, no sensor damage to my trusty X-T2, but all three 'threads' of the lens mount were completely sheared off. Bummer camp.
I have seen replacement rings like this one floating around... three questions:
  1. Is this the kind of repair I can do myself? Only tools I have are tiny screwdrivers.
  2. Would you bother? I got a new copy super cheap so I do hope to keep the lens.
  3. Long shot... would there be any way to attach a proper metal mount instead?
Any advice appreciated, aside from "dOnT L3AvE yOuR cAm3r@ 0n @ r0ck!!!!".... Likewise, no condolences necessary, this was absolutely and completely my fault
 fujiian's gear list:fujiian's gear list
Fujifilm X-T2 Fujifilm XF 35mm F1.4 R Fujifilm XF 27mm F2.8 Fujifilm 16-55mm F2.8R LM WR Fujifilm 50-230mm II +4 more
Fujifilm 50-230mm II Fujifilm X-T2
Aoi Usagi Veteran Member • Posts: 3,222
Re: Snapped Lens Mount of XC 50-230 on 2nd outing... Advice?
Thats terrible.  However the replacement looks straight forward.  The clips will need to be removed for the ribbon cables.  This could be done with a finger nail or tweezers and the new mount screwed in.  I would suggest using JIS or JCIS (Japan Industry Standard / Japan Camera Industry Standard) screwdrivers, but a normal phillips driver works but may cause some damage to the screws.  Hope you can get it fixed.
Formally Evogt500
Craig268
Craig268 Senior Member • Posts: 2,005
Has nothing to do with you get what you pay for. Had the lens not separated from the body of the camera you may have had damage to both the lens and the camera.
In other words, the breakaway lens probably saved some camera damage.  I had a similar incident with an XC16-50 once.
These are very fine lenses but yes things break when dropped.
 Craig268's gear list:Craig268's gear list
Fujifilm X-T1 Fujifilm X-T10 Fujifilm X-T4 Samyang 85mm F1.4 Aspherical IF Fujifilm XC 16-50mm F3.5-5.6 OIS +11 more
fujiian
OP fujiian Contributing Member • Posts: 718
Awesome, thank you!
I had no idea JCIS screwdrivers were a thing, but those little ones really do have to be just the right size. I will look into it.
To be honest, I am not sure what the difference between JIS and JCIS is.  I have a screwdrivers that are rated for both, so it might just be the same.
Formally Evogt500
lewiedude2
lewiedude2 Senior Member • Posts: 2,662
Thank goodness it wasn’t your 16-55 (your list shows it in your collection).
Go on Amazon or an equivalent, and search for precision tools/tool boxes/jewelers screwdrivers, etc. You will find that for something like US$20 you’ll get a highly function set of tools that can help in many ways. Go for it and fix it yourself. But get the correct tools. Good luck!
 lewiedude2's gear list:lewiedude2's gear list
Fujifilm X-T2 Fujifilm 16-55mm F2.8R LM WR
Jo Mar Junior Member • Posts: 33
Hopefully the lens mount on the camera body was not damaged from the impact. The metal mount could be slightly deformed, with the possibility that one corner pushed in or pulled out and might not be visible to see. The factory would measure any high or low of points of the mount with a collimator or other instrument. Any deformation of the lens mount, can affect sharpness.
Joel
 Jo Mar's gear list:Jo Mar's gear list
Fujifilm X-T5 Fujifilm XF 35mm F1.4 R Fujifilm XF 27mm F2.8 Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 100-400mm F4.5-5.6 OIS WR +2 more
Pixel8888 Contributing Member • Posts: 979
I recall some old reports, that the electronic part of the XC lens mount is soldered. There used to be replacement XC lens mounts with or without electronic connectors on ebay. Best is to spend some time to google for this topic, before you buy the wrong replacement mount. There was an old report on dpreview from Peetz, he had a broken XC16-50 lens mount.
 Pixel8888's gear list:Pixel8888's gear list
Fujifilm X-T2 Voigtlander 35mm F2.5 Color Skopar Fujifilm XF 27mm F2.8 Samyang 12mm F2.0 NCS CS Fujifilm 16-50mm F3.5-5.6 II +6 more
